Question about Westinghouse Refrigerators
Year manufacture westinghouse freezer model fj383 k.-l
Manufacture date
My Westinghouse Freestyle Freezer FJ383 wobbles on the floor. How do I fix?
There are feet on each coner that can be turned to make them go up or down. you may need a person to slightly lift or tilt the unit and a pair of strong pliers to get the feet turning.
Jul 14, 2016 | Westinghouse Refrigerators
Can you tell me the model of my 270 winchester rifle serial number is G1871685
This is more specific to decoding your serial number as the other information I gave was on your Model 70.
[PDF]Winchester Firearms Manufacturing Dates By www.winchesterguns.com/.../winchester.../serial-number.../Winchester-M...
  1. Cached
Winchester Firearms Manufacturing Dates by Serial Number and Year. 1866 through the early 1990s. The following pages were scanned from documents ...
What year was my Winchester manufactured? (Serial ...
www.winchesterguns.com/support/faq/date-your-firearm.html
  1. Cached
  2. Similar
Winchester Firearms Manufacturing Dates by Serial Number and Year. 1866 through the early 1990s. Below is the download link for a special resource for ...
Model 1894 (Mod 94) - Winchester Dates of Manufacture
oldguns.net/sn_php/windateslookup.php?file=win1894.dat
  1. Cached
  2. Similar
Winchester Model 1894 (Mod 94): Covering numbers: 1 - 5103249. Please enter a serial number and click the submit button.
Dates ' Winchester Collector
winchestercollector.org/dates/
  1. Cached
  2. Similar
When was Your Winchester Made? ... Serial Number ... the dates of manufacture shown were obtained from the original Winchester Factory Polishing Room ...
Winchester Serial Numbers - ProofHouse.com
www.proofhouse.com/win/index.html
  1. Cached
  2. Similar
Main Page. Lever Action Rifles Slide Action Rifles Bolt Action Rifles Semi-Auto Rifles Shotguns Military Misc. Lever Action Rifles top. Walter Hunt's Repeater
Winchester Dates - ProofHouse.com
www.proofhouse.com/win/winchester.htm
  1. Cached
Serial numbers of the Henry rifle overlap those of the model 1866 from 1865 to 1866. .... George Watrous, a Winchester employee, counted total production at ...
Serial Number info for Winchester Model 94 - The Firing Line Forums
https://thefiringline.com/forums/showthread.php?t=322230
  1. Cached
  2. Similar
Nov 27, 2008 - 25 posts - ‎17 authors Is there a place on line to research and find dates and serial numbers on The Winchester Model 94 30 30 ? ccookin is offline ...
Winchester Model 1894/94 Dates of Manufacture
www.savage99.com/winchester1894_dates.htm
  1. Cached
  2. Similar
Our database contains values of serial numbers through 5103248 which ended the year 1982. Our sources disagree a bit, but this seems to be the best set of ...
Date Your Model 70 and 94 - RifleShooter
www.rifleshootermag.com/rifles/featured_rifles_rs_model70wo_200803/
  1. Cached
  2. Similar
Nov 3, 2010 - We bought a Winchester model 70 with serial number G1741812. ... Kurt. Where can I find manufacture dates for Winchester Model 1894 rifles?
Winchester Model 1894/94 Factory Records - Shooters Forum
https://www.shootersforum.com/winchester.../67350-winchester-model-1...
  1. Cached
  2. Similar
Aug 12, 2010 - 7 posts It should now very clearly show the progression of verified dates of manufacture. I do not plan to add any additional new serial numbers to the ...
  1. Cached
  1. Cached
  2. Similar
  1. Cached
  2. Similar
  1. Cached
  2. Similar
  1. Cached
  2. Similar
  1. Cached
  1. Cached
  2. Similar
  1. Cached
  2. Similar
  1. Cached
  2. Similar
  1. Cached
  2. Similar
May 01, 2016 | Optics
What year was this model made?
Your unit (B3BV-036K-BB) is a Westinghouse / Nordyne Unit.
Vertical Flow only, 36,000 BTU, 208/230 volts.
You cannot tell the manufacture date from a model number, only from the serial number. Try contacting manufacture with the serial number...
(nordyne.com)
Sep 13, 2014 | Frigidaire Heating & Cooling
Westinghouse fj383
ne of the most common reasons for the freezer to start failing is called "frost free failure." Ice can build up on the evaporator coils over time, and this ice builds up until it starts blocking the fan. The fan is responsible for circulating cold air throughout the freezer, so if it is blocked the freezer will not be able to freeze any food. You can usually check this by removing an access panel in the back of the freezer to inspect the coils. If ice is built up on the coils, a hairdryer can assist in defrosting them
Dec 10, 2013 | Freezers
I have a fj383 Westinghouse freezer it isn't freezing the food My email is charmaine@hispeedgas.com.au
If you have ice on back wall of freezer compartment the self defrosting mechanism of unit is not working. check the defrost timer and defrost heating element for peoper operation.
Nov 24, 2013 | Refrigerators
Trying to figure out the year on a bike i might purchase and what model it is
Most motorcycles, including Yamaha, have a model tag on the steering head portion of the frame under the handle bars. It will include the year as well, or the date of manufacture. If the date of manufacture was in the fall of the year, the model year will be the year after the date on the tag. For example, if the date of manufacture was 11/2005, it would be a 2006 model. If the tag is missing, the VIN number is stamped into the frame in that area as well. Write it down and call the dealer parts counter they should be able to give you year make and model from the number. Good luck!
Jun 13, 2011 | Yamaha Renegade 200 Motorcycles
My Westinghouse LCM 22w2 (1 year old) has developed a green line running top to bottom of the screen. I cannot get rid of it. I've tried turning the monitor off, changing inputs, reseting - but it's...
Unfortunately that is a failure in the display electronics and is repairable only by replacing the display panel. I don't know what the warranty period is for this model, but check your purchase date and the warranty information. If the thing is just recently out of warranty maybe the manufacturer will work with you on a solution. Or you can contact them anyway and ask. Sometimes if you complain loud enough it works wonders.
Dec 06, 2008 | Westinghouse LCM-22w2 Television
My westinghouse freestyle freezer model number FJ3830-L*13 stops working now and then. On the back down the bottom left corner is a box. On this box is a small dial I turned this 1 click and the freezer...
hi i have a fj383, red light comes on and the fan doesnt circulate the cold air, only the bottom half stays cold, have tested the fan and does work, have put a new defrost timer in but no different, what activates the fan ? is it the timer or the t/stat or the element, hope you can help, thanks wayne.
Mar 15, 2008 | Refrigerators
Westinghouse fj383
I have a Westinghouse upright freezer FJ383M-R. The red light was on bright and the top half of freezer was not working. Turns out it was a switch that turns the defrost cycle on was faulty. Serveman replaced borken part. Now it is fine. Was much cheaper than replacing freezer.
Nov 28, 2007 | Westinghouse WRS3R3EW 33" 22.6 Cu. Ft....
Refrigerators Logo
42 people viewed this question
Top Westinghouse Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
christian nielsen
Are you a Westinghouse Refrigerator Expert? Answer questions, earn points and help others
