Question about Frigidaire FRT8B5EQ 30" 18.2 Cu. Ft. Top Mount Refrigerator w/ 2 Clear Crispers, 2 Sliding Wire Shel...
Dead mouse, need to remve non-removable drain pan.
Hi, I have a frigidaire top mount fridge. Manual says drain pan is non- removable, when I romove toe kickĀ  Ican get my hand on the drain pan but the opening is too small to pull it out, ther's a dead mouse and the smell is awful. Purchased in 2004. Thank you !
2 Suggested Answers
  • 958 Answers
SOURCE: drain pan
yup..that's how it is. no solution but to pick up the dead mouse and clean the drain pan as is, where is.
you might send someone with a small hand to reach the pan completely. rinse it with soap and water to eliminate the odor. use gloves to pick up and clean the pan.
tnx 4 using fixya,
drcool
Posted on Oct 24, 2008
SOURCE: drain pan
If u have 2 people u can lean the fridge back and the drain pan unscrews from the fridge from the bottom even though it says "non-removable
Posted on Jul 31, 2009
How do I clean the drain pan? Why in the world would anyone make a fridge that has a non-removable - and even a non-accessible drain pan? It stinks after awhile and it does need cleaned - even if jus
The "cover" is removable. Once the cover is removed, you can gain access to the pan and remove it for cleaning. The removal process can be a little tricky, but it can be done.
Dec 19, 2014 | Refrigerators
Frt18hs6dw9 top freezer refrigator
I believe it would be the defrost drain from the freezer is clogged. remove 4 screws in Refrigerator section which hold light bulb, temp sensor assy, etc.
there is a drain pan built in to the rear of this unit, and a tube which goes from the pan to the base of fridge. be removing the unit, you will be able to see if the drain pan has clogged, or if you need to carefully snake the drain tube.
Our unit the pan clogs every couple years.
Jul 08, 2012 | Frigidaire Refrigerators
I have a no frost frigidaire fridge and recently when it defrost it goed at d bottom section of the fridge
The evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the inside of the freezer at the bottom of the rear cover.
Jun 22, 2011 | Frigidaire 14.7 Cu. Ft. Top-Mount...
Dead mouse in drip pan how can i remove the pan
If you have the model where the drip pan is on top of the compressor you can twist it back and forth a few times. This will break loose the glue that is adhering it to the compressor. Just make sure when you put it back in that you put the drain line back in it.
Jan 30, 2011 | Frigidaire Refrigerators
Fridge is dripping directly onto top shelf. It is
Hello, this sounds like you have a blockage in the drain tube, remove panel back/bottom of freezer..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curtain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the fridge is because the water has been leaking into the freezer and down the vent into the fridge instead of running into the drain hole...Please feel free to comment again if you have any other question. Mike
Oct 22, 2009 | Frigidaire FRT18FS6C Top Freezer...
Water dripping down on top shelf of refrigerator compartment.
Hello, this sounds like you have a blockage in the drain tube, remove panel back/bottom of freezer..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the fridge is because the water has been leaking into the freezer and down the vent into the fridge instead of running into the drain hole...Please feel free to comment again if you need any further assistance. Mike
Sep 18, 2009 | Frigidaire 20.6 cu. ft. Top Freezer...
The air vent between my freezer compartment and fresh food compartment below is frozen over and as a result, the fresh foo d compartment gets too warm. I have a Frigidaire refrigerator, model FRT8B5EWA....
you have a blockage in the drain tube, remove panel back of freezer..you will see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. the reason you see water in the fridge is because the water has been leaking down the vent instead of the drain hole...If you need any further assistance please feel free to comment again. good luck!
Jun 29, 2009 | Frigidaire FRT8B5EW 30" 18.2 Cu. Ft. Top...
Drain pan
Oct 24, 2008 | Frigidaire FRT8B5EQ 30" 18.2 Cu. Ft. Top...
Frigidaire FRT18IL6D
Hi thanks for your question. to unclog. pull fridge away from the wall. remove back cover , clean all coils. let fridge thaw for at least 24 hrs. get small plastic hose to push up the drain tube from the back. blow up yhr drain tube to clear the tube. thanks the appliance doc. please rte my answer, thanks.
Oct 12, 2008 | Frigidaire FRT18B4A Top Freezer...
Refrigerators Logo
150 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Electrolux
Electrolux
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
