Question about Frigidaire FRT8B5EQ 30" 18.2 Cu. Ft. Top Mount Refrigerator w/ 2 Clear Crispers, 2 Sliding Wire Shel...
Drain pan My manual for my frigidaire top mount refrigerator says my drain pan is non-removable and when I remove the toe kick I can't see any way to slide it out. There's a dead mouse in the drain pan, smells awful. Thank you !! Purchased in 2004. I can get my hand on the drain pan but the opening is too small to pull it out. Thanks again.
  • joycegibbons Nov 12, 2009
    Is it possible to use some kind of jack to lift the front end up so I can do it myself? My pan has chocolate syrup from a desert my daughter stored in my freezer without a cover and of course it fell over. Just finished cleaning the drip hose which was clogged but cannot, I repeat cannot, allow water to drip into that decayed slop chocolate or I'm sure I will have the smell too. I began my goal simply to see if the hose was clogged since I continually have water under my crispers - a Fridgeaire - never again!!!!
If u have 2 people u can lean the fridge back and the drain pan unscrews from the fridge from the bottom even though it says "non-removable
Posted on Jul 31, 2009
  • 958 Answers
Yup..that's how it is. no solution but to pick up the dead mouse and clean the drain pan as is, where is.
you might send someone with a small hand to reach the pan completely. rinse it with soap and water to eliminate the odor. use gloves to pick up and clean the pan.
tnx 4 using fixya,
drcool
Posted on Oct 24, 2008
My Frigidaire refrigerator has a drain pan that is un remove able and has a bad smell how can I clean.
I appreciate your inquiry, friend!
If you would like to clean any dirt or debris from the drain pain you can use a vacuum attachment to get inside and clean any residue within the drain pan. You can also use warm water and bleach to help disinfect the drain pan prior to vacuuming it out. If that does not help you may want to consult with a professional technician for additional cleaning to be completed within your Frigidaire refrigerator. Best of luck! -Matt
Oct 19, 2014 | Frigidaire Refrigerators
Where is the drip pan on Frigidaire 18 cu. Ft. Refrigerator
Hello friend, that's a great question!
Typically the drain pan is located at the bottom of your Frigidaire refrigerator. You can look it by removing the toe grille. Hopefully this is helpful. -Matt
Sep 10, 2014 | Frigidaire Refrigerators
How do I pull out tray behind toe grille to clean?
Hello Friend, this is Z. Thank you for allowing me to assist you!
The drain pan of your Frigidaire refrigerator (FRS23R4A) is not removable. Hope this helps! Should you need further assistance please feel free to reconnect.
Sep 01, 2014 | Frigidaire Refrigerators
Water leaks on floor, where isthe defrost drain pan? the manual indicates that water might build up in drain pan, the connections with the ice maker are all dry.
The drain pan is usually located closest to the floor - behind the kick space or toe space grill at the bottom of the fridge. Most often the water that collects in it is evaporated by the heat generated by the compressor and airflow from condenser fan located close to the pan.
Make sure the water is coming from the defrost drain hose - not from water sources elsewhere in the fridge (leaking water / melting ice into the fresh food compartment, etc.). If found, take action to correct.
Oct 19, 2011 | Whirlpool 21.0 cu. ft. Top Freezer...
Removing drain pan
Most Maytag unit have non-removable evaporator drain pans. And if they are removable, they are very difficult.
The model # you stated shows a part # 61004095 (est 70.00 - 95.00). Is there a issue with the pan, they usually dont need servicing. see attached
Ric
Mar 08, 2010 | Magic Chef CTF2125 Top Freezer...
Water on floor
The drain pan should be removed and cleaned at least once a year. The drain pan is located at the bottom of the refrigerator behind the front grill. Remove the grill, which snaps into place. Grasp the drain pan while pulling slightly upward and forward.
Clean the pan with warm soapy water or warm water and baking soda.
If the pan rattles when it is replaced, it is too close to the compressor. Simply reposition the tray.
If you have an ice-maker, check the water supply hose going into and coming out of the water inlet valve. The hoses may be loose here.
Nov 14, 2009 | Frigidaire FRT18G5A Top Freezer...
Kenmore refrigerator, top mount, knocks often for a few seconds, sound seems to be coming from the bottom where the water filter is. It has an ice maker but turning it off doesn't help. Changing the...
hi
see if you can listen for the compressor turning on and off as well
sometimes with this unit, when the compressor starts up, the pressure change in the condensor coil causes a vibration, makeing the coil hit the bottom of the machine until its up and running
it can be fixed easily by removing the toe kick a sliding a piece of cardboard between the coil and the bottom of the machine
you dont need much
just enbough to change the harmonic signal
Oct 17, 2009 | Kenmore 18.9 cu. ft. Top Mount...
The air vent between my freezer compartment and fresh food compartment below is frozen over and as a result, the fresh foo d compartment gets too warm. I have a Frigidaire refrigerator, model FRT8B5EWA....
you have a blockage in the drain tube, remove panel back of freezer..you will see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. the reason you see water in the fridge is because the water has been leaking down the vent instead of the drain hole...If you need any further assistance please feel free to comment again. good luck!
Jun 29, 2009 | Frigidaire FRT8B5EW 30" 18.2 Cu. Ft. Top...
How do I remove drain pan under regrigirator Frigidair, side by side, mod# FRS26HR4DWS?
The drain pan on most models is slipped in when assembled and may not be removable from your fridge unless the compressor-condenser assy is taken down too.
First find the pan by removing the back cover. Next use a good flash\light and look for a plastic pan underneath. Then look along the sides of the pan for the words lift here or some other type of direction on the pan. If none are given try lifting the pan and see if it will lift and slide towards you or not. If not then its probably made to just sit in place.
Hope this helps please rate me as high as you can and thanks for using fixya.
May 05, 2009 | Frigidaire FRS26H5AS Side by Side...
Water in refridgerator interior
You have a plugged drain in the freezer. Unplug and remove back panel in freezer. Under the evaporator there will be ice, thaw with hairdryer or steamer. There is a hole under the ice, that is the drain. Flush with hot water until it drains into outer pan. It may take awhile to get drain cleared.
Mar 20, 2009 | Frigidaire FRT21G3CW Top Freezer...
Refrigerators Logo
1,834 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
