Cant log on to dir 655
192.1638.0.1
How to update D-link Dir-506L firmware
Just log in and go Tools and you will find Firmware upgrade. You can download the firmware and Manual from the given link.
DIR 506L Pocket Cloud Router
Feb 25, 2014 | D-Link DIR-506L Wireless Router - IEEE...
Cant remember wep key
In order to find the wireless security page of your Dlink wireless router DIR-615 , please follow these setps
1. Open up the internet explorer in the comp in which you are online and clear the address bar and type in the number 192.168.0.1 and hit enter.
2. You will be logged into the D-Link router setup page .
3. Under the SETUP tab, in the left hand side, click on WIRELESS SETTINGS? you will find Wireless security Mode under which you can find the password for the wireless settings.
Good Luck!
Thanks in Advance!
With Regards,
Prema.
Jan 11, 2011 | D-Link DIR-615 Wireless Router
When i plug in my router the ip address changes and i cant access net
This issue is possibly due to a configuration problem
1.Log into router
2. Verify wireless router name( on the computer) >>> ( on/off)
3.Note router name you are connecting to.
4.. Check the laptop do ipconfig /all to see current IP addresses.
5. Set the laptop up in the router by WEP KEY or MAC address.
6.Note router name you are connecting to.
7. Move the laptop about 20ft away and try to log on to the internet.
This is for all routers to set up wirelessly.
Here is the link for the DIR-330 your model number did not list:
http://www.dlink.com/products/?pid=564
Jun 21, 2010 | D-Link DIR-300 Wireless Router
How do i setup my dir-300 wth a password so other people cant log in to my internet?
First connect your router to computer with ethernet cable.
Then you can access it with following link
http://192.168.1.1
or
http://192.168.0.1
type user as "admin" and password as "admin" or blank or "password"
then go to wi fi security set your WEP code it is your password to connect wi fi network.
Let me know if you need more assistanse.
Thanks
Sep 26, 2009 | D-Link DIR-300 Wireless Router
I have activated the nat mode of my dlink dir-300 now i cant open the log in page by entering the ip 192.168.0.1
check the IP of your computer by going to dos: Run -> CMS -> then type IPCONFIG. If your IP address is not in the 192.168.0.X range then you will not be able to access it. You may have the IP assigned by the ISP or you may have to renew the ip address by restarting your computer. You can use another computer see if gets the 192... range or assign an IP belonging to that range manually.
Jul 30, 2009 | D-Link DIR-300 Wireless Router
D-Link DIR-635. Where can I find the "Web access Log"?
log on to your router > click on status> in left pane click on logs. Older logs are deleted when memory full.
If running the SYSlog utility you can save to a folder on your computer. You name the folder.
Link to manual:
ftp://ftp.dlink.co.uk/dir_products/dir-635/DIR-635_manual_10.pdf
Oct 08, 2008 | D-Link / RangeBooster N 650 / DIR-635 /...
How to install D-link DIR 300 for MACBOOK
You shouldn't need to install anything off the CD. Simply plug your Macbook into the DIR-300 via ethernet (making sure you manually set your Macbook's IP to 192.168.0.x (where x is anything from 2-254). Then open up your web browser and type 192.168.0.1 into the address bar. This will log you into the DIR-300 (I think the default login is "admin" with no password).
Refer to the manual for the configuration for the rest of your setup.
Jul 20, 2008 | Computers & Internet
Computers & Internet Logo
89 people viewed this question
David Payne
David Payne
