Question about LG 24 in. LDS 5811 Built-in Dishwasher
Water leaking from door lg lds5811st dishwasher
5 Suggested Answers
omaharox
  • 166 Answers
SOURCE: LG Dishwasher LDS5811bb. Water is leaking out
The dishwasher may not be levle side to side and front to back.
Se the installation instructions or go www.lgusa.com
they may have the instructions on line.
This will cause leakage at the door.
If the leak is @ the bottom left it may be from the drying vent assembly.
The vent would need to be replaced with an updated vent assy.
Posted on Jan 17, 2010
MNTECH
  • 1543 Answers
SOURCE: ERROR CODE "LE " ON LG DISWASHER
You should check for that the pump motor turn freely. You will have to remove the sump cover in the bottom of the dishwasher and manually turn the pump impeller. (note: screw holding the impeller on the motor shaft is a left hand thread) There may be an object there or at the cutting blade a bit lower down that is preventing the motor from turning. Motor should turn easily, smoothly, and quietly. There have been issues with magnets in the motor windings cracking, resulting in hard to turn or noisy motors. Also, models produced with serial numbers 501KW_____ to 702KW_____ may have wiring which has become embedded in the door insulation material, softening the wiring insulation, and causing a short to the motor. The fix for that is to replace the wiring harness and outer door liner with one with a different type of insulation. (not much fun to do)
Posted on Aug 27, 2008
omaharox
  • 166 Answers
SOURCE: LG Dishwasher (3850DD3006A) is leaking along left
Contact LG @ 1800 243-0000 this is a known issue and they may help you out.
The drying vent needs to be updated if this is a couple years old amoung other items such as the wire harness and inner door liner..
Posted on Jan 09, 2010
  • 106 Answers
SOURCE: I have a LG Dishwasher Model LDS5811ST. The code
( Motor error ) Condition : The motor is working abnormally. Possible cause : Wiring connections. The impeller of washing pump is locked. The rotor of washing motor is locked. The blade is locked. Correct wiring connections. Replace the cause of resrtiction. Replace the washing motor. Replace the PCB.
Posted on Mar 30, 2010
How do I replace dishwasher door hinge spring?
http://www.repairclinic.com/PartDetail/b200p9/LG-Dishwasher-Hinge-Spring/4970ED4004D/1337779?modelNumber=LDS5811ST#repairHelpVideoTabs
Oct 07, 2014 | LG Dishwashers
Lg tromm washer
The DE or DOE (Door open error) error or fault code indicates that the door is not latching properly. Check the lid or door operation to be sure it's not binding and that the door alignment is correct. Also, check the door/lid hinges to be sure they're not binding. Finally, make sure the door catch is in place and not broken. You may need to replace the door hook/catch or the door lock assembly.
Aug 22, 2014 | LG 4681EA2001D Original Water Pump Drain...
Lds5811st won't drain error le
have to change control board on lds5811st water not draining on last cycle already changed pump
Nov 17, 2012 | LG Dishwashers
Did you find anything out? Mine won't drain either.
May 14, 2010 | Dishwashers
Jan 07, 2010 | LG 24 in. LDS 5811ST Stainless Steel...
We have an lg dishwasher LDS5811ST and there is an error code. LE or an or 2 capital E's with top missing off of the first E. We tried turning the breaker off for 20 minutes and there is water going into...
Kevin,
The LE error on the LG dishwasher means that the dishwasher believes there is a leak because the level of the water is decreasing between the time the wash or rinse cycle begins (with the proper amount of water) and before the cycle ends and the water is pumped out.
After you have ruled out a real leak (check closely underneath) then here is the next step. 99% of the problem with LE is caused by the drain hose not having a high point between where it connects at the dishwasher and the drain.
The fastest (but not best) way to fix this is create a loop in the drain hose raised high up underneath the counter top. Attach it so it will not fall back. The cause of the "leak" is the natural siphon effect that can develop when the drain hose has not high point. (exactly like the siphon tube you may have created in science class.)
Please report back what you find, OK?
Sep 12, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
My LG LDS5811ST has error code of IE Where do I
1-Check if the water Inlet Hose is kinked.
2-The Water Pressure is very low.
(below 10 psi)?
3-Inlet Valve is OK?
The filter of Inlet Valve is clogged
by water filter?.
The Impeller of Air Guide is bound
Jul 03, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
Washer arm not working
If your dishes are getting clean, then your problem is a "feture" not a failure. The LG LDS5811 has a Verio motor/check valve that switches between cleaning the upper dishes and then the lower. Depending on when you open the door, one arm will not be spinning.
All the presure is routed either to the lower or upper arm, so it really does help - especially with a water conserving model like the 5811.
Good Luck!
Mar 06, 2009 | LG 24 in. LDS 5811ST Stainless Steel...
LG dishwasher model lds5811st error LE
per instructions in other's posts, I removed door panel, but no wires broken, so called LG and local authorized LG repair and they tell me motor sub-assembly needs replacement, cost $160 for parts, $200 for labor, which is making a new dishwasher look attractive.
Jul 25, 2008 | LG Dishwashers
Low water level
One of 2 problems is causing this.  Either you have a bad float switch which is located on the left side of the dishwasher, or you have a water leak and is losing water when it is in the wash mode.  You will need to have it checked by a qualified LG technician.
Jul 21, 2008 | LG 24 in. LDS 5811 Built-in Dishwasher
LG 24 in. LDS 5811 Built-in Dishwasher Logo
100 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
