Question about Necchi 3101 Mechanical Sewing Machine
How to wind a bobbin on necchi 3205 - Necchi 3101 Mechanical Sewing Machine
SOURCE: bobbin case on my 524fb necchi has come apart
Almost all Necchi use a class 15 bobbin & bobbin case, a new case should cost around 7 to 10 dollars!
Dwayne
Posted on Mar 14, 2009
miket756
  • 2702 Answers
SOURCE: NECCHI, model 4795. Thread bunches up at bobbin.
it sounds like the thred tenshion is to loos or the timing has sliped a little and its off a bit this can also happen with wear on the gears or just a loos fixing letting the timing slip back a bit,
Posted on Nov 20, 2009
aeroseek
  • 55 Answers
SOURCE: I have inherited a Necchi 537FA. When I wind a
Its been idle for too long and needs a good service. Try and trickle some oil behind the stop motion wheel. But what it actually needs is to have the wheel removed and then apply oil to the shaft. Careful when you start again as oil will fly out from the wheel so mind your drapes and wall decor.
Posted on Dec 12, 2010
  • 8 Answers
SOURCE: how do you wind a bobbin on a necchi 537fa?
You can find instructions at this link. Print them out so you have them handy in case you need them again. :)
http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Necchi_Sewing_Machine_Threading/Necchi_536_537_threading_Diagram.htm
Posted on Aug 26, 2011
SOURCE: I have a Necchi 3205
Hi, I've got a necchi sewing machine too, not the same model as yours.
you said you were sewing denim & the machine jamed & bent the needle, it's sounds like the machine is out of time, sometime it doesn't take much to get them out of time & would have to be serviced by a repair shop with the tools needed to fix the timing.
Posted on Aug 29, 2011
My Necchi sewing machine-model #534FB will not sew.
perhaps the hand wheel clutch need tightened .
Mar 03, 2018 | Necchi Sewing Machines
My Necchi Sofia 300. When winding bobbin the needle doesn't disengage and the matching makes a dreadful grinding noise as it winds the bobbin
Try putting a small drop of oil on the the metal shaft of the bobbin winder if it is not moving freely. The grinding noise implicates the winder tire may be ground from the locked winder shaft. The needle not disengaging requires oil in the shaft bushing. On this machine it appears you would have to remove the covers to access the appropriate areas.
Dec 05, 2016 | Necchi Sewing Machines
How do I wind a bobbin?
Actually, $10 for a manual is probably a valuable investment. It will not only help you with threading & winding the bobbin but also with maintenance and care of your machine and as well as how to use your machine. Similar brand machines thread and wind the bobbin in the same manner. So, even finding a similar Necchi and the bobbin winding method should be helpful.
Necchi bobbin wind Google Search
Oct 17, 2016 | Necchi 3101 Mechanical Sewing Machine
Necchi 4825 bobbin winding problems
tell me exactly what you do when you want to rewind a bobbin. I got an old singer that will not sew but it makes a great bobbin winder for all the other machines .
May 12, 2015 | Necchi Sewing Machines
How to wind the bobbin on a 3577 necchi
here is a link for a manual, it should have the information about winding a bobbin
http://www.sewingpartsonline.com/instruction-manual-necchi-3577.aspx
Oct 05, 2013 | Sewing Machines
Necchi 3205 FA: Seized
It may not have seized there may be a very small piece of thread jammed in the raceway area, you need to take the bobbin case and the raceway out to check
Sep 25, 2013 | Necchi 3102 Mechanical Sewing Machine
Model 3205 FA not picking up bobbin thread, needle goes down but doesn't pick up bobbin thread, needle not bent, macine was working fine then all of a sudden bobbin thread stopped. Can't even pick it up to...
- check ifu are using same needle model.
- check hight of needle bar is ok
- check timming between needle bar and hook.
- check if your material is very stritch or no
- check blad point of hook is ok or no
best regards
Aug 15, 2009 | Necchi Sewing Machines
Necchi 3101 Mechanical Sewing Machine Logo
73 people viewed this question
Top Necchi Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Ellen Den Dulk
Ellen Den Dulk
Level 1 Expert
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
