Question about KitchenAid Refrigerators
I have a Kitchen Aid refrigerator model KTRS20K which stopped working (everything felt warm and freezer not working ). I replaced the defrost timer, it didn't quite match but was told it was a re
Do you think an exact replacement of defrost timer is necessary ? I think the compressor and starting device are OK, because it will cool when timer is turned by hand.The replacement timer used is Whirlpool 482493.It came with a "Timer loose motor lead" and several options to use one is "Cumulative compressor run application"or continuous run application, by trying both it will work for a short time then become warm again, hope this helps, signed "Frustrated"
  • 9 more comments
  • John Tripp
    John Tripp Feb 13, 2012
    Tell me if this began when you changed the defrost timer. I need to know if the compressor is trying to run, JT
  • John Tripp
    To answer your question about defrost timer the 482493 is the correctKTRS20K replacement for the KTRS20K KitchenAid Refrigerator. Things that will make your model stop cooling are compressor start components.http://www.pcappliancerepair.com/part-de...
    Replacement start relay with overloadhttp://www.repairclinic.com/PartDetail/R...
  • John Tripp
    Evaporator and condenser fan, along with defective thermostat are possibly some other choices for not cooling, JT
  • Jorge Feb 15, 2012
    John, thanks for responding to my problem, my wife said if it doesn't get fixed soon I'll be sleeping in the garage !!. You mentioned both fans, evaporator and compressor fans seem to be running OK. You also asked if "This happened when defrost timer was replaced " If I understand your question, refrigerator stopped working, then I replaced the defrost timer. you mentioned about thermostat, where is it located and how do you test it? Also how can I test the compressor start components? I'm still confused about replacement defrost timer and extra lead that has to be set for correct option. When turning knob on bottom of timer frig will work for awhile then won't cycle back (start cooling) thanks again for your help.
  • John Tripp
    John Tripp Feb 15, 2012
    OK I don't want you to be put out in a cold garage so let me see if I can help you get her refrigerator going. Here is a parts manual in PDF format=>http://appliancepartssoutheast.com/KTRS2...
    Here is a link to Adobe if you don't already have the new Adobe Reader=> http://www.adobe.com/products/acrobat/re...
    You mentioned a wire that you may not have hooked up on the defrost timer. One wire powers the timer and if slipped over the wrong leg of the defrost timer will cause the timer to stop along with compressor. That may be what is happening so look that over and I will try to locate a wiring diagram if we need one. Let me know if you happen to find what is causing the compressor to stop cooling and I will be looking to hear back from you, Thanks John Tripp
  • John Tripp
    John Tripp Feb 16, 2012
    How To Test the Temperature Control can be found here=>http://www.acmehowto.com/howto/appliance...
    and on this page=>http://www.acmehowto.com/howto/appliance...
    Let me know if you are having mor problems, Thanks JT
  • Jorge Feb 16, 2012
    Hi john, thanks for the material. I have the paperwork that came with the new timer. My old timer did not have any leads coming out of it, it just pushed in the connector. I also have the schematics that were behind front grill. The timer instructions have 2 settings, one for 12 hr or 24 hr continuous run. I dont know what application I had before because old timer didn't have black lead. I have tried both settings and frig only cools for a short time, after changing black lead I turn wheel at bottom of timer to get ot going but stops after a short time. Thanks
  • John Tripp
    OK if not the timer I need you to feel top of compressor to confirm that compressor is running. If compressor stops running feeling top of compressor should be too hot to hold hand there. If compressor runs and does not get hot when freezer and fresh food section warm would indicate a Freon Leak. At this point how you set defrost timer is not important because you either have a start/run component defective or Freon leak. Feel compressor and tell me what you find, Thanks JT
  • John Tripp
    John Tripp Feb 17, 2012
    We seem to be running out of room here for comments so I offer my email address appliancepartsse@yahoo.com If you are here locally in the USA I can call you and maybe offer some advice that may be helpful. Just copy your post link above in your email or just copy this=>http://www.fixya.com/support/t11661277-k...
    so I will know who you are. I have a feeling that the problem you are having is not related to the defrost timer. So if you do not mind emailing me I will do what I can to help you find the answer you need.Basically the last post requires that you pull your refrigerator away from wall, remove the lower panel covering the compressor and let me know if feeling top of the compressor is too hot to keep hand on top of compressor. Thanks JT
  • Jorge Mar 03, 2012
    Hi John, very sorry that I didn't get back to you sooner. Fortunately for me I'm still sleeping indoors ! Today I puled the refrigerator away from wall, then touched the compressor, it felt warm but no hot to the touch. 24 hrs ago I turned it on because it wasn't running before, in a couple of hrs it worked, both freezer and frig, next morning it was still cold, but that evening it got warm. When I was looking at the compressor I removed the start relay to see if I could test it but I think i's sold state. I went on line and found out it's a Maytag AP 3156242. I think I fried the relay because I shook it sounded like loose parts were inside then reinstalled it. I put the clip that holds the cover back, but without the cover I just slipped it over the relay making sure it didn't touch anything. When I connected the power cord back it arched and started to smell like burned plastic. I know that the relay is gone but do you think it's worth replacing ? Do you know where I could buy one that is not expensive? Thanks for your help ( My wife is probably considering divorce)
  • John Tripp
    John Tripp Mar 03, 2012
    You still hammering away on your Kitchenaid? If the start relay has shorted you will have no choice but to try to see if that was the problem all along. If you felt top of compressor while ruining and warm then when it stops and will not restart top of compressor will become too hot to keep hand there. Reason the compressor must run to remove heat even from itself. Your best bet is to replace the components with something called Supco URSC10 1/12 TO 1/2 HP 115 The link below takes you to a PDF and you will need to scroll to page 6http://www.supco.com/images/09%20relay%2...
    To answer your question Is It Worth It? Yes if you understand how to test your compressor like described near bottom of page belowhttp://appliance911seabreeze.com/
    Call me if you run into problems and I will walk you through this. First email me appliancepartsse@yahoo.com If you don't feel comfortable then I would buy another refrigerator, Thanks Sea Breeze
  • KitchenAid Master
  • 4,654 Answers
That does not sound like a defrost timer problem. Sounds like a condenser or evaporator fan is beginning to fail. They don't always stop when they fail. Many will slow down and stop while you are not looking causing the refrigerator to stop cooling for a while. Let me know if you have any questions, Thanks Sea Breeze
Posted on Feb 13, 2012
My Kitchen Aid Superba refrigerator Model # KSRS25FGWH01 stopped working. no fans come on no noise only fridge lights. working the other day but fridge was not cold enough freezer was fine now nothing
The machine goes into the defrost mode every day or two. During defrost mode you will see these symptoms. After an hour or two, it should return to normal. If not, the defrost timer may be stuck in the defrost position.
Mar 05, 2017 | Refrigerators
Our fridge, SIDE BY SIDE BUILT-IN REFRIGERATOR-kitchen aid KSRT25CRWH01 freezer is working but not refrigerator, How do fix it
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Dec 16, 2009 | Kitchen Appliances - Others
Area around freezer opening on a PDS20S GE
This is uaually caused by the condenser fan next to the compressor not running. Remove the cardboard backing to see it, give it a spin if it's not running. Even if it starts running with a spin you'll need to replace it.
Or If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too. check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Aug 30, 2009 | GE PDS20MBS Bottom Freezer Refrigerator
The refrigerator part stop getting cold, but freezer part is still working, what do i need to do
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Aug 30, 2009 | Kenmore 57029 Side by Side Refrigerator
I have a GE Model #GSL25JFPABS fridge. My freezer has been frosting up for quite some time with the ice cubes melting a bit and freezing together. Recently the fridge side has also been warming once in a...
Is the freezer cold enough? Should be close to 10 degrees.
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it’s frozen. If there is ice, lift the cut off arm and let it drop to see if it will start.
If it does dump the ice but don’t refill with water.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
Aug 29, 2009 | GE GSL25JFPBS Side by Side Refrigerator
EVERYTHING WORKS FOR ABOUT A MONTH AND THEN THE FREEZER HAS A BLOCK OF ICE ANT THE BACK AND THE BOTTOM BECOMES WARM
Aug 27, 2009 | Frigidaire FRT21H8 Top Freezer...
Kenmore 52532101 side by side freezer and refrigerator not cooling - any suggestions? Doesn't appear to be frozen up.
Is the compressor motor running.If no check starter/overload relay.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
How to check stuff>
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
Aug 25, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Motor is running but both refrigerator and freezer are not cooling
How to check stuff>
If the evaporator coils behind the back panel of the freezer are icing up(totally blocked) because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
Aug 22, 2009 | Jenn-Air Refrigerators
Ksrs25ikss01 kitchen aid fridge portion not
1.check if the fan inside the freezer is running
2. if ref runs none stop, defrost timer is out.
3. or it could be the high limit that paired in series with the defrost heater
good luck!
Jun 25, 2009 | KitchenAid Superba Architect KSCS25INSS...
Top half fridge not cold freezer department fine
I had the same problem; the top fridge compartment was warming up to 14C while the freezer compartment was starting to defrost (frozen stuff was starting to become soft. I took the rear wall off the freezer compartment and found it all iced up. I defrosted it with a blower heater then powered it back up. It all worked fine for a month when the same thing happened. I figured that the defrost cycle wasn't working. I located the defrost timer on the rear right-side of the fridge. I rotated it several times and found that the fridge was turning on and off. I rotated it until the fridge turned off. I waited 5 minutes then stuck my head into the freezer compartment and felt the rear wall at the bottom where he drain is; it felt warm so I guessed the defrost heater element was ok. I ordered a defrost timer and installed it. I haven't had a problem since.
Nov 09, 2008 | Westinghouse Refrigerators
Refrigerators Logo
331 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
