Question about Moen 6610 Brantford Two Handle Lavatory Faucet with Drain Assembly Chrome
Change washer in moen 6610
How to change washers in moen 6610 faucets
  • 68 Answers
SOURCE: trying to get the handle off a single handle moen kitchen faucet
Hi adelinette,
Pry the cover off the top of the faucet with a little screwdriver. Under the cover you will find an allen head screw. Sometimes a little upward pressure with a screwdriver will help. Unscrew it and start disassemblying. Pay attention to part location as you take the faucet apart. you will be replacing a stem and not a washer when you get into it.
Good Luck and please rate this response, Phil
Posted on Jan 06, 2009
  • 92 Answers
SOURCE: Replacing Moen 1225 cartridge.
you will need a puller more then likely but what you can try is a little wd-40 lubricating spray
Posted on Feb 05, 2009
  • 82 Answers
SOURCE: moen T2113 shower faucet no hot water
You need to replace the stem. This will not cost you a dime; call MOEN and tell them the issue, with the model number, and they will send the replacement part. Many people don't know that MOEN is guaranteed for life (to the original owner)......another words, say you are the original owner :) They will not ask any questions. Good luck! PS Also works on any MOEN faucets you may have.
Posted on Sep 03, 2009
motor1258
  • 6674 Answers
SOURCE: i have a moen kitchen faucet with spray (high
If no satisfaction from Moen, hardware stores usually have "O" ring replacement kits by faucet type, and it will likely have the one you need in it.
Usually only a few dollars.
Posted on Jan 23, 2010
SOURCE: I am reinstalling a Moen 7345 riser faucet in my
I had a similar problem and, like you, found that there was nothing for the washer to seat against. Apparently, there was a metal bushing installed when manufactured, that was entirely eaten away by electrolytic corrosion - mine took nearly twenty years. I machined a new non-metallic bushing, installed it, and the problem was solved.
I also sent Moen's president a letter explaining the problem and how to fix it but heard nothing back from them. At the time, no parts were offered that could fix the problem.
Posted on Mar 23, 2010
Changed the stem in moen faucet but now it won't turn all the way off
need to reseat / replace "washers" in faucet ???
May 09, 2017 | Moen Plumbing
How is the cartridge removed on the faucet?
How To Repair Cartridge Sink Faucets at The Home Depot
www.homedepot.com/.../project_guide_repairing_cartri...
The Home DepotJul 22, 2013 - Quickly fix a leaky cartridge sink faucet with this detailed step-by-step ... On some models of faucet you may have to remove the cartridge with a
Removing a moen cartridge from the faucet! If the plastic tool ...? 2:47https://www.youtube.com/watch?v=vGdExIS3b-oMar 5, 2013 - Uploaded by TheOldkid888This is a video on how to remove a moen cartridge from any moen faucet when the plastic tool does not do ...Installation Help / Animated Tutorials for Moen Faucetwww.moen.com/consumer-support/installation-help/tutorial?id...MoenUsing a Philips screwdriver, unscrew the handle screw and pull the handle up off from the faucet. Using pliers, loosen and remove the pivot retainer nut as well. Remove the washer from the cartridge and use pliers to remove the retaining clip.
Dec 03, 2015 | Plumbing
How do I remove the handle on a Moen Brantford doule handle lavatory faucet
there has to be a small setscrew hole on either handle .otherwise they could not be repaired
Feb 11, 2015 | Moen 6610 Brantford Two Handle Lavatory...
Have a moen brantford bathroom faucet. One handle has become very hard to turn. The hot water side turns fine, but you have to use muscle to turn on the cold. Does the handle need to be replaced or the...
It usually takes a special tool to remove a Moen cartridge. Just getting the handle off can be tough. How long have you had this unit? maybe it would be cheaper just to replace the whole thing. My last Moen lasted a good twenty years, still working good, but finally starting to corrode. Good product.
Nov 30, 2013 | Moen 6610 Brantford Two Handle Lavatory...
Moen bathroom faucet washer replace.
They should have a small Allen screw in side may have a small cover if u call morn and tell them type they will send you new ones free and directions
Mar 30, 2013 | Moen Plumbing
Moen - Single lever bath tub faucet - cold water only
moen does not have a ball and washers....sounds like a Delta maybe. Moen uses cartridges. Either way sounds like a balancing spool problem....but you will need to make sure of the right name for the faucet to get the parts.
Aug 17, 2009 | Plumbing
Moen Tub Faucet.. Water won't stop running.
change the washers first if that don't work change the inserts buy all at same time and return if not needed . Thank you for useing fixya please rate me
Feb 25, 2009 | Moen 2919 Chateau Two Handle Tub and...
Feb 05, 2009 | Moen Plumbing
Trying to get the handle off a single handle moen kitchen faucet
Hi adelinette,
Jan 03, 2009 | Moen 7437 Chateau Single Hole Kitchen...
Moen 6610 Brantford Two Handle Lavatory Faucet with Drain Assembly Chrome Logo
29 people viewed this question
Top Moen Plumbing Experts
john h
Donni Steen
Don Numinen
Don Numinen
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
