Question about Whirlpool Refrigerators
I have a Whirlpool fridge/freezer Model ARZ735/S The vegetables are freezing in the bottom drawer and there is ice on the fridge wall
  • Anonymous Mar 25, 2014
    remove bottom freezer drawer
  • 958 Answers
The return duct could have been blocked with ice already. try to defrost it manually by unplugging it in 24 hours and make sure the vent is cleared of ice then replug it and test it again.
need to transfer all the goodies in another fridge.
tnx 4 using fixya,
drcool
Posted on Oct 24, 2008
I have a barge bottom freezer model B 26 ft 70 s
efrost cycle not working properly. bad heating element or bad thermostat
Aug 26, 2014 | Refrigerators
Why do my vegetables freeze
Do you have frost buildup on the rear wall of your freezer? What is the model number for your Whirlpool? It is important that you provide the model number so I can see what may be causing the freezing temps in the fresh food section/crisper. Thanks JT
Feb 06, 2013 | Whirlpool Refrigerators
Icing up in the freezer, loosing cold in the fridge. Sweating down the inside wall between fridge and freezer. Icing up at vegetable drawer.
Pull the fridge our from the wall and vacuum the back wall of it very gently. Also, take the kick plate (just above the floor) off and vacuum that underneath as well. It might not correct the problem but it won't hurt.
Feb 09, 2011 | Microwave Ovens
Model CTX18GAZBRWW - (Hotpoint) no-frost - freezer on top Water collects under the vegetable drawers and must be removed every day.
Something to try....on the back wall of the fridge nearer to the top is a little cup like part sticking out. There is water in it but it usually runs down an attached tube inside back wall and ends up under the fridge and gets evaporated. If that tube or the little cup thing is plugged then it will drip in the fridge and collect on the inside bottom of the fridge. So the trick is to clean them out. Check it out ...may solve the problem.
Sep 07, 2010 | GE 18.2 Cu. Ft. Frost-Free Top-Mount...
Water accumalating in the bottom of the fridge.
A common problem. All modern refrigerators have an automatic deicer. The heater kicks in, then MELTS the ice in build up in the freezer for a short period before freezing again. This water drains either in the fridge or out the back to the catch tray. Simply pull out the bottom drawers and clean the clogged drain hold where the water can drain and evaporate in the catch tray as it is designed to.
Mar 14, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
I purchased a bottom freezer Amana refrigerator when we built our house in 1999. The produce in the vegetable drawer keeps freezing! Everything else in the fridge is fine. Why does this happen?
Usually on bottom freezer fridges, there are two vents at the bottom of the freezer compartment where the cold air goes back into the freezer (cold air enters the fridge through the vent at the top/back of the fridge.)
If the vents at the back of the fridge are covered, the cold air will settle to the bottom of the fridge after it enters, and freeze your vegetables. The problem could be caused by ice build up in the evaporator coil of the freezer section also, but this will probably warrant a checkup from a pro.
One thing that can cause ice to build up inside those vents is moist air seeping in through a faulty door gasket. A thin coat of ordinary Vaseline on the gasket surface can help it make a better seal.
Dec 04, 2009 | Dishwashers
Bottom of fridge under vegetable drawers lots of water collects. Every two days have to soak up.
I assume it's a top freezer model. The drain is either blocked, or frozen up. You'll have to be able to remove the the rear panel in the FREEZER compartment and inspect.
One other thing that can cause this, is if you have an Ice maker, and when filling, the fill hose to the ice maker hose has become dislodged.
Oct 19, 2009 | Whirlpool Refrigerators
Bosch Refrigerator ice forming in vegetable drawer
Emptied drawers and cleared the drain hole. Drawers were then refilled BUT MADE SURE THAT THEY WERE NOT OVERLOADED
Jul 28, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
Kenmore elite fridge crisper drawer freezing stuff
If you have a side by side model you need to look at the refrigerator compartment wall on the left of the bottom drawer and move the slide control to the warmer/fruit/vegitable setting instead of the meat setting.
I hope this helped. Please rate my help or ask for more help please. supertechks
Apr 05, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
SubZero 550 not cooling, ice film
1. check the comp. working touch the top of the comp. 2.if the motor comp. working touch the high side tube of the motor comp. if to hot the freon is ok. 3. check the cooling fan inside.
Sep 23, 2007 | Sub-Zero 650 / O Bottom Freezer...
Refrigerators Logo
203 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
