How to fix wirlpool washer mod wfw8300sw01 that is showing f28
Washer showing f28 how do i fix it
5 Suggested Answers
  • 107 Answers
SOURCE: serial #HLT4230350, during washing the washer
F28 = SERIAL COMMUNICATION ERROR
The communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
1. Unplug washer or disconnect power.
2. Check wire harness connections to the MCU, the motor, and Central Control Unit (CCU).
Check connections of the CCU board within the housing. Make sure all grounding switches are engaged.
3. Check the drive system for any worn or failed components.
4. Plug in washer or reconnect power.
5. Verify CCU operation by running a Diagnostic Test or any cycle.
6. Check the MCU by looking for operations of the drive motor.
7. Check the drive motor for powered rotations.
8. Check that the serial harness at the MCU is not mounted upside down.
The wires should be to the left when facing the MCU connectors.
Posted on Nov 12, 2009
techbuster
  • 5081 Answers
SOURCE: F28 code washer stops working. Reset will only
Error code F28 indicates that one of the below part is bad
  • Motor Control Unit (8540135)
  • Microcomputer Machine Control Unit (8540788)
If you find either the MCU or the CCU(Microcomputer Machine Control Unit) you can fix it,
Here's the online repair manual for Whirlpool Duet Sport, but its identical to your HE2.
Refer page# 4-20 it describes how to get to MCU.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/6545d78b3f479480852571650061b1ba/$FILE/8178558.pdf
Posted on May 04, 2010
Testimonial: "I'll look for that manual-thx for the info"
  • 662 Answers
SOURCE: F28 appearing on display. What does it mean? how
Check your washer plug to see if the connections are tightly screwed. Next check your filter if you haven't for long.
Remove the 3 screws at the bottom of the front panel under the washer door. Your filter door will be light brown. If you find a hose there it is to drain out excess water (water that could not be drained by your pump) After you hv drained unscrew the cap and remove all the junk inside. Have a large plastic bag to catch junk and water. Refit carefully after cleaning out. If not solved, something shd be blocking your pump, check this out
How abt a nice rating for the free help? Thnks
Posted on May 19, 2010
quatlew
  • 139 Answers
SOURCE: wirlpool duet sport Mod Wfw8300sw01 Error code
Take off the front bottom cover (3 screws). Unscrew the lint filter and empty it out , it is plugged. est cost of repair $ 150.00
Posted on Mar 18, 2010
Testimonial: "Thank you very helpful all that work pulling washer out using metal coat hanger ect to try to fix waste of time when the solution was that simple <3"
Whirlpool duet steam front loading
go to this link ........... it will show you step by step solution
http://www.ehow.com/how_8052747_fix-f28-code-whirlpool-duet.html
May 06, 2013 | Washing Machines
TOUCH PAD ON MODEL WFW8300SW01 WON'T START WASHER
You will need to replace the interface board on the unit. Here is the board to order.
The part comes with a 365 day, any part, any reason return policy.
Nov 23, 2012 | Kenmore Dryers
I washed a large load in our Whirlpood Duet Washing Machine and it stopped with a flashing F28 code. I unplugged it for 5 minutes and it still will not run a cycle without stopping with a flashing F28...
The error code F28 means one or both of these parts are bad.
It would be a good idea to order both, as both components have been problematic for error code F28
If you find either the MCU or the CCU(Microcomputer Machine Control Unit) fixed it.
You can download the online repair manual in the below link
On page# 4-20 it shows how to access your MCU.
Jun 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
May 04, 2010 | Kenmore HE2 Plus Front Load Washer
Serial #HLT4230350, during washing the washer would stop and sometimes flash F28 , a technician says that the MCU was totally destroyed. Do I have to replace the enire Master Control Unit if the problem...
Nov 07, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Duet front loader washer Model WFW8300SW01 Whirlpool. The washer is not working it locks the door when you press start. We have replaced the door latch and the main control board. At one time it had a F28...
This should tell you all you want to know.
Sep 02, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Washing Machines Logo
235 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
