Question about Hitachi Video Cameras
Hitachi dzhv595e The camcorder doesnt hold a charge and wont power up. Have tried this with two different batteries.
  • 30 Answers
SOURCE: Hitachi DVD camcorder
The door might be stuck. Try "helping" it open manually after pressing the eject button. Otherwise, something is probably broken and you might have to call a repairman.
Posted on Apr 09, 2006
  • 125 Answers
SOURCE: Sharp Camcorder VL-NZ100E battery doesn't seem to charge
2.7 volts is too low. Usually camcorders use battery at least 6 volts. Problems with rechargeables especially NiCds and NiMH, a cell will be shorted. for 6 volts pack, there are 5 cells in series (5 pcs x 1.2 volts with load , 1.35 no load). If you are measuring only 2.7 volts, it is highly possible that 3 cells are dead. As for the charger, if the same charger is used to power the camcorder and you said the the camcorder operates using the adaptor, this means that the charger is OK. You can ZAP the battery back to life but I will not recommend. It can be dangerous. If you can buy the battery, I suggest you do it since the old battery, even when zapped, will not provide enough juice anymore.
Posted on May 22, 2007
  • 30 Answers
SOURCE: jvc digital video camcorder gr-d20ek no power
wipe the contacts with after shave solution or isoprophyle alcohol, this may do some magic
Posted on Aug 15, 2007
fotomohamed
  • 321 Answers
SOURCE: No power on DVR D100 panasonic camcorder, battery is okey.
desolering inside pin show to near service centre or contact us
Posted on Jun 19, 2009
  • 64 Answers
SOURCE: camcorder wont charge
Try cleaning the brass tabs on the battery and the point of contact brass in the camcorder. Use a soft brass brush (gun clean kits at Wal-mart carry them in all sizes). I do NOT recommend useing steel wool because steel wool will leave little bits of itself behind and cause shorting out
Posted on Sep 24, 2009
Hitachi DZHV595E editing problem
Are these points not covered in the camcorder manual ?
Mar 26, 2017 | Hitachi DZHV595E HD Camcorder
I have recently bought a Hitachi DZHV595E camcorder and have upgardedd the memeory card to a Sandisk HDSC (Extreme HD) 8GB class 10, the camcorder doesnt appear to be seeing the card. When I put the card...
Hi i have a Hitachi DZHV595E HD Camcorderand when im videoing and pause it and take it of pause carry on videoing and look bout on the video it speeds fast then slows down then fast again please help as im
disappointed thanks james
Jul 26, 2011 | Hitachi Video Cameras
Hitachi (VM-E520A) camcorder battery problem
IT may be the charger itself try another battery to see if does the same or just simply the battery BURN!!
Jun 28, 2010 | Video Cameras
I own a Sony DCR-HC47E Handycam.It will not turn on
i have a problem with my sony dcr-sr47 camcorder it wont charge the battery camera works fine with power supply any solutions.
Dec 15, 2009 | Sony DCR-SR47 Camcorder
Camcorder wont charge
Sep 24, 2009 | Video Cameras
Hitachi DVD Video Camcorder Model DZ-HS300A wont turn on
Melinda, Did you ever solve this problem? I am having the same problem with mine.
Jul 03, 2009 | Hitachi DZ-HS300A DVD Camcorder
Canon ES 50 does not work with battery but works w/power supply
battery could be worn out mine doesnt even take charge anymore.You can still buy batteries for this camcorder for ES 50
Nov 23, 2008 | Canon ES50 8mm Camcorder
730 camcorder
well it sounds like the battery is dead. try charging it fully...if it doesn't work, then try getting a new battery for it, and if that doesn't work, try taking it in to a camera repair shop.
Apr 16, 2008 | Hitachi DZ-MV730A DVD Camcorder
No Power on
if it doesnt come on even on charger, then most likely the mainboard is damaged.
even with a bad battery the pda should work on charger.
May 19, 2007 | Hitachi G1000 Pocket PC
Video Cameras Logo
82 people viewed this question
Top Hitachi Video Cameras Experts
mega_mind
Are you a Hitachi Video Camera Expert? Answer questions, earn points and help others
