Question about Mag Innovision InnoVision XJ 717 Monitor
I think my tube is out, and maybe more?
My T.V. is a sony KP-53XBR25. I turned my T.V. on one morning, and about 30 seconds later it shut off and won't turn back on. I saw that the two outside tubes are popping, but not the center one. I'm just wondering if it could be a bad circuit to the middle tube. The tubes flash when I plug it in, but every so often it won't do anything. I've stopped messing with it and will probobly call around tomorrow, but I am very interested in any insight to my question which can be offered from any expert t.v. repairers out there. Thanx
Nuvico nvjv 4000 beeps and shuts off
sometimes these will go into an automatic sleep mode and will restart once you power it down and restart..
Jan 19, 2014 | Nuvico NVJV-4000N Video Recorder
The T.V turns on for less than 30 seconds and then the screen turns blue and shuts down. How to fix the problem.
This sounds like a problem i had at the shop some time ago. If i got the right case history. this might be a bad tube. I Found in my case. it was the green tube.. also a shorted ic 7201 and a bad resistor 7301. It might be another tube. this might be other issues but without examing it this is my best guess :)
Oct 13, 2010 | Sony KP-51WS500 51" Rear Projection...
Screen turns red then shuts off
Sounds like a bad red projection tube, disconnect red tube socket and try again if tv stays on reconnect tube soket and adjust screen controls on front of tv under the front panel which you will have to remove to do any of this. There are six adjustment controls 3 are for focus for each color and 3 screen controls for each color. Look close at the black plastic control module should be labled R G B for focus and R G B for screens. Good Luck!
Mike
Apr 14, 2010 | Sony KP-51WS500 51" Rear Projection...
Turns off after 30 seconds
i think the convergence amps are weak, or the akb circut has caused the tubes to go bad, google your model number to see if it is in the tube problem. sony made some projos w/ bad tubes in them. tv lasts only three or four years,no cause i had one
Jul 10, 2009 | Sony KP-65WS500 65" Rear Projection...
Blue Screen
You have a bad blue picture tube. If you replace it the red and green will be weak and probably go sooner than you think. Everytime I had to replace a tube in a sony projo tv i had to replace all 3 picture tubes at the same time. It's very expensive if you don't have any type of warranty coverage.
C-Dog
Feb 10, 2008 | Sony KP-65WV700 65" Rear Projection HDTV
TV goes out
pyrosp4,
it maybe you blue crt (picture tube). mine turn blue and then shuts off. i got it repaired for 460. 300 for the part 160 to install. you can try to adjust the voltage settings behind the speaker screen and see if that clears the problem. if not its you blue crt.
pridah
Dec 18, 2007 | Sony KP-65XBR10W 65" Rear Projection...
Big screen troubles....
It is either going to be a shorted blue CRT (picture tube) or a driver board for it. I suspect the CRT itself.
Apr 17, 2007 | Sony KP-53S35 53" Rear Projection...
Red Screen
Sounds like the red color tube is goeing bad you wil hafto call in a tech to conferm it Sony is noted for tubes goeing bad, in the future leave sony alone
Sep 24, 2006 | Sony KP-57HW40 57" Rear Projection...
Screen turns green then shuts off
Sounds like the green picture tube is arking or shorting out and at that very second the safety circuit senses the problem and makes the complete set turn off,the only way to repair is the replacement of the green picture tube and it can be too expensive.Maybe if you move the complete set from one side of the room to another you might get lucky.Maybe!!!!!!!!!!! is worth to try.
Sep 20, 2006 | Sony KP-61S35 61 in. Rear Projection...
Mag Innovision InnoVision XJ 717 Monitor Logo
Top Mag Innovision Computers & Internet Experts
William Miller
William Miller
Rommel Balcita
Tony
Are you a Mag Innovision Computer and Internet Expert? Answer questions, earn points and help others
