Question about Sony BDV-IT1000ES Home Theater Systems. 5.1-channel Blu-ray theater system
Sony BDV-IT1000ES Unknown Disc
My Sony BDV-IT1000ES has stopped playing discs. Whenever I insert a disc either old or new it says Unknown Disc.
techman
  • 3130 Answers
SOURCE: No disc message on DVD Player
What you might want to try before giving up would be to get a lens cleaning disc. If that does not work then you may have to take off the top, locate where the small laser lens is, and with a small cotton swab, soak slightly in alcohol, and in a swirling motion, clean the laser lens, now with the dry end, do the same. Wait a few minutes for all the residue to dry. Plug in the unit, and see if you made any differance. If you did GREAT!!. If not well at least you tryed, and there is not alot more you can do as a consumer, without test equipment, or speacial jigs. It most likly will not be worth taking into a repair shop, as these days these players are almost a dime a dozen!. Good Luck Ps Please do not forget to rate this.
Posted on Oct 16, 2006
SOURCE: No Disc
Stumpy, I think the first step could be to find out between the DVD player and the disc which one has a problem.If the DVD Player is able to play other discs then it is possible the problem is with the disc only. If that disc can be played quite alright in other DVD players then the problem is with your DVD Player. I suggest you trial that first. I think the indication of " No disc insert disc" could be that your DVD Player is failing to load or read the disc either because the disc has some scratches or because your DVD Player lens are not powerful enough. I am, Letsthank.
Posted on Aug 10, 2007
dankind38
  • 6 Answers
SOURCE: SONY SLV-350P DVD PLAYER/VCR COMBO
I'm afraid you are dealing with a weakened Laser on the unit. The cost vs. benefit ratio of fixing this unit is not worthwhile.
You will find that there are newer versions of this device on the market less expensive than what you paid for the unit you have now.
Posted on Dec 30, 2007
SOURCE: player reads no disc
make sure you are putting them in correctly
Posted on Jan 27, 2008
  • 102 Answers
SOURCE: My Sony PlaySatation2 console wont read any games on PS2 discs.
9 out of 10 times when the fat ps2 cant/wont read disk its the cd tray needs to be adjusted.
I would suggest opening up the ps2 and cleaning the console with Qtips and rubing alcohol. if the laser will wont read. go to youtube.com type in fix my ps2 laser. you will watch a video on how to adjust your cd tray.
The reason for this issue is if the laser is to close or to far from the cd the laser cant read the cd.
the worse problem u can come across is the laser 100% failed. which is rare but you can buy a new/used working laser on ebay.com or google it. the laser will have the model on it you want to make sure you get the correct model. otherwise it wont work.
contact united.gamez@gmail.com for help
Posted on May 20, 2008
My sony bdv-e300 started not being able to read discs.....after trying updates (from .007 to .009); resetting; unplugging from surge protector to wall outlet (all Sony's support ideas).....nothing...
Did you figure this out? I upgraded firmware from 009 to 011 and am now having the same problem. Have had the unit for 18 months. Called Sony and they want me to ship in for 147.00 dollar repair even though their firmware upgrade caused the problem. Cannot operate disk now when trying to load a Blu-ray disk. Plays standard DSD's without any trouble.....
Mar 27, 2011 | Sony BDVE300 Theater System
Uxpendables blu ray won't play on my bdp s350. It says Unknown Disc. update not needed I already checked.
is that the only disc that wont play? have you tried inserting memory stick on bd player. format memory stick (atleast 2gb) first to fat 32 using computer. insert to usb slot of bd player. then try to play the disc again...
Dec 24, 2010 | Sony BDP-S350 Blu-Ray Player
HOW DO I TYPE NAMES OF CD OR DVD ?
You can't add a title to a disc from a player (such as this). You can only add a title on a disc writer before finishing the disc. (The only exception is RW (rewritable) disc which can be unfinished.) If a title (disc, chapter or track) is on the disc you can display it. Press Title on the remote. If you want to read all of the information on any disc, insert the disc and press Load on the player (when in Stop mode) or press the TV/DiscExplorer/DVD button to set the unit in Disc Explorer mode. It takes about 30 seconds to load the data. Press Stop to cancel the data search. Then use the folder buttons (ALL,DVD,CD,A,B,C,D) on the remote or the player to read the various items. Press Return to leave the folders. If you enter the Disc Explorer while playing a disc, the playback will stop and you will have to press Play to restart (Resume is not an available option).
Once loaded the player will store the data even after you remove the disc. It will clear when a new disc is inserted or you press Load.
The manual for this unit is available at: http://esupport.sony.com/US/perl/model-documents.pl?mdl=DVPCX850D .
I hope this helps.
Oct 12, 2010 | Sony DVP-CX850D DVD Player
My 2 1/2 year old LG dvd/vcr recorder will play some dvds but will not play others. It says unknown disc. I was told to try a lens cleaner; I bought one and the lens cleaner says unknown disc as well. ...
Your DVD /VCR says unknown disc because the
dvd which you have inserted is not of the supported format by player.
If you insert unsupported formats only it will say as unknown disc.This is not related with disc cleaners.
Please insert the supported formats and it will play the disc.
Thanx
Jul 31, 2010 | LG Televison & Video
Keep saying No Disc on Sony BDV-IS1000
a lens dosent work. you need to buy more
Sep 28, 2009 | Sony DAV-IS10 System
Ps3 will not play disc
You better do disc cleaning on the unit. It seems that the optical lens is dirty and cannot read any disc you insert. On this you may need a disc cleaner to clean the unit lens.
Hope this helps
Aug 03, 2009 | Sony Playstation 3 (PS3) Console
Disc reads "There is no data"
For one nobody plays this game any more
I don't know how to fix it sorry''''''''''!!!!!!!!!!!!!!!!!!!
lol Ha Ha Very funny
Nov 10, 2008 | Sony PlayStation 2 (PS2) Console
Panasonic SA-AK66 Sound Problems
I have a Panasonic SA-AK66 5 disc changer stereo system. At first I was getting a no disc. I inserted my cd disc cleaner, now it won't play the disc or open (the drawer). What happened?
Nov 26, 2007 | Panasonic Audio Players & Recorders
Sony BDV-IT1000ES Home Theater Systems. 5.1-channel Blu-ray theater system Logo
113 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
