Question about Car Audio & Video
How come my usb wont play in a cde-126bt
It comes up no file with other usbs or unit error
3 Suggested Answers
etirbynnor
  • 655 Answers
SOURCE: Alpine CDE-102 w/usb port: will not
Hello desoren,
The receiver may not be set to recognize MP3 files.
Press and hold "sound setup" until the unit enters setup mode. Rotate the volume knob to "play mode" and press "enter". Check that the setting is CD/MP3 (not CD/MA), or rotate the volume knob to change the setting to CD/MP3 and press enter again. Press and hold "sound setup" again until the unit exits sound setup.
If the files are still not recognized, I'd try using a different USB drive, a different computer to write the MP3's, and/or a different application to download or rip the original music content.
Hope this helps.
Posted on Sep 23, 2009
SOURCE: alpine cde-126bt bluetooth connection
Hi, same problem (v3.80), but finally conected. I would say that is related with bluetooth name length of the phone.
Try setting the phon's name to something smaller.
Jordi.
Conected with an android device, Motorola MB200 (DEXT)
Posted on Aug 08, 2011
Audiosonic dvd player
sounds like the usb CABLE is bad
not the units
have you tried a different cable
Oct 17, 2013 | Televison & Video
Pdw u1
This indicates the hard drive has errors from bad sectors to file corruption, the hardware should be tested, maybe possible to repair.
May 08, 2012 | Sony PDW-U1 XDCAM Drive Unit PDW-U1 USB...
Hp 4700 49.3066 service error
49.xx errors are mostly caused by invalid print commands, corrupt
data, or invalid operations. Basically the printer "does not understand" the print job.
- restart the printer to clear the print job from the printer's memory.
-if the error returns disconnect the network/USB cables from the unit and cycle power again.
If the error comes back without the network/USB connected perform a cold reset on the device and go the next step.
- Once the unit is at Ready reconnect the network/USB cable.
If the unit gets the 49.xx error or begins to print a job then gets the error disconnect the cables again and power cycle the printer. This time when you plug the network/USB cable in watch the control panel for any signs of the unit receiving a print job. When the printer says "Processing" press the cancel button on the printer. This should clear the "bad" print job.
I strongly recommend updating to the latest driver for the device Drivers Software . If you had an issue with a PDF file use the Post Script (PS) driver.
Good Luck
Jan 24, 2012 | HP LaserJet 4700 Printer
StarView SV211K 2-port KVM Switch: super usb box gone off error 8882 coming up...
have you downloaded the wrong files /firmware for this /download the latest file and turn your box off just when you are ready to download turn the box on at the same time this sometimes over rides and fixs itself
May 17, 2010 | StarTech.com StarView SV211K 2-port KVM...
LaserJet 4350 Printer: HP 4350 printer, 49.2F9D service error...
1st thing to do is upgrade the firmware. Go to hp.com and look for the software and drivers. Drill down to the firmware and read the instructions.
May 16, 2010 | HP LaserJet 4350 Printer
Usb(mp3 player) reads error 6 so does a burnt disc(audio files) forums descibe this as an upside down disc-doesnt make sense in terms of the usb(mp3 player)-any ideas?
probably its a read files error ..try to connect to a pc...and reformat the unit ...becareful to backup any files and give it a try ...anyway ..when those devices start to reading errors...they usually have much more damages than this ...but it worth trying .....( I understood that this is a mp3 usb device ...right??)
Nov 01, 2009 | Car Audio & Video
32-bit self-extractor module .exe file not working on USB
Self extracting exe files tend to run unzip once they start. It may be that the usb drive is getting full before it can unzip the files or it needs to run the files on c:. You are far better copying the file onto the target computer and running from there.
Oct 24, 2009 | Electronics - Others
Ipod Does not Work
THE PROBLEM THAT YOUR P.C. MIGHT BE HAVING 'VIRUSES'SO JUST SCAN IT
Sep 01, 2009 | Clarion M475 CD Player
Clarion DXZ385USB will not play from the usb input
It is not compatible. I had the same receiver and mp3 player. according to the Clarion website, an "ERROR 5" is the message for a compatibility problem. You probably got an "ERROR 2"(format problem) when you had the player plugged in and then cycled through the sources(that's how I received the error).
I have since bought an Ipod and the USB input works just fine. Clarion says the deck is MTP compatible, but it will not run a lot of MTP devices. Only Ipods and certain memory sticks. The Creative Zen Vision M is read as an MTP device when it it plugged into anything like a computer, Xbox 360, and the Clarion USB receivers. The Clarion units even attempt to read it as an MPT device, but will not play. It is not an issue with the receiver or the MP3 files. The Creative Vision M is not a compatible device, sorry.
May 29, 2009 | Clarion DXZ385USB Car CD/ MP3 Player
Car Audio & Video Logo
282 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
