Question about Canon PIXMA MP780 All-In-One InkJet Printer
PIXMA MP780 Paper feeder wont work and there is no manual solution
The fax memory is full and the paper feeder wont work, it keep trying to feed in paper. There does not seem to be a manual feed solution,
  • 33 Answers
There could be a jam right down the bottom
Posted on Oct 27, 2008
The paper feeder wont do it's job,will not feed paper . Makes loud noise but no action, then screen asks to load paper.
The feeder on this model has 1 weak mounting place for the gears that drive the feed roller. The plastic stud that holds the gear will break off of the frame and cause the noises you hear and no paper feed. The only fix is to replace the sheet feeder assembly, about $30.00 for the part.
Feb 21, 2010 | Canon PIXMA MP780 All-In-One InkJet...
I have a canon pixma mp780 all in one printer. It keeps saying add paper but the paper tray is full.
Check the feed switch, you can put paper in the bottom tray or the top feeder and you press the feed switch to change from one to the other, when the rollers are dirty and paper doesn't pick up you also get that error.
Jan 14, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Paper won't feed through to print my faxes.The mechanism sounds like it is turning to pick the paper, but it isn't feeding through. As an alternative, can I use the USB port to copy the faxes onto a USB...
That model quite often breaks plastic parts that hold the gears together in the sheet feeder, a new sheet feeder will run around $49.00, there's no way to transfer faxes out of the machine without printing.
Nov 04, 2009 | Canon PIXMA MP780 All-In-One InkJet...
My PIXMA MP780 is still flashing check the printer then press ok - an error msge ##357 keeps coming up. what does this mean pls?
This is an error in the position of the paper feed unit.
First, make sure there is no paper jam anywhere in the machine.. look inside, rear, where the paper tray (output) is, etc to see if you find any shreds or torn paper that may have gotten stuck and you didn't see.Look carefully in the zone of Purge unit, using flashlight in the right side on printer.Look in the sheet feeder too. If this not help your printer need service.
Oct 28, 2009 | Canon PIXMA MP780 All-In-One InkJet...
My PIXMA MP780 always says "Warming Up" when I try to fax or scan. It never warms up. The machine prints fine- doesn't do much else.
Paper feed roller
cleaning
When paper does not feed properly.
To clean the paper feed rollers.
Machine buttons
2 min.
Oct 12, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Doesnt print faxes or copies because the paper isnt picked up from the tray
1. Remove any paper from the Auto Sheet Feeder and Cassette.
2. Select the paper source with [Feed Switch].
3. Press [Menu] repeatedly until 3.MAINTENANCE> appears.
4. Use [<] or [>] to select <ROLLER CLEANING>.
5. Press [OK].
6. When cleaning has finished, repeat steps 3 to 5 for a total of three times.
7. Load A4- or letter-size plain paper in the selected paper source and repeat steps 3 to 5 additional three times.
Oct 01, 2009 | Canon PIXMA MP780 All-In-One InkJet...
When i turn it(canon MP780)on, i see a error (##357). How can i fix it?
The service manual says this for ##357:
ASF paper feed (AP) position error.
AND ALSO:
##357 ASF paper feed (AP) position error
Cause: An error occurs at the AP positioning in the ASF (Auto Sheet Feeder) unit.
Solution: (1) To reboot, press [OK] button or turn off and then on the power.
(2) Replace the SHEET FEED ***’Y.
(3) Replace the SPCNT board.
Apr 04, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Problems with paper feeder-wont feed through-chews up paper
I HAD THE SAME PROBLEM A MONTH AGO. I LOOKED WHERE THE PAPER LOADS AND THERE WAS A PAPER CLIP JAMMED IN THERE. I HAD A HECK OF A TIME GETTING TO IT, BUT I DID. AND IT WORKS FINE. MAYBE SOMETHING IS THERE.
Jan 31, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Canon pixma mp780 getting memory
Open printer properties click paper to use /paper size then okey
Jan 08, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Hp paper feeder wont thu printer
paper feed rollers wont feed paper through and also paper tray is empty prompt comes up when there is paper in the tray tried small amounts of paper and still says tray is empty
Dec 27, 2007 | Canon PIXMA MP600 all-In-One InkJet...
Canon PIXMA MP780 All-In-One InkJet Printer Logo
186 people viewed this question
old marine
old marine
