Question about NEC SuperScript 860 Laser Printer
Paper does not come all the way through the printer
When I print a page the paper gets stuck when the paper is about half way out of the printer. If I pull on the paper it comes out and the page is properly printed. If the document is more than one page long and I pull on each page as it gets stuck all the pages are properly printed. However, if I do not manually pull the sheets as they come out the next page gets stuck. This is an old printer and probably not worth the cost of a professional repair but I would like to have it working properly again. Is there a fix for a ten thumbed dunce can attempt?
  • joepeters Apr 30, 2008
    Yes, I have the same problem
This is more of a workaround than a fix: I open up the front door and use the Face-Down Tray to collect all my printouts.
Posted on Nov 11, 2007
When printing documents no matter how few or how many pages, paper gets stuck in the middle of printing.
Try using regular paper on unit as specified by Samsung. If that does not resolve the issue then the hassle lies with the paper feed mechanism. Often a good cleaning of all the rollers in the path can take care of the issue.
Aug 24, 2015 | Samsung ML 2525 BW laser Printer
Lexmark X4550 all-in-one Paper feeds only half way then jams
Frances;
I'm not Lexmark certified; however, paper motion fails are generic in nature. Paper motion fail can be a bit difficult to diagnose at a distance...
* If it jams at every sheet then check to insure there is not a bit-o-paper stuck from a previous jam.
* If it has been an issue that has been increasingly getting worse than I'd replace the pick-up roller(s)
* Lexmark's support page for your printer is below. (You can also find a service prover too)
* Parts order for your printer is also below. You can determine at the support page if your comfortable replacing pick-up rollers in that model printer.
support lexmark com Service Parts
Note:
* Frequently people tear a jammed sheet when it comes out leaving pieces behind. BAD! When you get a torn sheet in your printer insure you retrieve all the pieces. Those left behind guarantee a jam on your next try.
* Paper jams not caused by debris in the path or worn pick-up roller(s) is beyond user maintenance.
Mar 03, 2015 | Lexmark X4550 Wireless All-in-One Photo...
I am printing several pages and there is a jam. I
It will re-print it after you clear the jam. Just pull it out pulling slowly and evenly and it will come out.Also you can see directions on HP.com. Steven 818-888-0006
Mar 06, 2010 | HP LaserJet 3055 All-In-One Printer
I printed out more than i wanted to, a page is stuck half printed
You will need to remove the jammed page. If you can see it coming out of the printer, gentley pull it out. If not you will need to open the service cover, see you your manual, and remove it that way.
Please take a moment to rate my solution.
Thanks.
Simon.
Rytech Computer Services Limited
Nov 29, 2009 | Brother HL 2140 Laser Printer
Paper Jam Toshiba 250
  1. Turn off the printer.
  2. Inspect the location or tray the printed paper ejects to. If the stuck paper is visible manually remove it.*
  3. Remove all paper trays and any paper that may be stuck between the tray and the printer. If the stuck paper is visible manually remove it.*
  4. Open the printer door that allows you access to the printer ink cartridges or toner and look for any stuck paper. If the stuck paper is visible manually remove it.*
  5. Turn the printer back on. If you continue to receive a printer jam error try repeating the above steps again. If issue still persist and you see no paper that is stuck in the printer it's likely your printer is experiencing another hardware issue and i suggest contacting theprinter manufacturerfor additional assistance and/or repair.
Thanks! mannu_rakesh
Aug 31, 2009 | Office Equipment & Supplies
IBM InfoPrint 1612 Repeatedly erroring - Paper Jam
Check the FUSER, I think your exit sensor is bad.
If you open the rear door, look inside where the paper starts to come out of the printer, you should see a small lever that triggers the PAPER EXIT sensor. It might be hard to see. If it is not broken, you need a new FUSER.
Mar 18, 2009 | IBM Infoprint 1612 Laser Printer
Epson Stylus CX8400 Paper Jam Error
I have the same exact problem of paper half torn removed but I can not see the other half anywhere. The printer has hardly worked for at the most six pages and now showing paper jam error. How do I fix it?
Dec 22, 2007 | Epson Stylus Photo R1800 InkJet Printer
Paper jam - a special one
A gear in the Service tray section Coould be broken. wiht out this gear, the service tray woudnt function, andmost of these printers behave erraticatly when the service trsy sctions dont do its job. When the cartridge moves to the right, it supposed to activate a few gears that works together.
May 21, 2006 | HP PSC 1315 All-In-One InkJet Printer
NEC SuperScript 860 Laser Printer Logo
338 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
