Question about Philips VOIP8411 IP Phone
I do not have a dialing tone and cannot make or receive calls
I was wondering if anyone out there could help me, I'm a techno phobe so you will need to make any advice idiot proof! My new VOIP8441 is set up, plugged in correctly and the displays are on in all the right ways BUt there is no dialing tone to make landline calls. Before you ask, yes, the phone jack is in!  The phone does rings and the display lights up when someone calls but the line is dead when I pick it up.
Any ideas?
Thanks,
Eleanor.
  • A Womans Computer Man
    A Womans Computer Man May 11, 2010
    hmm..i believe that the dial tone only appears after entering a number, and then pressing the green button, right?
    Master:
  • 538 Answers
Let me know if that is the case..
Posted on Oct 24, 2008
The visual ringer will not flashing.
At an educated guess sounds like dial tone is set to decadic if there are two phones the other phone will set off ringer when numbers dialed. May need to get phone provider to change dial mode in exchange line interface circuit to be Dual tone Multi Frequency Dialing and then switch phones to Tone dialing rather than pulse dialing.
Jun 01, 2015 | Lands Phones
Hello...The base of my Uniden D1384-2 does not seem to be communicating with the handsets. Handsets are fully charged and all functions work. The base unit lights work and are capable of charging the...
it might be because of interference. i think it takes all the power from your other phones cause it needs all the power from your other things plugged in to try to get rid of the problem. if this helped, good. if it didnt, sorry. the way to solve this is to probably look at the base and figure out how to open it and take a look inside.
Aug 09, 2013 | Uniden Lands Phones
Phone can receive calls but not make them.
hello i have a solution, you need to change you dialing mode on the base option, the deafult is "tone dialling", change to "pulse tone " this fix my problem on my A495 gigaset.
May 16, 2012 | Lands Phones
Driverts calls
Hi, You can use this instruction to activate and de-activate Call divert .Works on all phone
Turning Call Divert On
by Touch Tone phone
Step 1 Lift the receiver and listen for the dial tone.
Step 2 Press the Divert On button if using an Optus OneTouch phone, or dial *78 from any other touch tone phone.
Step 3 Listen for three beeps followed by a continuous tone.
Step 4 Dial the telephone number to which the calls are to be diverted.
Step 5 Listen for two short beeps, confirming the diversion.
Step 6 Replace the receiver
Turning Call Divert Off
By Touch Tone phone
Step1 Lift the receiver and listen for the dial tone
Step2 Press the Divert Off button if using an Optus OneTouch phone, or dial #78 from any other touch tone phone
Step3 Listen for two short beeps to confirm removal of the diversion
Step4 Replace the receiver.
Other Call Divert Options - Selective Calls
With selective call options, you can choose which numbers you wish to divert, accept or reject by adding these numbers to a list. You can list up to 30 numbers for each call option.
Turning On or Off Selective Call Options
Step2 Press the access code for the service you require. You will hear a prompt telling you the status of the service and how many telephone numbers you have on your list. To turn the service on/off press 3.
Access codes Dial
*63 for Selective Call Divert Dial
*68 for Selective Call Accept Dial
*60 for Selective Call Reject
Step3 For Selective Call Divert you will then hear the 'divert to' number that is currently entered. If this number is correct press 1. If it is incorrect, press 0, then re-enter the phone number you wish to have your calls diverted to. When turning this feature off dial 3 again.
Step 4 The feature is now on/off.
Step 5 Replace the receiver.
Note: You can divert calls to a local, national or mobile. However, you cannot divert calls to emergency, 0055, 1900, 008, 1800, 0050, 13, 1300 or international numbers.
Hope it helped.
Thanks for using fixya...
Jan 11, 2011 | Cell Phones
I have lost the manual for my Panasonic phone.
Here is a link to your manual
KX-TG7160E Manual
Save a copy to your computer for future reference.
Thanks for using Fixya.
Jun 15, 2009 | Panasonic KX-TGA552M Cordless Expansion...
Cannot receive calls and dial tone flashing
You have a feature active on your phone it's more than likely a call forward feature which would redirect you calls. The broken dial tone or stutter dial tone is an indicator a feature is active. Contact you system admin for the clear all feature code and the clear all call forwarding codes.
Feb 26, 2009 | Mitel 5220 IP Phone
Dial tone is active as I'm dialing, callers cannot hear me speak
Your phone is broken, the only solution is to replace it. Call Uniden Customer Service and they should be able to help you. 1-800-297-1023. ( I'm serious, there is no way you can fix this problem with out opening the base unit up and replacing a bad transistor)
Feb 24, 2009 | Uniden DECT 6.0 Cordless Telephone...
I need to retrieve my home phone messages from cell phone
Activating Call Forwarding
You can activate Call Forwarding whenever you want your calls to be sent to another phone, including a mobile phone. Once activated, all your calls will be sent to the forwarding number you request. Each time a call is forwarded, you will hear one short reminder tone on your home phone, but you will not be able to answer the call from your home number.
1. Lift your telephone's receiver and listen for a dial tone.
2. Press *7 2.
In some areas you must use 72#
Dial 1172 on rotary or pulse-dialing phones.
3. At the tone, dial the telephone number where you want your calls transferred.
You will hear the number you entered ring. When the number is answered, Call Forwarding is activated.
4. If the call is not answered or the line is busy, hang up and call the number again within two minutes.
You will hear two short tones telling you that Call Forwarding is activated.
5. Hang up the receiver.
Deactivating Call Forwarding
Turn Call Forwarding off when you want to receive calls on your home phone.
2. Press * 73.
In some areas you must use 73#
Dial 1173 on rotary or pulse-dialing phones.
3. Listen for two short tones.
Call Forwarding is now off and you will receive your calls at your home number.
Dec 01, 2008 | Uniden Cordless Phone
No dial tone
Very strange that there a no other symtoms.
Are you sure you are plugged into the LINE port of the fax machine?
Oct 18, 2008 | Brother IntelliFAX-2440c Plain Paper...
No dial tone
This is the time that love cannot help with. Buy yourself a new home phone where the massages will pile up. erase all massages on your mobile phone. It is time to buy a cell phone which will record all masseges that you've received.
Sep 23, 2008 | Siemens Gigaset S455 Cordless Phone
Philips VOIP8411 IP Phone Logo
267 people viewed this question
Top Philips Computers & Internet Experts
Computer Repairing
Computer Repairing
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
