Question about Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Sony Connections I have a Sony KDL-46X3000 Sony Blu-ray player (300) and a Sony audio system HTSS 1300. Which is the best way to connect the systems for best results? So far I have 2 HDMI leads.
  • 85 Answers
If the audio system has HDMI in/out I would think connect plaer to it first them the HDMI out from the audio set to tv
Posted on Nov 14, 2008
Can a blue ray player be input to the back panel recepticales?
You would normally connect a Blu-ray player to the TV using an HDMI cable. A digital optical audio cable connects the Blu-ray player to the home theater system.
Aug 10, 2014 | Sony DAV-HDX678WF Theater System
No Audio
cant use both hdmi and opti outs try sum setting in blue ray but u nee dto plug all blue ray dish directto samsung hdmi then 1 master digital out form tv to sterio digital i n ok tell samsung your output also
Jan 20, 2008 | Sony STR-DG510 Receiver
No Sound for Blu Ray While Cable box is on.
Check your connections and your cable, fibre optics can be brittle
Mar 11, 2014 | Bose Solo TV sound system - Black
Sony DAV-IS10 doesn't get video and sound from Samsung 3D Blu-ray Player.
change the input settings on the SONY. sometimes there are are HDMI INPUTS AND OUTPUTS on high end systems. Make sure you are in INPUT
Mar 10, 2014 | Sony DAV-IS10 System
How to plug the blu-ray into the tv
It depends on the TV inputs. You will need to provide your own cables for most connections. If your TV has an HDMI in, get an HDMI M/M cable of an appropriate length. (Use an online shop for better prices.) This will provide the best picture. (If you have a sound system with HDMI ports, you may be able to go EDBC011 HDMI out to the sound systems HDMI in. Then the sound system HDMI out to the TV HDMI in.) If the TV has a DVI port, get an HDMI to DVI cable (again M/M). For this option, you will also need to connect the audio cable (see below in the composite or component video section).
Alternatively, this Blu-ray player has component and composite video out ports. Note: composite video is limited to SD. For these, you will have to connect the audio cables (RCA l/r audio or digital audio out). The composite video cable is included with the blu-ray player when new. For these, match the colors of the jacks to the wires to make sure that you have them correctly connected. You can put the audio cables to your sound system or your TV, as appropriate for your setup. For some TVs, you may need a RCA audio to 3.5 mm cable (all male ends) or adapter (for example RCA F/F to 3.5 mm M with an RCA audio cable or 3.5 mm F to RCA M/M with a 3.5 mm audio patch cable) . This applies for units with only the PC audio in.
Make the connections with the TV and the video player off (turn off the audio system if you are including that set of wiring). Then turn on the TV and set it to the desired input (use the Input/Source button on your remote or TV). Turn on the audio system (if using one) and blu-ray player.
If you have problems, first try different cables. Try other input connections and try different devices. It's possible for either the TV or the blu-ray player input/output jacks or boards were damaged.
The manual for the EDBC011 is available here: http://www.elementelectronics.com/support_docs/edbco11/edbco11_manual.pdf .
I hope this helps.
Oct 12, 2011 | Element Electronics EDBCO11 Blu-Ray Player
Connection status cannot be confirmed the service requested was not found the server returned with the following reference code 300 on all blu ray options
I have sony bluray disc player S370 I went to set up scrolled down to resetting selected "reset to factory default settings" scrolled down and selected "system settings" and selected "start" turned off the dvd player waited about 5 seconds and turned it back on. Choose netflix, which is what I was having trouble with in the first place, and it connected. I haven't tried other internet connections through the system, however, if this is truly a sony server issue, it should correct any internet connection issue you may be having.
Sep 09, 2011 | Sony BDP-S300 Blu-Ray Disc Player
Only 1 hdmi outlet on TV . I have a high def cable box and a sony blue ray dvd player. How do I connect 2 hdmi cables fron the components to the tv?
Don't used the Blu Ray player on the tv HDMI out put hub.Used the connections for of the Blu Ray player connections by a S-Video cable for the video and the RCA component cable R,W for the connections for the audio out.The high Def.cable box will not work for high Def. this way,but the Blu Ray player will.
May 30, 2011 | Sony BRAVIA KDL-40S2400 40 in. LCD HDTV
I have bouight a samsung home theatre system that comes complete wiht a DVd player - i also have a samsung blu ray player - naturally ithought they would be compatible!! how wrong i was!! the connections...
You have several ways to do this. You can hdmi cables from the two units and plug them into your tv if it supports hdmi and run the audio out portion on the back of the tv and hook that into one of the audion inputs on the surround unit. Or you run audio directly out of the bluray using rca, digital coax, or digital optical cable. Turn the surround reciever to the corresponding input that you choose to use.
Jun 19, 2009 | Samsung HT-BD2R 7.1 Channel Blu-ray Home...
Blu ray connect to my sc-pt660
as far as hooking up your blu ray player to the sc-pt660, the only real way to utilize the surround sound (with true surround sound) is through the optical audio out. You need to connect your blu ray player through hdmi to your tv and then connect your blu ray player to your surround sound using the optical audio out/in. I, personally have the sc-pt660 hooked up through component cables so I don't waste an HDMI input on my TV. Except for cd's, there is no reason for you to use the actual dvd player part of the surround sound considering you have a blu ray player. In conclusion, hooking your blu ray player and the sc-pt660 up to get better video simply isnt possible (your blu ray player alone gives the best possible resolution, 1080p). As far as audio goes, run an optical audio cable from your blu ray player to your sc-pt660 to get true surround sound.
Mar 23, 2009 | Panasonic SC-PT660 Theater System
Sony BRAVIA KDL-40V2500 40 in. LCD HDTV Logo
167 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
