Question about Nikon Speedlight SB-800 TTL Flash
Fried Unit At my stepdaughter?s wedding this past week end I shot over 600 images using my speed light but when I put in a fresh set of 5 batteries ?? a non-rechargeable got mixed in with the other 4 rechargeable ones and after a few shots I heard a snap, then saw a bit of smoke coming out of the unit so I immediately took the batteries out. The unit will now turn on but it won?t flash. Question, would this have cause it to blow like that and is the whole unit lost (fried) or is it worth trying to have it repaired? Thanks in advance for any help.
  • 363 Answers
Mixing the batteries should not have damaged the flash. More likely the smoke came from the odd battery.
Posted on Nov 28, 2007
SOURCE:
Power light flashes put unit doesn't power on
Laptop is having a power problem. Problem is either from the Adapter or battery (optional). Or the power part on the mother board has a shot.
Jan 26, 2012 | Gateway M465-E Notebook
Which film is best for the Polaroid One Step 600 Film Camera
Polaroid has not manufactured film for 600 cameras in about 5 years now. The only current source is The Impossible Project, which gives 8 shots per pack, black and white images only, and they tend to fade rather quickly. You can find and order online by searching the name. The Polaroid versions available are no longer really usable because the batteries are drained, film has expired and chempaks have oxidized.
Again, the only CURRENT, in-date, usable film for Polaroid 600 is made by TIP, available thru their website. There are some scumbags out there online selling old Polaroid film they've re-dated and selling it as current and fresh film - it is not. The newest Polaroid brand film expired in 2009. Buyer beware.
Oct 24, 2010 | Polaroid 600 Film Camera
I keep putting in new or recharged batteries and every time I get ready to use my camera if it over a week, it says change the batteries. This has just started happening the last 3 months. The camera is...
The rechargeable batteries, especialy NiCD and NiMH ones, loose they're charge over time. Even if fully charged, they loose all of the charge within a week or two. This is not a malfunction.
However, if you are using alcaline batteries and still get this problem, probably you have some electric problems inside (maybe some batteries leaked in the past). In this case try cleaning the inner contacts of the battery slot. If the problem persists, go to a local electronist for repairs.
Apr 12, 2010 | Canon PowerShot A570 IS Digital Camera
My SB-600 Just quit firing... :(
It maybe because it overheated he flash tube, nikon flash guns use a thermal cutout, to prevent overheating, usually after approximately 30 / 40 shots, in quick succession.  It should start working again after it cools down.
If not you may need to get it checked at Nikon Service Centre. Cheers Ian
Aug 04, 2009 | Nikon Speedlight SB-600 TTL Flash
Missing shot.
Any auto camera like this is going to have trouble in dark light...
Photography is all about light, and in dark situations, compromise as well.
You best chance is to set the ISO up to the highest setting available, use flash, and a faster shutter speed, however, faster shutter speeds means less light can enter the lens, and hence give a darker image. Higher ISO makes the camera more sensitive to light, but produces grainier images as a result. Flash creates artificial light...
The only real way to get good images at a concert in the dark is with a high end camera, a lens costing many thousands of dollars, a tripod or monopod to steady yourself, and a longer open shutter time.
In the meantime however, experiment with higher ISO setting, flash and try to keep your hand steady at all times because the shutter speed needs to be slightly slower for the lens to capture more light.
Apr 06, 2009 | Fuji FinePix S8000fd Digital Camera
Canon 5d
Make sure you have your flash & timing set where it is supposed to be, usually between 120 & 180. This is the shutter timing and flash duration. It is the syncronizing speed setting. If possible, turn off the automatic review, this slows things up. Also, if possible, use a power cord for the flash instead of batteries. Not all have this feature but, the flash is ready for the next shot in about 1 second.
Jan 27, 2009 | Canon EOS-5D Digital Camera
Flash blows out the image!!!
hi ,
it could be possible that the light sensor (the device under the red transparent plastic) in front of the flash is already failing. to test,set the camera mode to auto then cover the sensor with your hand and do some test shots, the images should be overexposed if the sensor is covered, then shoot some photos without covering the sensor, the images should be properly exposed , otherwise it might already be a light sensor failure .
Sep 30, 2008 | Nikon Speedlight SB-800 TTL Flash
Nikon FE shutter speeds problem
I don't know, but it's worth a try. I took mine to the camera store, because my shutter wouldn't even work anymore, even with fresh batteries in it. He again tried new batteries, and turned the shutter speed knob from Automatic all the way over to "B" for Bulb, and back to the Auto. Guess What! I haven't used the camera in 3-5 years because I thought it was broke and going to need factory repair. Well, this tricked worked for me. I was so thrilled, because my daughter wanted some double exposures and special filters shots for her wedding. Also the weight of the camera I couldn't handle anymore with a health problem, so I went to digital, but would love a Nikon good digital.
Good Luck!
May 13, 2008 | Nikon FE 35mm SLR Camera
Sb-600 not beeping, images completely black (underexposed)
Series of images is the KEY. If the Power you set the SB-600 is HIGH it will take a LONGER time to recycle than the SB-800. If you try to take a photo before the SB-600 is ready you will get a dark image. The randomness you get is due to the time between shots. In general try to run remote flashes at a lower power so they recycle faster.
I like the SB-800 because it can take 5 cells. 5 cells can really make a difference in the recycle time (faster) The SB-600 only takes 4 cells so it is slower.
Apr 04, 2017 | Nikon Speedlight SB-600 TTL Flash
Rechargeable batteries NiMH don't last long
i used to have the same problem with my Sanyo 2100mAh. i switched to the Uniross 2300mAh and problem solved. that was using my Ridata 512MB 40X solid state CF. switched to Hitachi 4GB MD (from Muvo2) and now the problem is back. i have learned to live with that though, as it causes no other problem for me except for the faulty battery indication.
Sep 08, 2005 | Pentax *ist D Digital Camera
Nikon Speedlight SB-800 TTL Flash Logo
126 people viewed this question
Top Nikon Cameras Experts
Ric Donato
pictureman4u
Geoff Hone
Are you a Nikon Camera Expert? Answer questions, earn points and help others
