Question about CAD Microphones Audio Players & Recorders
Connect CAD gxl 1200 to computer - CAD Microphones Audio Players & Recorders
3 Suggested Answers
  • 43 Answers
SOURCE: cad gxl 2400
When you say working in some places but not others, do you mean it works on some channels but not others?
I'm sure you are aware that condensers will not work without phantom power. I'd suggest trying your mic through a different system (if there are non available try your local music venue, if you ask the engineer nicely I'm sure he'll let you test it on their rig). Also try a diffenent condenser on all channels of your mixer, and also try a dynamic mic as well just for thoroughness.
I can't really give you an answer to this unless you've tested with other equipment to identify which part of your rig is faulty.
To be honest I wouldn't be surprised if it was your mixer, I've always found behringer gear to be pretty crap quality.
Also it might be a stupid question but have you tried using a different cable?
Posted on Dec 01, 2007
SOURCE: gxl 2400 wiring connections
I need to take apart a shure pg58 wireless mic how do I do that
Posted on Oct 24, 2009
Gxl 2200
The easiest way to do it properly would be to use a small mixer, with an adapter cable from the outputs (usually 1/4") to the line-in of the laptop (usually 3.5mm stereo).
Mar 29, 2014 | CAD Microphones GXL2200 Professional...
My gxl 2200 condenser mike is not working for my mix craft 6
The usual procedure when a mic is not working - check that the phantom power (+48V) is working, then try another cable.
If the mic is out of warranty and you're low on bucks, you might have to fix it. Unscrew the base, carefully holding the body sleeve up against the screen. Then carefully slide off the body to expose the PC boards. Check the boards and wires for cracked copper film and bad solder joints. Two tiny Philips screws will allow you to remove the REAR board for full inspection of both. If all is good physically, start checking components with a multimeter. (if you don't know how, StartPage it.) The circuit is similar to the one below, EXCEPT there is a low cut switch on the CAD 2200. If you find a bad component, most of them are pretty cheap to replace.
Feb 13, 2013 | CAD Microphones GXL2200 Professional...
1988 mazda rx7 gxl
whats the problem
Nov 25, 2011 | 1988 Mazda RX-7
How to create network terminal system
As in like a Citrix solution for home? You can setup RDP through windows which is a remote connection to another system on your network. You can do this by clicking Start > Run then typing MSTSC and hitting okay. You can then type the name of the other computer and it should prompt you for credentials. You may need to do a bit of setup on the remote computer first, such as adding your network username and password into the remote users group (right click my computer, choose manage, local users and groups, groups
Mar 07, 2011 | Dell E200 233Mhz Thin Client Terminal...
Can I connect a CAD GXL2200SP Condenser Mic to a computer?
Technically, you can plug any microphone into a computer via an audio interface or USB(if applicable) With this mic it will require an audio interface just remember that since you are using a condenser you will need an interface that can supply phantom power. Good Luck, Cody J.
Dec 15, 2010 | CAD Microphones GXL2200 Professional...
I have a gxl 2200 mic and my computer acknowledges the mic but i cant record anything because when i play it back there is no sound
You'll need a phantom power source, like an interface or mixer. Otherwise, the mic is likely in need of repair.
Sep 19, 2010 | CAD Microphones GXL2200 Professional...
I bought a GXL2200 and i cant hear my vocals.
The GXL 2200 is a condensor microphone. It needs Phantom power to operate, and get the correct levels for recording. Your lexicon interface should have a button/switch that says +48V phantom power, or something similar. This needs to be enabled before the GXL 2200 will work.
Mar 07, 2009 | CAD Microphones GXL2200 Professional...
Gxl 2400 wiring connections
well best to just resolder it if you know the wire it should have a standard diaphragm with standard layout. should be asimple fix.
thanks,
Nate
Aug 12, 2008 | Audio Players & Recorders
Cad gxl 2400
Dec 01, 2007 | Audio Players & Recorders
Top CAD Microphones Audio Players & Recorders Experts
Ben Armstrong
Vito Vacirca Jr.
Tom Chichester
Are you a CAD Microphones Audio Player and Recorder Expert? Answer questions, earn points and help others
