Question about HP StorageWorks MSL 6000 (AD612A) Ultrium Tape Drive
Msl6000 error Error ? Fault Code: 3032 (Soft) Chasis S/n ? Character count is not correct
I've another fisher and paykel washing machine GM512. It has fault error of 1 and 7. How do I fix it?
What side are you counting from? Each light has a different value for the error code. Counting left to right will give a different error code than counting from right to left.
Jul 31, 2016 | Fisher and Paykel Washing Machines
Xerox phaser 8500 error code 09, 038, 46:4597
Ink count sensor flags are stuck after melting 2.5 ink sticks. The following codes are recorded: 9,03x.41, where x= 5 for cyan, 6 for magenta, 7 for yellow, and 8 for black. (Your error indicates black ink loader failure)
Features on the bottom of genuine Xerox ink sticks actuate the Ink Out Sensor located at the forward end of each ink channel of the Ink Loader. The sensor indicates the passage of ink to provide a count of ink consumption.
Damaged or non-genuine ink sticks may not reliably actuate the sensors. This can lead to false Ink Out messages as well as Ink Stick count faults. Using 8400 model ink in a 8500/8550/8560 models will also cause 9,03x.4x ink stick count faults.
Ink Loader will need replaced and then diagnostics entered to run "Clear ISC Fault" test to clear the error.
IIf
Aug 11, 2013 | Xerox Phaser 8500/DN Printer
Riso 7050R with error code S99-3032-1
according to the troubleshooting guide
Examples of Error Messages
The following are examples of error messages.
<S00-000>
Service Calls
These error messages are displayed when inspection or repair is required by a service representative.
Nov 28, 2011 | Office Equipment & Supplies
Spectralink PTB400 internal error
Correcting Spectralink Errors Below are instructions on performing a “soft test” which will correct any internal error 8 and 4444-444C messages on your Spectralink phone. To aid you in educating your staff you may view the following Word document showing the step-by-step instructions. Please feel free to print and post this document where the Spectralink phones are kept on your floor. Soft Test Instructions
  1. Power off the phone.
  2. Press and HOLD the volume key (VOL) and the power key at the same time (the phone will chirp and display the serial number.)
  3. Now…release ONLY the power key (phone will vibrate and make a long tone.)
  4. Now release the volume key (the display will have a lot of black boxes and ZZZZ’s – you will also see the bottom of the display showing “msg”, “bat”, etc.)
  5. Count to three and then power off the phone.
This “soft test” is to correct only certain internal error messages. When the phone is experiencing a correctable error the display will read “internal error 8” or “internal error 4444-444C”. For all other internal errors the phone will need to be taken to Teleservices, NE-165 to be replaced.
As per : http://depts.washington.edu/uwmcdir/spectralink.html
Mar 16, 2010 | Spectralink (PTB400)
Receiving error code 6A00, and alarm light is
That error says the purge unit is broken. You will need to have the purge assembly replaced.
It's # QM2-3032-000 but a shop should replace it for you.
Dec 04, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Canon pixma mp800 error code 6A00
6A00 means you need a new purge assembly. That's the unit that cleans the printhead. Part number is QM2-3032-000 around $30.00 but a shop should install it.
Jul 24, 2009 | Canon PIXMA MP830 All-In-One InkJet...
As soon I turn on it shows internal error 8 & 4444-444c
http://depts.washington.edu/uwmcdir/spectralink.html Correcting Spectralink Errors Below are instructions on performing a “soft test” which will correct any internal error 8 and 4444-444C messages on your Spectralink phone. To aid you in educating your staff you may view the following Word document showing the step-by-step instructions. Please feel free to print and post this document where the Spectralink phones are kept on your floor. Soft Test Instructions
May 16, 2009 | Spectralink (PTB400)
XEROX 8550 DP ERROR
when are you getting this error message?
Oct 28, 2008 | Xerox Phaser 8550DX Laser Printer
Error code 09,038,46:21303
When you service a Phaser 8500 or 8550 printer for:
· a persistent Ink Out message
· 9,035.43 Cyan Ink Stick Count Fault
· 9,036.44 Magenta Ink Stick Count Fault
· 9,037.45 Yellow Ink Stick Count Fault
· 9,038.46 Black Ink Stick Count Fault
Test the Ink Out Sensors for proper operation.
Inspect the Ink Sticks.
Apr 09, 2008 | Xerox Phaser 8500/DN Printer
Error: 09,035.43:27650
You have a Cyan ( blue) ink stick stuck or a broken ink stick in the ink loader.
Check the cyan slot carefully, one of the sticks has not moved properly, The machine is not seeing the ink loader moving indicating a stuck cyan stick, Here is the info.
Ink stick count faults (error code 09,03x.4x) are declared when the printer melts 2.5 ink sticks without tripping the color's ink out flag. The ink out flag is used to physically count ink sticks passing thru the ink loader.
Verify that the ink sticks are Xerox 8500/8550 ink sticks. Manually verify that the ink stick are correctly loaded and are able to advance in the ink loader chute. Check for broken ink sticks which can fool the ink out (ink stick counting) sensor.
The ink stick count fault can only be cleared by powering up the printer in internal diagnostics mode. Then scroll and to the Functional menu item Clear ICS Fault.
Dec 19, 2007 | Xerox Phaser 8500/DN Printer
Computers & Internet Logo
943 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
