Question about Nintendo Wii Console
New additional handset
My wiii plus 1 original handset works fine. but i bought another remote handset and cant see how to register it.....pls help
Try going in to wii settings. An where there batteries are theirs a red button to press to activate it i think. I tried both of these and one of them worked dont know which one, hope that helps
Posted on Oct 25, 2008
GE Model 27911 DECT 6.0 Additional Cordless Handset not working
I took the post that mentioned removing the battery, waiting a few minutes and then reinserting it.  It worked.  Thanks to that person.
Apr 14, 2009 | Uniden Cordless Phone
Can't register new handsets
If you have a multi-handset system, you already have more than one handset
registered to your base unit.
You can register additional handsets to have up to five handsets per base unit,
with each handset's number (1 to ) shown on its display. (Note: each handset
1. Press and hold <PAGE> on the base station for more than five seconds, to
put the base station into registration mode. It will stay in registration mode
To register a new handset to your base:
for about 1 minute, so the following handset sequence must be completed
with in this time.
2. Press <MENU> and <UP/DOWN> to select REGISTRATION.
3. Press <OK> and you are requested to enter the 4-digit system PIN.
4. Enter the 4-digit system PIN.
5. Press <OK> to confirm, and the display will show SEARCHING.
If the handset registration is successful, you will hear a confirmation tone and
the <antenna icon> will stop flashing.
The handset will automatically be allocated the next available handset number.
This handset number is shown in the handset display in standby mode. If the
handset registration is unsuccessful, the <antenna icon> will still flash.
I Used 0000 As the default pin when asked.
Hope this helps you
Apr 10, 2009 | Lands Phones
Sync a new handset to kx-tg5632 phone
This works on MY panasonic; May work on yours too!
Registering a handset
The included handset and base unit are
preregistered. If for some reason the
handset is not registered to the base
unit, register the handset.
1 Handset:
{MENU} i {0}{0}{1}
2 Base unit:
Press and hold {LOCATOR/
INTERCOM} until the IN USE
indicator flashes.
LAfter the IN USE indicator starts
flashing, the rest of the procedure
must be completed within 1
minute.
3 Handset:
Press {OK}, then wait until a beep
sounds.
4 {OFF}
Registering an additional handset
See page 5 for information on the
available model.
Start from step 2.
Dec 29, 2008 | Panasonic KX-TG5632 Phone
Adding a new handset
You need to register the new handset with the base.
In Global settings De-register the new handset then place it on the main base unit connected. It should then register.
Jun 30, 2008 | Uniden TRU8885 Cordless Phone
Programming old handsets to a new base
Cancel the old handsets registration at the previous base unit if desired.
For additional handsets, you must register each of them at the new base unit. Only one handset can be registered at a time. A handset will be assigned anextension number at registration.
Make sure the base unit and the other handsets are not being used. Program the same way as the extra handset you bought.
Registration must be completed within 1 minute.
Jun 25, 2008 | Panasonic KX-TG2740 Cordless Phone
I had the same problem. What worked for me, after several unsuccessful registration attempts, was to disconnect the phone handset battery for about 1 min and then reconnect the battery. Run the handset registration procedure again. It registered for me on the first attempt after the battery reinstall. Good luck.
Jan 20, 2008 | GE 28111EE2 Cordless Phone
VT2461 ADDITIONAL HANDSET PROBLEM
I can vouch for the second solution. It worked perfectly on my 2461 with two extensions. Even the vTech website was not able to provide a solution.
Dec 12, 2007 | Vtech VT 2461 Cordless Phone
Uniden handset TCX905 with base unit TRU8866-if compatible?
I just successfully registered 4 TCX905s with my TRU8865 base - it's documented in the TCX905 manual.
Be sure the handset you want to register is fully charged.
Remove the handset you want to register from its charger.
Now unplug the AC for the main base, hold down the 'find handset' key on the base and plug the AC in again, when it beeps, you can let go of that button.
Hold down the '#' on the handset you want to register, it will show 'Registering Handset...' and when it beeps, it's done - registered, you're good to go :)
Oct 11, 2007 | Uniden TCX905 Cordless Expansion Handset
Doesn't anyone have an answer or some help? Please!!!!
Uniden TRU8885-2 Cordless Phone > User Guide E X P A N D I N G Y O U R P H O N E w w w . u n i d e n . c o m Register the Handset to the Base If you purchase an extra handset, you need to register the handset to the base before use. Only one handset can be registered at a time. The handset ID for the supplied handset(s) was assigned at the factory, which has #1 or #2 in the display (#2 for models that have two handsets in packaging). When you register additional handset to the base, the handset ID will be assigned. 1) Before registering the extra handset, the battery pack must be charged for 15-20 hours. 2) Place the extra handset in the main base unit to begin registration. 3) While the handset is registering, Handset Registering will appear in the LCD. When Registration Complete is displayed, the handset has been registered to the base. If Registration Failed appears, please try these steps again. Extra Handset Extra Handset Charger Charger Main Base Extra Handset + Main Base Charge the handset for 15-20 hours. Place the extra handset in the main base to register. 1 2 3 4 ?An extra handset can be registered when the main base is in standby mode. ?Standby Mode - The handset is not in use and talk/flash has not been pressed.
Jun 26, 2006 | Uniden TRU8885-2 Cordless Phone
Nintendo Wii Console Logo
47 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
