Question about LG 50PT350 50 in. Plasma TV
No sound from output
Hooked up lg soundbar, no sound from the tv output
4 Suggested Answers
  • 864 Answers
SOURCE: im trying to hook up surround sounds on a 50in lg
Use the audio jacks in the Monitor Output section. See pages 9 and 19 of the manual:
http://www.hdtvsolutions.com/pdf/50PX5D-0314-50px4dman.pdf
Posted on Nov 18, 2009
Dumaine
  • 112 Answers
SOURCE: cannot hook up vizio VSB200
I have questions about sound bars myself so just today I call LG about My 42LD450. The first thing the agent said was to not get the Vizio, he said that the 42 just will not work with the Vizio.....just a lil tidbit of info ......
Posted on Jan 13, 2011
  • 159 Answers
SOURCE: I'm trying to hook up a soundbar to my LG
Hi, I have your solution. there are only 2 audio outputs it seems-one is a fiber optic digital output that uses a Toslink connector, the other is a small 1/8 in.- 3.5mm stereo headphone jack ( it's location I'm unclear on-it may be located on the side or even on the bottom edge. Other than those the only other audio out is through the t.v.'s speakers. Thanks for choosing fixYa, good luck-Prodzilla
Posted on Apr 20, 2011
How do I get my headphones to work with my Panasonic smart tv and LG soundbar?
Let me see if I can understand what you want to accomplish.
You have a Panasonic Smart TV, and an LG soundbar. But you want to use a set of headphone. I guess that your TV is already connected to the soundbar, no?
The first thing that you need to check is for an output, it must be from the sounbar, it could be a 3.5mm jack, or an RCA jack. Usually soundbars only have input, meaning that only takes the sound in, never out. If you have an audio output from the TV, you c an always try, but the soundbar won't be use then.
Feb 06, 2015 | LG Televison & Video
I have a Philips soundbar that I have hooked up to my flat screen tv using audio (red,white) cables directly from soundbar to tv and there is no sound coming out.
Be sure you are hooking up the Audio Output from the TV or satellite to the soundbar.
From the satellite box both Audio Output and Video Output go to the TV, and then Audio Output from the TV goes to the soundbar.
Or
From the satellite box Video Output goes to the TV and Audio Output goes to the soundbar.
This may help as well:
https://www.youtube.com/watch?v=Z27WtBy4IUs
Jan 07, 2015 | Philips HTL2101A/F7 Soundbar 40 Watts
Do i need to buy anything extra for my ilive 37' soundbar for my tv? The sound doesnt work with my tv, but the bluetooth works just fine.
You'll need some sort of audio cable to connect the TV's sound or audio output to the soundbar. For the most basic connection, use an RCA-style cable ( like the one found here: http://goo.gl/5F8yLh ) to connect your TV's audio output to the soundbar's input. Most soundbars also have an SPDIF input ( like the one found here: http://goo.gl/2F2rKs ) and most modern TV's have an SPDIF output. Get an SPDIF optical digital audio cable to connect the two devices together. Once you've decided which type of connection to use and have connected the TV's audio output the soundbar, then make sure you select the proper input on the soundbar. That should fix your problem.
Nov 28, 2014 | iLive 2.1 Channel Sound Bar ITP152B
Hook up samsung sound bar to lg smart tv
easiest way would be to connect the optical audio output from the tv to the optical input on the soundbar. You may have to go into the tv's setup menu and enable the audio output jack
May 10, 2014 | Samsung HW-D450 Sound Bar
Sound bar compatibility
Make sure red glow is coming from TV's Opt out cable when TV is on. If it is, it is working. The best solution is use an LG soundbar with an LG TV. There is a differnce in digital outputs and with a "service remote" (used by authorized LG servicers) you might be able to change the TVs factory setting to make the vizio soundbar work. but I think you'll be better off with the LG soundbar.
Feb 18, 2014 | LG 47LH55 47 in. LCD HDTV
I HAVE A 50" EMERSON T.V. AND I HOOKED UP A SOUND BAR TO IT AQND I DON'T HAVE NO SOUND
Ensure that the output from the TV is feeding the soundbar. Use Settings/Sound/Output in the Main TV Menu.
Dec 02, 2013 | Boston Acoustics TVEEM25 TVee Model 25...
Lg soundbar nb2020a setup
If you are currently using your sound system shown for your television sound then you need to use that with you sound bar plugged into it. You can hook it directly to your TV if you have an audio out but your tv has to produce enough output to run the sound bar. If your tv does have an audio out then there is a good chance you need to make those jacks active in the sound set up menu for external speakers. Some sound bars are powered and will require being plugged in as well.
Apr 27, 2013 | Audio Players & Recorders
I tried hooking up my boston acoustic soundbar to the tv's audio inputs, but i get nothing. if i hook it up to my dish receiver i get sound, but i cant use my bluray, cause its hooked in the receiver. why...
because your tv output is not of suffieient power to drive the soundbar. The soundbar needs to be hooked up to an amplifier that is being fed by your tv line out (or earphone output)
Mar 20, 2011 | Boston Acoustics TVee Model Two TV...
How do you connect a vizio sound bar to the tv
plug in the power to each unit with the provided power adapters, turn the sound bar and subwoofer on, activate the wireless subwoofer link by pressing a button on the soundbar (or remote) and subwoofer, and connect an audio source to either the provided analog or digital audio inputs on the soundbar
Note: When using the Digital Optical input, set source device audio out to PCM
(you can hook to ur tv if it has a R/L audio output, or u can also connect it if your tv has a toslink style digital output. (most LCD and Plasma TV's have them.))
Dec 31, 2010 | LG 47LG50 47 in. LCD HDTV
LG 50PT350 50 in. Plasma TV Logo
41 people viewed this question
Computer Repairing
Computer Repairing
