Question about Yamaha Audio Players & Recorders
Yamaha AX550 When on phono we get intermittent drop out on thr right channel by changing back to Tuner (one next)and back using the remote full sound is restored. how can this be repaired
5 Suggested Answers
SOURCE: Yamaha DSP-A2070 intermittently fail to output audio to speakers
Probably selector switch when you turn to CD mode. The ball bearings inside the switch make poor connection resulting in intermitant problems to either speaker. Yamaha knows the selector switch is defective but has stayed silent. I've had mine replaced for $144.00 Can and it works AOK now. Different switch of course. I've had my problems with that switch for a long time and it was after a few years that a knowledgeable technician knew of the problem. Poor support by Yamaha! I'll never buy a Yamaha product again nor will my relatives and friends. Do the calculations and assess whether the cost of the switch is worth the value of the receiver. I think it is worth it as the receiver when it works is excellent. It is at a stage now when other problems could creep in though including corrosion on the boards and solder joints so have the technicians do a entire quality check at the same time...
Posted on Jul 02, 2009
Grubhead
  • 5484 Answers
SOURCE: Intermittent fault on right channel. Sound breaks
Get hold of a Servisol freezer spray, from either Maplin or Radio Shack, depending where you live. Take the top off and look inside. Locate the output transitors for the right channel and with it powered up wait for the fault to go away. Then with the spray, squirt any of the transistors you suspect. If it starts up (the fault) after the spray, that part has gone!
Do them one at a time and wait a while before spraying the next part. If you find one that acts up, to make certain, warm it back up by touching it with a soldering iron. Then freeze again.
Posted on Oct 07, 2009
  • 4234 Answers
SOURCE: Intermittent drop out on Yamaha CA amplifier
The output speaker relay is corroded a bit. The higher volume creates enough voltage to bridge the gap and make a good connection again. Some of these relays are sealed and can not be cleaned. The relay should cost around $10-$15 max.
Dan
Posted on Dec 24, 2009
  • 17 Answers
SOURCE: I own a Fisher X-202-B tube amp which I have
i) It is possible that one of the electrolytics has been put in with wrong polarity. Check in the faulty channel preamp. It may have caused the HT to collapse in that preamp section - look for burnt resistor.
ii) Also compare the corresponding voltage on the anodes of the preamp valves in the working & non-working channels. This will tell you which area is faulty.
Posted on Feb 16, 2011
I connected a JVC component turntable to the CD input then tried the Aux input on a Yamaha RXV663 HD tuner and the audio volume in this 7.1 system was almost non existent. There was barely any base coming...
Yeah, phono a preamp.
"PHONO" is the only designated connection on an audio device that is literal and exclusive. Nothing but PHONO will work right on it and old-school turntables would require it to preamplify the tiny current produced by a Phono cartridge.
If your unit doesn't have a PHONO connection AND your TT doesn't have a self-contained preamp you will have to get a Phono Preamp to connect between the TT and any Line Level input, like Aux.
eBay always has some...
http://shop.ebay.com/?_from=R40&_trksid=p3984.m570.l1311&_nkw=phono+preamp&_sacat=See-All-Categories
Jul 25, 2011 | Audio Players & Recorders
When using tuner both speakers work but when using turntable one speaker is very low?
ONLY one channel low with a turntable?
Are you using a self-preamlified TT or an outboard phono preamp, because the HTR has no facility for direct attachment of an old-school TT.
It could be a turntable problem if you have phono preamplification most likely. Swap the two channels to prove it or not.
Try another input.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Yamaha-HTR-5730-Receivers-manual/id/1075bh230/t/2/
Mar 11, 2011 | Yamaha HTR-5730 Receiver
What are the classification of simple machune
Specifications Display Image Aspect Ratio: 16:9 Widescreen Modes: Conventional 4:3 Comb Filter: 3D digital Additional Features: V-Chip, parental control Diagonal Size: 42" - widescreen Display Format: 1080p (FullHD) Resolution: 1920 x 1080 V-Chip Control: Yes Image Contrast Ratio: 2500:1 Brightness: 500 cd/m2 TV Tuner Stereo Reception System: MTS Secondary Audio Program (SAP): Yes Analog TV Tuner: NTSC Video Features HDTV Ready: Yes Analog Video Input Signals: NTSC Input Video Formats: 1080p Remote Control Type: Remote control Audio System Sound Output Mode: Stereo Sound Effects: Virtual Dolby Digital Speakers Included: 2 speakers Additional Features: Mute button Speaker(s): 2 x right/left channel speaker - built-in Connections Connector Type: 1 x composite video input ( RCA phono ) ¦ 1 x S-Video input ( 4 pin mini-DIN ) ¦ 3 x audio line-in ( RCA phono x 2 ) ¦ 2 x component video input ( RCA phono x 3 ) ¦ 3 x HDMI input ( 19 pin HDMI Type A ) ¦ 1 x digital audio output (coaxial) ( RCA phono ) ¦ 1 x audio line-out ( RCA phono x 2 ) Power Power Device: Power supply - internal Power Consumption Operational: 240 Watt General Product Type: 42" LCD TV TV Tuner: 1x analog, 1x digital Width: 41.3 in Depth: 10.2 in Height: 29.7 in Weight: 55.1 lbs HDCP Compatible: Yes Digital Television Certification: HDTV Digital TV Tuner Digital TV Tuner: ATSC, QAM Additional Specifications HDMI: Y More Information Model No.: DP42848 Shipping Weight (in pounds): 67.0 Product in Inches (L x W x H): 41.3 x 10.2 x 29.7 Assembled in Country of Origin: USA and/or Imported Origin of Components: USA and/or Imported Walmart No.: 000503420
hope this will be helpfull to you.
GoodLuck
Feb 02, 2011 | Sanyo 42 in. LCD TV
VIZIO LCD VX20L, intermittant video/audio with Blue screen message "No Signal"
If the tuner is bad, changing the mainboard should fix the problem.
May 18, 2009 | Vizio VX20L 20 in. LCD TV
Does my toshiba model have a digital tuner?
Negative. Here are the specs for your TV/DVD combo: I hope this solution is helpful. Please take a moment to rate this solution.
Toshiba MD13M1 Dvd Type: DVD player - built-in
Media Type: DVD, CD, Video CD
DVD Repeat Modes: A-B repeat, title, chapter
CD Playback Modes: Program play, random play / shuffle, all tracks repeat, one track repeat
Tv tuner Analog TV Tuner: NTSC
Reception System: NTSC-M
Analog Channel Qty: 181 channel(s)
Channel Coverage: VHF:2-13, UHF:14-69, Cable:1-125
MTS Stereo: Yes
Video features Closed Caption Capability: Yes
Closed Captioning on Mute: Yes
Remote control Type: Remote control - infrared
Features: Back-lit buttons
  • 1 x headphones ( mini-phone stereo 3.5 mm ) - front
  • 1 x composite video/audio input ( RCA phono x 3 ) - front
  • 1 x SPDIF output ( RCA phono ) - rear
  • Composite video/audio input ( RCA phono x 3 ) - rear
  • 1 x antenna ( F connector ) - rear
Jan 28, 2009 | Toshiba MD13M1 13 in. TV/DVD Combo
Right speaker goes off when using Rec out on the Phono input
The switch is contaminated. Pick up some electronic switch cleaner and spray into the switch. Move the switch back and forth a number of times and that should clear up the problem. Make sure that you get the cleaner that has a lubricant included.
Dan
Jul 08, 2008 | Yamaha RX-595 Receiver
No sound from turntable bought for our hi fi system
Most if not all turntables would need to be connected to a PHONO INput which is high impedance with a high gain pre-amplifier stage. It will not work when connected to an AUX, CD or any line level inputs. Alternately, if your amp does not have any Phono Inputs, you can feed the turntable output to a preamp which can then be connected to any any line level inputs. An example may be found here or here. Additionally, there are some turntables with a built-in preamp.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Jan 16, 2008 | Audio Players & Recorders
Can't get B Speakers to work
Use the remote and switch it to be in the sub mode (top right corner of remote) It is here (in the sub mode) that you can change volume and inputs.
May 29, 2007 | Onkyo TX-DS555 Receiver
Open Questions:
75 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
