Question about Gateway GT5654 Desktop PC
Just beeping when turn computer on it beeps continuely screen says no signal rgb
  • 3 more comments
  • shesez2luv Oct 26, 2008
    hi, thank you for ur response,
    my children were playing a game on disc when computer froze up they could not close anything out out so they manually turned the computer off by holding the power button, when tried to turn computer back on it just beeps continually will not load anything up and the monitor says gateway like its going to load up then it says no signal rgb, monitor goes out to standby mode and nothing happens just continue to beep with a blck screen this is a new computer
  • Anonymous Nov 16, 2008
    I have the same problem, just
  • phmat2 Dec 03, 2008
    I think there is something before that issue happened, maybe what can you help me to resolve the issue, because I doing some assumes such as processor/display card but I dont know if I am right
  • jesika_crost Apr 06, 2009
    turn computer on. one beep continunuiius beeps. screen wont load up. it lets u load sometimes then shuts down . goes black
  • A Womans Computer Man
    A Womans Computer Man May 11, 2010
    that suggests that the video card is unhappy..perhaps re seating the memory will help
  • 189 Answers
Have you done something on your computer before that happen? Maybe change your display resolution? or video card?
Posted on Oct 24, 2008
  • Alan Brenneman
    Alan Brenneman Oct 27, 2012
    removed memory and reinstalled
When i power on the cpu it become a 5 beeping and nothing going on and the monitor says no signal with black screen
Posted on Dec 03, 2008
Emachines won't send signal to screen, when turned on it makes one long continuous beep
The beep signifies an error. But different bioses have different beeps. You can check with the emachine site to tell you what 1 beep on the machine signifies and you can be guided accordingly. Could be bad power supply, connection, peripheral, etc
Sep 01, 2017 | E-Machines eMachines Desktop PC
No signal on monitor, vga tested and ok
Did you check your monitor with other system or individually. If it works fine in these conditions then the issue belongs to your pc.
First of all, you have to confirm that is it the problem of VGA itself or the motherboard. For this, you have to see that does system beep when you start it because system with beeps having the error and the beep sound with continuous or 2-3 beeps relate with different issues. I am going to write down the beep conditions.
1 short beep Normal POST - system is ok 2 short beeps POST Error - error code shown on screen No beep Power supply or system board problem Continuous beep Power supply, system board, or keyboard problem Repeating short beeps Power supply or system board problem 1 long, 1 short beep System board problem 1 long, 2 short beeps Display adapter problem (MDA, CGA) 1 long, 3 short beeps Enhanced Graphics Adapter (EGA) 3 long beeps 3270 keyboard card
Mar 11, 2012 | Computers & Internet
It is not showing the post screen and beeping a long and continuous beep
a long beep is identicated your vga has trouble, but maybe it caused by ram error, first turn off your computer, open computer case, disconnect your ram and connect again, turn on computer, is the computer still beeping??if yes it mean the problem come from your vga card, do not use onboard VGA port, just insert PCI or AGP VGA card, your computer will work properly
i hope this helpful
thank you for using fixya
Feb 04, 2011 | Foxconn (945G7MA-8KS2) Motherboard
I turn on my computer and i cant see any thing on the monitor my monitor says no signal
Thanks for the response, I opened it and the processor is burnt, one corner of it. Was a lot dust in there maybe that caused it? Anyway I found a new one on EBay for 30 bucks, the board looks fine so that should work huh?
Sep 21, 2010 | HP Compaq Presario SR2013WM (RE468AA#ABA)...
My gateway gt5404 says no rgb signal what do I do
With 3 beeps, you are getting a Memory base read/write error, which means your RAM is having a problem.
You can try takng the RAM simm/dimm out and re-seating them back into the slots.
If the issue continues, you will need to replace the bad RAM
Nov 21, 2009 | Gateway GT5404 PC Desktop
No picture and desktop makes beeping sound
Base on the post codes this continuous beeping indicates a power problem. Atypically this is a power supply problem and it will need to be replaced.
Oct 06, 2009 | Computers & Internet
A and b lights on back are yellow and computer wont stay on. computer beeps three times then reboots never rebooting completely. continually
If your computer is under warranty, contact Dell as they can troubleshoot this with you.
If you have your monitor plugged in via DVI (cable with white connectors on ends using a digital connection), try switching to an RGB cable (with the blue connectors on ends also called an analog signal). Remember to switch your source to RGB on the monitor(s) as well.
If that isn't the problem, then before getting to the Windows loading screen, press F8 a few times and choose "Safe Mode" and see if that allows you to boot up into Windows. From there try to figure out what recent system configuration changes could have take place that could have caused this malfunction. Perform a virus and malware scan as well.
All the best.
Jul 14, 2009 | Dell Dimension 4600 PC Desktop
Black screen when i turn on the computer
post comment in my yahoomail so thAT i can kep in touch with you!!sergio_bonjovi@yahoo.com
when you turn on the computer does the computer beeps?how many times does it beeps? when your computer beeps 3 times faster..try to check you video card!!!! but when the computer continues to beep and beep try to check the modules or the memory try to replace it with a new memory!!! but when you turn on your pc and no beep at all your motherboard will be the problem?so did i answer your questions?
Apr 25, 2009 | Compaq Presario 5000 PC Desktop
Beep
The Polaroid Fun! Digital 320 camera is programmed to shut off automatically after a few minutes if it is not being used. This helps to conserve battery power. When the camera shuts itself off, it will make a continual beeping sound. To use the camera after it has shut off, simply push the shutter button or self-timer button to take a picture. If you are not going to use your camera, turn the power switch to OFF. The camera will also beep in rapid sequence after you press the self-timer button. The camera will continue to beep in faster sequence until a picture is taken (approximately 10 seconds). A final long beep signals that a picture has been taken. NOTE: It is normal for the camera to beep while downloading photos to a computer.
Sep 14, 2005 | Polaroid PhotoMax Fun 320 Digital Camera
Gateway GT5654 Desktop PC Logo
491 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
