Question about Vivitar DVR 530 Flash Media Camcorder
Memory card i insert memory card into camera and it wont turn on. then it turns on without memory card inserted. then i insert the memory card and it doesnt show up in camera.
  • Anonymous Oct 29, 2008
    yh i have the 540 version and sometimes reads the card and sometimes nt
  • 849 Answers
Memory card is bad, repalce it
Posted on Oct 24, 2008
When i turn on my camera it says Meomory card unusable insert new memory card
Try formating the memory card using the camera's Menu - select format memory card.
Feb 27, 2013 | Kodak EasyShare Z710 Digital Camera
Camera wont switch on praktica dcz 8 lm busy light comes on 3 seconds then off and nothing after that
took the memory card out and then turn on the camera. Now see the busy keep coming or its gone. If not showing busy any more then format the memory card and then try to turn on the camera with inserting the memory card. Thanks.
May 23, 2012 | Praktica SlimPix Digital Camera
I just got my Nikon D3100 and it wont turn on..why?? i didnt buy a memory card yet..doest it need memory card to turn on??
The battery ships in an uncharged state. Slip the battery into the charger until the it indicates it is fully charged. Install into the camera. The camera should power up without an SD/SDHC/SDXC type memory card installed - and should flash [-E-] in the viewfinder alerting you to the fact that no memory card is inserted.
Sep 06, 2011 | Nikon D3100 Digital Camera
Check to make sure the batteries are inserted correctly.
Clean the battery terminals with a dry cotton swab that has a fine and soft tip, and then re-insert the batteries.If the [Memory Card / Battery Cover] is not securely closed, the power of the camera may not turn on.Close the [Memory Card / Battery Cover] securely, and then turn the power on.
If your camera still does not work even after you have performed the above procedures, your camera may be malfunctioning. Please have the camera serviced in this case.
Apr 19, 2011 | Canon PowerShot A460 Digital Camera
When I turn my camera on it says internal memory is full and it really does not let me do anything. Oh this is a EasyShare C 813 What can I do and I pray I have not lost my pictures.
Have you insert a memory card in it ? If we don't insert the memory card, pictures that have been taken will automatically saved in camera internal memory, and this memory usually have low capacity so we won't make many pictures because the memory will full in no time. The solution is insert proper memory card (kind and capacity).
If you have insert the memory card the camera shows that notification, it means you need to transfer your pictures data in PC so you can delete them and make more space in your camera memory card.
Hope this help and RATE please !
Jan 17, 2011 | Cameras
The camera works fine without a card in, but when the memory card is put in it doesnt. i changed the card and no difference. PLEEASE HELP
The cause and solution may include one of the following:
  1. The card may not be certified SD. Please purchase a certified SD memory card. For example: Sandisk, Toshiba, Panasonic, etc.
  2. The card may be corrupt. Reformat the memory card.
    CAUTION: Formatting deletes all pictures and videos, including those that are protected. Removing a card during formatting may damage the card.
  3. The card is not fully inserted in the camera. Turn off the camera, insert a card into the slot, then push to seat it.
Feb 13, 2010 | Casio Exilim EX-S500 Digital Camera
When i insert an sd card the vtech kidizoom camera wont turn on at all.
I am not a tech wiz but have just managed to put the card in my daughters camera! Normal SD card tight fit,it looks like it needs to go all the way in but doesnt. Either you have it in wrong or wrong card? Metal bits down! When I turned it on you then have to go to the tools sign to switch to memory card .Hope this helps.
Jul 25, 2009 | Vtech Kidizoom Digital Camera
It wont turn on
Check the memory card try to turn on the camera without the memory card if that works problem with the memory card if that doesnt work...... Try using a diffrent set of batteries...... Still doesnt work...... Get the camera replaced..... Good Luck....
Jan 19, 2009 | Nikon Coolpix L11 Digital Camera
Memory card not read
try inserting card after camera powered up...same result?
May 29, 2007 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Camera wont work when memory card is inserted
I suggest you try to use a different memory card. If it doesn't happen again then it's probably a bad memory card.
Mar 06, 2007 | HP Photosmart M417 Digital Camera
Vivitar DVR 530 Flash Media Camcorder Logo
114 people viewed this question
Top Vivitar Video Cameras Experts
Lawrence Oravetz
abdul rauf
abdul rauf
Are you a Vivitar Video Camera Expert? Answer questions, earn points and help others
