Question about HP Computers & Internet
I have a hp pavillion 6000 whith a hdmi port i can connect it to my tv and get a picture but no audio
  • 749 Answers
You will need to run a seperate audio cable from the sound card speaker output of the computer to the audio in jack of the tv. i use a 6 ft adaptor cable with an 1/8 inch stereo jack on one end (goes into soundcard) and has rca's ,left and right, on the othe end (this goes into your tv)
these cables can be found at Radio Shack or sometimes even walmart and are no more than 10 bucks
lil extra info::::::The computer usaully does not send sound through the video cable as sound is not processed in the video card:::::::::
Posted on Oct 24, 2008
How can i connect my hp pavillion s5610y to my bravia tv
This is a bit complicated since there is no HDMI output capability to the PC, only VGA and DVI. First, check to see if the Bravia has one of its HDMI ports listed as DVI capable. If it does, it should have accompanying audio jacks (red/white) for it. What you would need to get is two different cables for interface. The first is a DVI-to HDMI cable to run from the PC DVI port to the Bravia DVI-compatible HDMI port. You cannot run the DVI to a regular HDMI port because if you do you will get only picture and no sound. DVI outputs, unlike HDMI outputs, do not carry the audio signal. A DVI-compatible HDMI port on a TV set will connect the video from the HDMI port and the audio from the reserved audio port accompanying it. The second cable you need will be a mini stereo audio plug to RCA jacks. This will connect between the PC audio out (green), and the DVI audio plugs on the set. See pictures for cables below
Once you have this done, selecting the appropriate HDMI port on the set should result in audio and video getting to the unit. If you only need the video (you are going to use the PC speakers), then you don't need the audio cable and you can use any HDMI port, but you cannot control the volume using the TV set remote. You would need to use the PC volume settings. (Just as an afterthought if the set has no DVI-compatible HDMI port).
Jan 26, 2016 | HP Computers & Internet
Connecting to usb port
depends on the connections on the monitor/tv. you can get conversion cables like hdmi to usb for example.
Jul 24, 2013 | ViewSonic VA1912wb 19" LCD Monitor
Element tv wont see laptop
Connecting laptop VGA port to HDMI port on a TV
VGA to HDMI converter is required to connect a laptop to a TV with HDMI input. The VGA signal does not have an audio component. You need to connect an audio cable from the audio/headphone port on your laptop to the audio connector on your TV. There are HDMI converters with Audio input so you do not need to connect an audio cable to the TV. The audio is connected to the HDMI converter and then passes the audio with the video data to the HDMI cable to HDMI port on the TV. Check out these WEB site for these HDMI converters. http://www.aten.com/products/productItem.php?model_no=vc180 http://www.sybausa.com/productInfo.php?iid=1174 http://www.topbuy.com.au/tbcart/pc/Audio-VGA-to-HDMI-Video-Converter-Box-HD-HDTV1080P-p164633.htm
Mar 14, 2013 | HP Pavilion Computers & Internet
Hi, I want to know if there is a way to watch tv (sound & picture) with a htmi cable or similar even if I do not have a hdmi port. thank you
You might be better off with external speakers connected to the laptop's audio output. Flat panel TV speakers tend to be weak.
If you want to continue with the HDMI option and your laptop doesn't have an HDMI port, try a USB to HDMI adapter. Look carefully, some models output 720p not 1080p. One possible unit: http://www.walmart.com/ip/Aluratek-AUH200F-Aluratek-USB-to-HDMI-1080p-Adapter/16386417 . However, your video rate may be sluggish due to the limits of the USB port. (If you have a USB 3.0 port on your laptop and find a USB 3.0 adapter, it won't be as bad. USB 2.0 adapters are more common.)
Look at the specs for your laptop or add a comment with the make and model. My mom's HP laptop (purchased in 2009) has an HDMI out; however, the audio driver doesn't go to HDMI out by default.
You may need to adjust the audio output options. (In Windows 7, Start > Control Panel > Hardware and Sound. Then Select Manage Audio Devices under Sound. Check the Playback tab for your audio output options and change the default device if needed.
I hope this helps.
Jan 17, 2013 | Computers & Internet
If hdmi cable sends audio and video info from my laptop to my tv why can't I hear anything? I have video but no audio. the Audio all say hdmi/high def audio and are working properly
Have you "muted" the sound on your computer?
Have you "muted" any of the outputs (MIDI, speaker) on your computer?
Have you "muted" the sound on the TV's built-in speakers?
Have you "muted" the sound on any external speakers that are connected to your TV?
Does your TV have _more_ than one HDMI port? Have you tried them all?
Got a friend with a TV with a HDMI port?
If so, connect your laptop via THEIR HDMI-cable to their TV.
Also, connedct your laptop via YOUR HDMI-cable to their TV.
Jan 09, 2010 | HP Pavilion dv5-1002us Laptop PC
I would like to connect my HP Pavillion dv9000 to my Sony Bravia HDTV... I do not have an HDMI port on my computer. What is the best way to connect them?
I dont believe your laptop has an S-Video port. You should be able to use a Monitor Cable. There should be a PC input on your TV that you can plug into.
Jun 22, 2009 | HP Computers & Internet
No audio from HDMI on HP Pavillion DV9700
If you are not getting any audio through the laptop without the hdmi cable check that the volume control has not been turned down on either the laptop or on the windows volume control icon in the bottom right corner of your screen. Sometimes the easy solutions are the hardest to find.
Jun 10, 2009 | HP Pavilion dv9000z Notebook
I have a new HP Pavillion Elite m9160fPC with HDMI- no sound
you have to change your Realtek Audio settings to HDMI output under "playback devices"
Mar 23, 2009 | Computers & Internet
No audio when connected to tv with s-video cable
then you need to connect audio, either from an onboard audio port or your audio-out port which you will need an adapter to plug into the audio out then convert to RGA compatable connector which will plug into your tv audio in port
Nov 20, 2008 | Dell Inspiron 6000 Notebook
Computers & Internet Logo
157 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
