Question about Garden
Rebuild a model # 190412 briggs and stratton engine
  • 40 Answers
SOURCE: need model number for Briggs & Stratton engine in
try this
http://manuals.mtdproducts.com/mtd/public/list.jsp?BrandCode=0&LeftNav=true&model_num=147-812&serial_num=00000000
Posted on Mar 11, 2009
  • 22 Answers
SOURCE: 5 HP Briggs and Stratton Engine
use a champion RJ19LM spark plug, you will see that the engine is built by briggs and stratton.hope this helps
Posted on Mar 30, 2009
  • 68 Answers
SOURCE: the flywheel pin needs replacing on 3.5hp briggs and strat.engine
Take off the top sheet metal , there should be a nut & spring washer that will have to come off, they will be tight. Put the nut back on a few threads, use a prybar to put some upward pressure on the flywheel at the keyway side, while hitting down on the nut with a block of wood & large hammer. This should pop the flywheel loose from the taper shaft, replace drive key with ALUMINUM key!!
An impact wrench is sometimes necessary to get the nut loose.
Posted on Apr 26, 2009
  • 376 Answers
SOURCE: Fuel in tank going into engine and mixing with oil
The float needle and seat are leaking and not shutting off the fuel when carb bowl if full. It then flows down the intake into the cylinder, past the rings and into the crankcase. Have the needle and pressed-in brass seat replaced. Could save yourself some money if you removed the carb yourself and took it in.
Posted on Jun 12, 2009
  • 10865 Answers
SOURCE: need head bolt torque for Brigges Stratton 18 Hp
210 to 230 inch pounds. Torque in a crisscross pattern upper left lower right upper right or left or right.
Posted on Jul 10, 2009
Briggs & stratton v-twin engine cuts out
acid dip rebuild carb make sure fuel selinoid on bottom of carb moves freely
Sep 07, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Poor running engine on my lawn mower
I think you need more than a screw adjustment in the carburetor. It sounds as if you need a full tuneup. This means air filter, gas filter , carb. rebuild ,spark plug etc. Good luck. donnyb60
Mar 22, 2009 | Briggs & Stratton Garden
Looking for briggs+stratton repair manual 271172
wiill not start has all new spark plugs and fuel filter
Mar 20, 2009 | Briggs & Stratton Garden
Garden Logo
99 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
