Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Cant get mower to go in to drive or revers
Cant get it to go front or back what should i check.
  • taylorgighar Oct 26, 2008
    Same issue.  Starts fine, blade runs fine, just won't go forward or reverse.
  • 76 Answers
Check that belt is on the drive train pulleys. belt maybe stretched. look for adjuster to tighten slack out of belt tighten in small increments. hope this helps
Posted on Oct 28, 2008
Will not go into drive gear, either forward or revers.
On some models, mainly MTD built units, there is a metal pull out at the rear of the mower. If you pull it slightly up and let go, the metal pin goes in, and your drive train is bqck to operational.
Oct 09, 2015 | Garden
Change rear wheels on self propelled lawn mower
unbolt wheel or re move hub cap or a nut cover pull of the retaining clip remove wheel reinstall in revers with new wheel retainig clip if bolt just tighten up
Sep 03, 2014 | Omega Rear Drive Wheel Snapper Mowers
Craftsman 56" lawn tractor auto trans dose not drive forward or revers. tryed purging trans no go checked engagment rod ok, belt seems good. I can push the mower by hand as if the trans were not connected...
somehow did the little freewheel lever get pulled in the rear of the tractor to disengage transmission?..usually out is disengage and in is engaged. look around the back panel behind the rear axle for a small lever you can pull or push in.
Aug 18, 2013 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
How to replace drive cable on craftsman platinum 700cc mower
I have to change the drive cable I have the end on the handle but cant figure out how to do it on the mower head
Oct 01, 2012 | Craftsman 675 Series 190cc 22" Briggs ...
1320 stalls going in revers
check the safety switch on the back of the trans
May 29, 2012 | Cub Cadet Garden
I have a Honda HRR2165VXA mower that is having issues with the smart drive.
hello, hello, Drive belt replacement for front drive mowers. remove the belt coved on top of deckand clean out grass,turn mower on side where carb is facing up,use a pair of vice grips on side of mower deck so the blade can stop,remove the blade,remove the belt cover and clean out the grass,remove belt from rear and front pulley pulleys. install new belt,put belt cover and blade back on,put front belt cover on, should work,if that is not the problem; wheels will not prepeal the mower,wheels turn only when raised off ground, Check the gears or groves on the inside of the wheel for access wear that is a common problem,check the axle drive gears to make sure turns ok, to check gear box if ok pull mower back wards while drive is engaged,if wheels turn backwards than the trams is bad,all of this is caused by the operator,by not disengaging drive while pulling mower backwards or by holding mower back not allowing to propel self completely,hope this helps,any comments welcome,thank you.
Feb 15, 2012 | Garden
Motor runs, but will not go forward or rever
if you can push mower by hand ? there is a shuttle valve that may have got turned on , its a little handle in the back of the mower that turns off the hydrolics so you can move the mower without the motor running
May 21, 2010 | Garden
Front wheels lock up when pull mower backwards
Typically self-propelled mowers are propelled using the front wheels, which only turn forward. Pulling the mower back while the front wheels are turning will damage the drive gears. It's best to raise the front wheels slightly off the ground before pulling back.
Mar 24, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
145 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
