Remote not changing channels
I have changed the remote control batteries but the set top box will not respond to the Remote. There are no controls on the main unit, so I am stuck on the channel it is currently on. Any suggestions?
  • Brainfixer Feb 18, 2012
    I tried to repair the remote following step 2 but its still not working.. So I am not sure if the remote is really the problem.
    Guru:
  • 1,705 Answers
1) You could get a replacement, just google "replacement remote control", you can elaborate and include your dvd player details. Here's a UK site I've used before:- http://www.avukltd.com/
2) You can try a repair, invariably with use, goo tends to build up between the keypad and the printed circuit board in the control.
Take out the batteries, look for screws, normally one at each end but the same side. Remove those and prise the top from the bottom of the remote. You may have to remove the printed circuit board as well.
The keypad needs to come away, intact. Once achieved, look at the contacts on the keypad, probably covered in a film of goo. This can be washed in soapy water, gently, then dried thoroughly, dab with a soft cloth then place on a radiator or somewhere warm for a couple of hours.
The circuit board now needs to be cleaned. I use isopropriol alcohol on a cotton bud, smells great, hugely inflammable but cleans and evaporates very quickly. If you don't have any, try a soft damp cloth and dab away at the contacts. That too has to be thoroughly dry. Then you can re-assemble the remote and try again.
Posted on Feb 12, 2012
  • dgsturt Feb 18, 2012
    "I tried to repair the remote following step 2 but its still not working.. So I am not sure if the remote is really the problem. "
    The only time I've seen this before is when a substitute or replacement remote control is being used, that being the case you probably need to enter a code before your DVD player will accept instructions.
    The only other issue, other than component failure is the infra-red sensor on the DVD player is either covered or blocked or may just need a wipe.
    I've gone on about DVD players because you posted the problem under DVD players but you mention a set top box, could it be you've a problem with a digi-box vice DVD player?
    This being the issue, try reseting the digi-box. Power off for 5 minutes, power on then, using the setup menu on the remote control reset and retune the box.
SOURCE: i have a rca dvd recorder+vcr combo drc8320n i want to set up watching/changing cabletv channels on the dvd remote. i have tried buying universal remotes cheap& expensive but they no longer work on my
With cable input connected to "RF in"on rear of unit make sure vidoe input is set to "Tuner". This will show up on the TV screen. Change channels numerically or using up/down arrow keys on DVR remote. Note there is a slight pause between changing channels.You probably will have to "autoscan" for channel setup/etc. If you say your TV set is old; it probabaly is equiped with coax
connection only/set TV channel to "3" or "4". when yot opt to play vcr/dvd it will override your
cable channel selected. Hope this helps!
Posted on May 09, 2009
SOURCE: Sunia Tv model LTD1720 Cannot change channels with remote
i need a wire of sunia tv model no.1720
Posted on Aug 26, 2009
SOURCE: my remote wont work
Try holding enter and 1 together for more than 3secs
Posted on Oct 27, 2009
SOURCE: Can't set up a magnavox ZV457MG9
What it really means is set your tv to the channel that displays the VCR/DVD palyer
Posted on Nov 14, 2009
engg_cool_bo
  • 236 Answers
SOURCE: I just got a Toshiba HDTV 40RV525R and don't have
follow this link and get the manual for ur product. i hope u will get the solution.
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Posted on Dec 05, 2009
The tv doesn't respond to remote commands. I've change the batteries. I get a slow response then nothing for a few minutes. Can't even turn volume up or down
Check the remote control for its infrared emission. Check it with fresh batteries. Check it by pressing all the keys. You can detect the presence of infra-red emission from the remote control, using a cell-phone camera. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. Surf the site with patience. In some cases, the remote control might need to clean.
http://remotesearch.blogspot.com/
Search the site by type in this key phrase "how to test a remote control "in the "search box at the top right of the display window of the Homepage" to get the related post quickly.
https://www.youtube.com/watch?v=jsSCNCW3IbQ [open and clean]
https://www.youtube.com/watch?v=Qp-l1uh-5gE [open and clean]
Jan 26, 2016 | Samsung TV Remote Control
The tv is not responding with the remote.
https://www.youtube.com/watch?v=F8oYoZslgbs
See this video to know how to open and clean a remote cotnrol.
Dec 11, 2015 | Sony BRAVIA KDL-32XBR4 32 in. LCD TV
I cannot change the channel with my MX880
Try to set the remote control; with an other code said for your device. Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://electrohelponline.blogspot.com/
Dec 29, 2014 | Universal Remote Control Universal MX880...
Television model tp2784c101 what is the remote control menu/set up to keep channel so it doesn't automatically switch to different channel after 30 seconds; or how can I set it up to turn onto AV1 an
If the TV do not respond to remote control; to change channels, there are many possibilities. Check the infrared emission of the remote control first. Check it with fresh batteries. If the infrared sensor inside the TV is faulty, this kind of fault can happen. In other words, your TV need a through check up, which a normal user can't do with ease. Contact any service technician; or the authorized service centre. Electro help
Nov 18, 2014 | Philips Magnavox 27MS343S 27" TV
No turn Chanel's manual or with the control
If you have a newer television, the remote control that came with the TV might not change the channel if you are using a set top box. Try using the cable box or satellite remote instead.
Apr 06, 2014 | Televison & Video
How to remote control three U-Verse set top boxes that are side-by-side?
If the set top boxes are identical and use the same remote control, there is no way to change things
Feb 18, 2013 | Invoca Telemania 025448 Remote Control
Harmony 880 Logitech won't change channels
Was it working before?  Is it possible you selected the wrong brand of TV when programming the remote?  Do you use a cable box or satellite dish with your TV (in other words, do you change channels by changing the channel on the TV, or on the digital box connected to your TV)?
Mar 30, 2009 | Logitech Harmony 880 Universal Remote...
Need remote control codes for the JVC Multi Brand Remote Control Unit, LP20303-018
It took me a week to find the right instructions and codes on how to do this so I am posting it everywhere I can to help out folks with the same remote. Pay close attention to the instructions, for instance when programming the remote for TV use make sure you hold the TV button down while you enter the code and then press OK, You also have to hold the TV button down while you use the volume and channel controls or it will just change the VCR channel.
A
Turn on TV
Turn on the TV using the Power button on the TV or its Remote.
B
Set TV brand code
A
Press and hold TV.
B
Press MBR SET.
C
Press the Number keys to enter your TV.s brand code.
D
Press OK, and release TV. The TV should turn off.
C
Operate TV
While holding down TV, press one of the following buttons:
POWER 1, TV/VCR, TV CH+/., ^(TV Muting), TV VOL+/.,
and the Number keys.
For some brands, you must press ENTER after having pressed the
Number keys to enter a channel number.
TV BRAND CODE TV BRAND CODE
JVC 01, 03
SONY 07
HITACHI 10
SAMSUNG 12
MAGNAVOX 02
SANYO 13
MITSUBISHI 03
SEARS 13
PANASONIC 04, 11
TOSHIBA 08
RCA 05
ZENITH 09
SHARP 06
Cable Box or DBS Receiver Brand Setting
A
Turn on cable box or DBS receiver
Turn on the cable box or DBS receiver using the Power button on
the unit or its Remote.
B
Enter brand code
A
Press and hold CABLE/DBS.
B
Press MBR SET.
C
Press the Number keys to enter your cable box.s (or DBS
receiver.s) brand code.
D
Press OK, and release CABLE/DBS.
C
Operate cable box or DBS receiver
While holding down CABLE/DBS, press one of the following
buttons: POWER 1, TV CH+/., and the Number keys.
To change the cable box.s (or DBS receiver.s) channels, press TV
CH+/–
or the Number keys. (The CH+/–
button can be used to
change the VCR.s channels only.)
CABLE BOX BRAND CODE
ARCHER 01, 05, 17
CABLETENNA 01, 17
CABLEVIEW 15, 16, 17, 21, 25
CITIZEN 15, 16, 17, 21, 25
CURTIS 02
DIAMOND 01, 17
GC BRAND 15, 16, 17, 21, 25
GEMINI 15
GENERAL INSTRUMENTS 01, 04, 06, 11, 12, 15, 28
HAMLIN 10, 18, 23
JASCO 15
JERROLD 01, 04, 06, 11, 12, 15, 28
NOVAVISION 02
OAK 07
PANASONIC 13, 14
PULSER 15, 16, 17, 21, 25
RCA 13, 14
REGAL 10, 18, 23
REMBRANDT 01, 16, 17
SAMSUNG 05, 16, 24
SCIENTIFIC ATLANTA 02
SIGMA 07
SL MARX 05, 16, 17, 24, 25
SPRUCER 13, 14
STARGATE 05, 15, 16, 17, 21, 24, 25
TELEVIEW 05, 16, 24
TOCOM 01, 04, 16
UNIKA 01, 17
UNIVERSAL 16, 17, 25
VIDEOWAY 03, 09, 22
ZENITH 03, 09, 22
DBS RECEIVER BRAND CODE
JVC (DISH Network) 51
ECHOSTAR (DISH Network) 51
SONY (DSS) 41
RCA (DSS) 40
Changing Remote Control Code
This Remote is capable of transmitting two control codes; one set
to respond to A code control signals and another set to respond to
B code control signals. This Remote control is preset to send A
code signals because your VCR is initially set to respond to A code
signals. You can easily modify your VCR and the Remote to
respond to B code signals. When using two JVC VCRs, set two
VCRs and their Remotes to different codes, so that you can
operate these VCRs separately.
A
Set remote control code for Remote
A
Press and hold A/B.
B
Press the Number key .2..
C
Press OK, and release A/B.
The Remote now can transmit B code control signals.
B
Check remote control code for VCR
Press and hold 4
on the VCR for more than 5 seconds while the
VCR is turned off. The code currently set appears on the display
panel.
C
Change code for VCR
Press any key on the Remote. The VCR now responds to B code
control signals.
To set the Remote and the VCR back to A code control signals,
repeat the same procedure as shown above except pressing the
Number key .1”
in step B
of 1
1111.
To control two VCRs with the same Remote
You can control two JVC VCRs by switching the remote control
code for the Remote between A and B (.
step A
AAAA), keeping two
VCRs to different control codes.
To change only the remote control code for the Remote, DO
NOT perform steps B
BBBBand C
CCCC.
Mar 19, 2008 | JVC RM-C18G-1H Remote Control
Set top box and remote control
I have the same problem. When I move the 8300HDC away from the TV, or power off the TV, the remote responds. There seems to be some kind of RF interference, which makes no sense since the TV shouldn't emit RF, and the the box should be using IR only for remote input. My TV is a 46" LCD Samsung. Try turning off the TV and see if the 8300HDC responds to powering on and off with the remote.
Sep 16, 2007 | Hitachi 51F710 Rear Projection Television
Televison & Video Logo
220 people viewed this question
Top Televison & Video Experts
Electro Med Services...
