Jumper Settings Western Digital WD3200 AAKS - Computers & Internet
SOURCE: western digital hard drive
I have a WD800BB.
Jumper settings starting closest to the power connector.
CS for Cable Select
SL for Slave
MA for Master
The last two position are not marked.
Hope that helps.
Posted on Mar 19, 2008
Crystal K
  • 3 Answers
SOURCE: jumper switch settings
I have the same thing and here is your solution.
http://www.babooforum.com.br/idealbb/files/152532-Maxtor2.jpg
Worked perfect for me afterwards. :)
Posted on Apr 19, 2009
  • 111 Answers
SOURCE: Is there anyone who can tell me the jumper
http://www.wdc.com/en/library/eide/2579-001037.pdf
Try there it should help you out.
Posted on Oct 30, 2009
  • 17 Answers
SOURCE: need jumper settings wd800 as Mast. & maxtor Dia.plus as slave??
To use the WD 800 as a master there must be no jumper attached to it.The maxtor has a diagram for the jumper and it MUST be set to slave not cable select.
Posted on Mar 24, 2010
  • 509 Answers
SOURCE: my western digital wd800bb caviar, has no label
Set the jumper like this for a secondary hard drive...
Posted on Jul 09, 2010
What is the nutral position sinle jumper settings
Jumper Settings: The Western Digital hard drive is factory set for single drive installation. Western Digital hard drives are shipped with a jumper in the neutral storage position (across pins 5 and 3) for future dual drive use. If you are installing the Western Digital hard drive as the only hard drive in your system, leave the jumper in the neutral storage position. Jumpers are not required for single hard drive installations.
For more information visit this link http://support.radioshack.com/support_accessories/doc33/33085.htm
Apr 25, 2015 | Western Digital CaviarĀ® WD400BB 40 GB...
Western digital wd2500bevt slave jumper settings
SATA drive position is determined by the plug on the motherboard, not a jumper. Jumper settings are for PATA drives (much older).
Feb 06, 2014 | Western Digital WD Scorpio Blue WD2500BEVT...
Western digital caviar ide drive jumper settings master
The jumper settings are on the label or just above the jumpers on the end of the drive
Apr 26, 2013 | Western Digital Caviar 40 GB Hard Drive
Manual for wd 3200js-00pdb0
Here you are,
http://support.wdc.com/product/install.asp?wdc_lang=en&fid=wdsfCaviar_Blue
On the above Western Digital Support page;
1) Quick Install Guide
2) Jumper Settings
TIP:
There are NO user jumper settings. These settings are for the factory. Set as it came out of the box is the way to use it.
For additional questions please post in a Comment.
Regards,
joecoolvette
Jun 16, 2011 | Western Digital Caviar SE WD3200JS...
Need to know what is jumper setting for cable select on all western digital hard drives
Welcome to Fixyah,
Jumper settings procedure will located at the front of that disc and it will show where the jumper setting was located. I suggest to you to go ahead and check it out.
Aug 11, 2010 | Western Digital Caviar WD400BB 40 GB Hard...
Dead Western Digital 500 gig hard drive (My Book)
I had same issue. 1.5 yrs old and suddenly not accessible. Took unit apart with screw drivers and broke a couple of tabs. I'm now thinking that if you first pull off the soft rubber "gasket" around the unit, you can take apart without breaking. It then should split into two pieces. Inside mine I found a WD5000AAKS that is now called Blue Caviar, but this was before they used that "blue" name. I took the controller board off the drive and after cleaning with Qtips and laquer thinner found some burned pins on the largest chip. I tried buying a brand new WD5000AAKS and swapped controllers, The old controller was seen by the BIOS when I connected to my PC's SATA, but the new controller is not. Now I have a new 'AAKS that I don't want and am searching for an older 'AAKS to try it's controller board.
Nov 13, 2008 | Western Digital 500GB My Book World...
Jumper settings
check this official web of western digital...
http://www.wdc.com/en/products/legacy/Legacy.asp?Model=WD400EB
Aug 19, 2008 | Western Digital Protege WD400EB 40 GB Hard...
Western digital hard drive
I have a WD800BB.
CS for Cable Select
SL for Slave
MA for Master
Hope that helps.
Feb 20, 2008 | Western Digital Caviar WD800BB 80 GB Hard...
Open Questions:
Losing data is a disaster. Never let that happen Use Cloud Backup'Call +1888784-9316 Cloud storage services are great for sharing files with friends and families, keeping documents in sync between all your devices, and so much more. Free cloud storage is even better! Several backup services offer free online backup plans. DataAlign is known for having the finest free cloud data backup software in the world! Not just being simple and automatic it can be customized to a large extent and not to forget the scheduling capabilities that allows it to run at any time of the day. With several years of experience in its kitty, DataAlign is the trusted innovators in free online backup solution. DataAlign is proud to be known as a market leader in providing Server Cloud Backup Solution based storage and individuals is our primary motto. Our innovative platform has been designed while keeping you in mind. To provide Cloud Backup For Small Business optimal user experience we focus on simplicity and this in turn ensures that you will be able to backup and access large data quickly and smoothly. Unlike other companies, there are no catch with DataAlign free cloud backup solution. With the kind of experience, you get with DataAlign, we strongly believe that you will eventually upgrade your account to a bigger one. And that makes us give awa Online Backup Pricing accounts as a free version with no strings attached. So drop your worries and and setup your free cloud data backup account with DataAlign. Just to clarify we will not ask for your credit card details upfront when you sign up for a free account. Keep using your free account as long as you need it. DataAlign has been designed with you in mind. You wouldn't require any technical skiil or IT degree to use it. Simply, upload your data and the technology will do the rest, enabling you to focus on what really matters; your business. Our dedicated support is readily available to answer any questions that you may have.
May 28, 2018 | The Computers & Internet
Computers & Internet Logo
155 people viewed this question
David Payne
David Payne
