Question about Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw
455 husqvarna only runs with choke on - Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw
4 Suggested Answers
  • 211 Answers
SOURCE: husqvarna chain saw, model 455 will not oil properly bar and chai
hi cindilou50
check the oil filter from the oil tank,the oil line ,the worm gear and the oiler under the clutch.Clean the ways where the oil goes with compresed air.(after you fill out the oil tank)Also check the oil hose.
best regards savumihai71
Posted on Dec 01, 2008
  • 4088 Answers
SOURCE: i have a husqvarna 455 rancher that won't run at
Clean or replace the fuel filter. Check the fuel lines for decay or other damage. Check the muffler for plugging of the screen. Be sure to run with fresh fuel mix and to shake the container thoroughly each time just before filling the tank to prevent oil starvation. Hope this helps!
Posted on Nov 11, 2010
SOURCE: Chainsaw will not shut off using stop, I have to
the wire on the stop switch probably came of the terminal. take the top cover off 3 screws ,and the air cleaner. you just replug it.
Posted on Jan 26, 2011
455 rancher runs with chock out 15 second and dies
Try opening the choke half way as soon as it starts then all the way open in a few seconds... It only needs the choke to start and should run fine in less than a minute after idleing with the choke not engaged...
Jun 15, 2014 | Husqvarna , No.455 Rancher, 20" Gas -...
Wher do the two carburator linkages hook up to a husqvarna on a 455 rancher
The throttle wire plasric end sits through the back of the crancase and into the square cut a way into the tank back handle, the hooked wire end drops into the carb throttle spindle on the r/h side of the carb, the blue clip on the spendle then rotated and locks the wire in, the choke pull just pushes into the choke spindle on the l/h side of the carb, it has a bullet style end to stop it popping out again
Dec 06, 2012 | Husqvarna , No.455 Rancher, 20" Gas -...
Started 455 rancher after setting for about a month. always used stabil in fuel. started with choke on and then turned off choke once saw was running. the saw seemed to be stuck in high idle and would take...
This sounds like the throttle spindle sticking, or the cable sticking, if you remove the top cover and air filter, then push the throttle spindlefully back to the stop screw with your finger, then try again, the spindle may be a little gummed up.
Mar 18, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
Chainsaw will not shut off using stop, I have to use the choke to shut it off. Husqvarna 455 Rancher
Jan 02, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
I have a husqvarna 455 rancher that won't run at full throttle unless the choke is on. It runs at half throttle fine.
Nov 11, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
Husqvarna 51 idle seems to struggle, runs OK when I throttle then chokes and dies out as soon as the throttle is released. What can I do?
will it start right back up after it dies? you could use a small screwdriver and turn the idle screw in a little to raise the idle speed that should fix it.
Oct 09, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
Want start
Read the warm start procedure from the operators manual.
1. Pull choke (sets fast idle)
2. Push in choke (fast idle retained)
3. Make sure ignition is on, pull (usually once on my saw)
4. Advance throttle slightly to release fast idle.
I made the mistake ONCE of not setting the fast idle. My shoulder gets sore thinking about it. HTH
Lou
Sep 21, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
Husky viprating on tick over and now wont start
I think you are saying it sputters but won't run. Once it attempts to fire open the choke or it may flood. My 359 start:
Cold: pull out choke control, pull starter (usually twice) while listening for attempt to start. Once it fires push choke control in and
continue pulling (usually once more).
Warm: pull out choke control (sets fast idle), push choke control in, pull starter.
Page 19 of my manual.
Lou
Once flooded these are a bear to start.
Aug 25, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
I am getting fire on my 455 rancher BUT IT WILL NOT START
you need turn off you choke one's its fired up... otherwise it will flood the saw with too much fuel...
Aug 05, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
455 Husqvarna chainsaw will not run
Remove exhaust , check piston make shore you have a chance,
check ex screen isn't blocked.
check choke isn't stuck on,and half throttle is working. get back to me from there.cheers
Dec 22, 2008 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw Logo
93 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
