Question about Hunter 21617 Palermo Brushed Nickel Ceiling Fan
Hunter model 21617 receiver wiring diagram - Hunter 21617 Palermo Brushed Nickel Ceiling Fan
  • 52 Answers
SOURCE: Hunter 44630 thermostat
Here is a link that will have wiring diagram it is for a similar model hunter. Also check your dip switch on the back of the stat to ensure it is set for gas (HG) or electric heat (HE) depending on your type of unit. Good Luck. Rule of thumb for most four wire systems is RED (power to stat) Yellow (Cooling) Green (Fan) White (heat)
Posted on Jan 29, 2008
  • 333 Answers
SOURCE: Hunter Palermo Ceiling Fan Problems-model # 21617
lick on this link and it will take you to there web sight and on it you will find email and # to contact them reguarding parts. I hope this helps. Don't forget to rate this answer.
Posted on Feb 07, 2009
  • 19 Answers
SOURCE: need a wiring diagram for thermostat/hunter model44260
Hello please try this link and see if this contains the information that you need
Reply to bsix@hotmail one way or the other Thanks
http://www.hunterfan.com/uploadedFiles/Support/Owner_Manuals/42711.pdf
Posted on Sep 14, 2009
jyackle5
  • 8197 Answers
SOURCE: Need diagram for hunter fan with light kit. Three
Black to black. from fan
Blue to Black and white. from fan
White to white. from fan
The input is from ceiling supply
the black wire from fan is for motor.
the black and white is for the light.
Posted on Jan 02, 2010
  • 3 Answers
SOURCE: Hunter fan model 21617 remote fan won't turn on
You mean only the light? and the fan is working? Have you checked the light bulb? If it's ok, then checked on the wall switch. If is also ok, then probably there's is something wrong with the wiring in the fan.. It's either a bad or loose connection
Posted on Jul 22, 2010
How to install hunter palermo ceiling fan?
Your question is too broad. Do you need help with the mechanical installation or the wiring? Be more specific.
This is a link to the owner's manual: http://www.hunterfan.com/SupportDocuments/OwnersManuals/42700.pdf.
Jul 13, 2014 | Hunter 21617 Palermo Brushed Nickel...
Hunter fan remote bypass
This fan uses a "ballast" to run the fan. The ballast (part #272) probably contains wiring for multiple speeds. Here is a manual that discusses the wiring- http://www.hunterfan.com/SupportDocuments/OwnersManuals/42700.pdf.
To use a wall mounted fan dimmer, you need to identify the high speed wires and connect them to the dimmer switch. This method will bypass the other speed windings and is not as power efficient.
Jan 31, 2014 | Hunter 21617 Palermo Brushed Nickel...
Lights come on at random .has a remote how to fix ?
The fan remote control receiver used in the Hunter 25730 model fan (see picture) is not available from Hunter. Remove the fan from the ceiling. Remove the receiver and take it to recycling. It can be replaced using a readily available and inexpensive replacement universal remote and receiver controller. There are limitations though. The Hunter receiver provided fan reversing functions. The universal controllers do not. You therefore have two options.
Option 1: The universal receiver can be installed such that the fan direction is fixed, either up or down, all other functions operate normally.
Option 2: A reversing switch can be purchased from Radio Shack for about $4 and installed in the fan. This does require cutting a square hole and drilling two bolt or rivet holes in the side of the cylindrical housing which previously housed the Hunter receiver. I'd suggest the Radio Shack DPDT slide switch part number 275-403.
Refer to the wiring diagrams and connector pinout diagram for connections. Please note that the connector pinout diagram is the connector that is soldered to the circuit board as shown in the photo of the Hunter receiver. If your motor wire colors are different then with the connector unplugged from the receiver use a multimeter to probe all the motor wires in order to identify two pairs of wires that indicate approximately 70 ohms each pair. These will be the motor windings. 6b0a1409-5a20-4efe-a059-c600652e9512.jpg 5da8e4ef-1b54-40d0-a8a4-21d4608b1d23.jpg 9fc8772d-3ac3-41b7-aa55-78ccc6e5ea00.jpg 0759e340-6464-4c4b-90f5-6d9926e74e42.jpg
Jan 23, 2014 | Hunter Ceiling Fan Light Remote Control
What is the whirring diagram
Most fans have 3 wires usually a white, black, and a blue(or black with white stripe) the white wire is the neutral and goes to the white wire in the ceiling box, the black wire is the fan hot lead and goes to the black hot lead in box and the blue(or other blk/wht) is for the lights and would go to the switched lead in the ceiling box(sometimes another color but not white or green)..if you don't have a switched lead coming out of the ceiling box and just two wires then the white goes to the white in the ceiling and both black and blue go to the black wire in the ceiling box
Jan 22, 2011 | Hunter 21617 Palermo Ceiling Fan
Hunter fan model 21617 remote fan won't turn on light from wall switch
Jul 01, 2010 | Hunter Ceiling Fan Light Switch Control
Feb 06, 2009 | Hunter 21617 Palermo Brushed Nickel...
Simultaneous fans
USE A DIFFERENT DIP CODE TO THE SECOND RECEIVER AND REMOTE
Jun 01, 2008 | Hunter 21617 Palermo Brushed Nickel...
Hunter 21617 Palermo Brushed Nickel Ceiling Fan Logo
63 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Brandon Berry
Brandon Berry
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
