Question about Philips Magnavox DVD/VCR Dual Player
Magnavox MWD 2205 DVD/VCR combo: DVD only plays first couple of minutes of disk and then repeats same over and over
When trying to watch a DVD, only the first few minutes of the program plays and then it replays the first few minutes over and over again without progressing to the rest of the DVD program.
Every now and then can get it to play past the first few minutes or introduction, but most of the time it recycles to the beginning of the program and just replays the introductory part portion over and over again sort of like it's previewing the program over and over again
Can anyone figure out what this crazy thing is doing?
Thanks!
JW
  • 905 Answers
Is this the begining of a dvd that plays the introduction over and over untill you press play again or select the play option on the intrduction? if not then try a cleaning cd for the laser , also make sure the repeat option has not be enabled when the dvd is played hope this helps! I'll check back to see if you need more help
electech
Posted on Oct 24, 2008
Need parental level 4 digit password for magnavox MWD 2205 DVD player
EASY PROCESS LOL
Instructions
    • 1 Press the "Stop" button on the remote if you are currently watching a movie.
    • 2 Press the "Setup" button. A menu will appear on the TV screen.
    • 3 Tap the "Left" and "Right" arrow buttons until "Custom" is selected. Press "OK."
    • 4 Select "Parental." Press "OK."
    • 5 Enter your four-digit PIN number. If you forget or do not know your code, enter "4737" to override the security. Press "OK."
    • 6 Tap the "Up" or "Down" buttons until "Parental Level" is selected. Press "OK."
    • 7 Select "All." Press "OK."
    • 8 Press "Setup" to exit the menu. The MWD7006 is now unlocked.
Sep 21, 2012 | Philips Magnavox DVD/VCR Dual Player
Magnavox 2205 DVD/VCR Output Channel Control
1: set tv to channel you want your vcr output to be on. 2: turn vcr on (if it is a vcr/dvd combo make sure it is on vcr) 3: put in video tape. 4: press play button one time, release it, and then press and hold it for three to five seconds. i had to call customer support to figure this out on mine.
Jan 17, 2009 | Philips Magnavox DVD/VCR Dual Player
Magnavox MWD 2205 dvd/vcr player won't record more than one show on timer
this is a common repair if when you press play on a tape and the the tape stops
it is a slipping belt or there is a clutch disk that starts slipping when it wears down
if it is only not recording the time recording then there could be something wrong with the timming circut. unplugging for a while can reset this. if not it needs repair
dirty head would result in snowy , messed up picture
dirty roller that pulls the tape will result in tapes eaten , tape stop and machine lockup
Oct 17, 2008 | Philips Magnavox DVD/VCR Dual Player
Code for magnavox vcr/dvd player
I am going to assume you are talking about a code for a universal remote control.
It could be one of these:
434 934
The website with the most codes I have seen is http://dogbytecomputer.com/codes.htm#DVD CODES
Aug 13, 2008 | Philips Magnavox DVD/VCR Dual Player
Magnavox MWD 2206A vcr/dvd combo
you probable have a dirty video head...you can try a tape head cleaner tape/// they sometimes work.... if not you need to get to the video head and clean it with a liquid cleaning solution---
one of your tapes may have a bad spot on it causing the problem...if you clean it and use the same bad tape again you can cause the same problem again
Jul 25, 2008 | Philips Magnavox 20MC4304 20 in....
My vcr won't play back
I have a Magnavox zv457mg9 DVD&VCR combo ,and the vcr records for a short period(10minutes) and then cuts off. This happens each time I try to record on the VCR. Any suggestions??
Feb 26, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Magnavox mwd 2206 dvd vcr player....shuts off with eject word across screen.
On a unit I checked with this same symptom, removing the top cover allows the unit to stay on and operate normally. There is some sort of sensor at the left middle of the chassis, which, when unblocked by any opaque object, allows the unit to remain on. A temporary fix (not advisable) would be to replace the top cover with a piece of clear plastic or taut saran wrap (no vent holes needed). It's unclear exactly where/what that sensor is from a cursory test. This is a work in progress on someone else's machine that I lack full access to.
Oct 27, 2007 | Audiovox VE1020 10.2 in. TV/DVD Combo
Philips Magnavox DVD/VCR Dual Player Logo
178 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
