SOURCE: Not able to turn off Progressive scan feature-sony dvp nc85h
Are you pressing the Progressive Scan button on the front of the Player? You need to look at the BACK of the Player. There is a manual switch just below the words "LINE OUT". This needs to be moved to the left where it says "Normal"
Try this please!
Brian
SOURCE: A DVD got stuck in the dvd player
unplug dvd player, hold down open button, then while continuing to hold down open button, plug dvd player back in.
SOURCE: DVD player reloads after 5 minutes into the movie
I have a K715 that was having the same problem. The "line select" had been switched from "in" instead of "out". Once I switched it back to "out", the player worked normal.
SOURCE: Philips Universal Remote with Emerson VCR/DVD Combo
http://www.urc.philips.com/
US2-PM335
There you will find all needed information
Without Codes:
With the DVD/VCR unit on, continue to depress the remote controller's "Code Search" button for about ten seconds, release, & the light on the remote controller should stay on. Continue to tap the remote controller's UP or DOWN channel button ONLY UNTIL the DVD/VCR unit responds. Then, press the power button on the remote controller once the channel has changed. If the DVD/VCR unit shuts off, then press the power button again to turn it back on. If the DVD/VCR unit turns on, then the remote controller has been correctly programmed. Otherwise, repeat this whole process until the remote controller is correctly programmed.
