Question about Sony Playstation 3 (PS3) Console
I tried to turn the system on and the controller lights on the front just blink.
The system does not respond. What is the problem? I have to hold down the power button on the front for 30 seconds before it turns off. The controllers don't respond, they just blink all 4 LED light on the front.
  • Anonymous Mar 16, 2009
    I will be in the middle of a game when all of a sudden my controller just stops working and will flash all four led lights. Then I have to reset the ps3 and sync the controller but then after a while it happens again. I have no other bluetooth devices around my ps3
  • jhastl May 14, 2009
    how do you reset the controller?
Reset your controllers
Posted on Oct 27, 2008
How to program radioshack 3 in one remote to a panasonic dvd home theater sound system sa-dm3?
hi,
try any one of the following code. if not work do the following steps to find out code.021, 107, 035, 081, 110, 162,225, 454,035, 162,051, 054, 055, 250
MANUAL CODE SEARCH
If the 3-in-One Easy Remote Control does not op-erate your remote-controlled devices when you
first set it up, you might have to manually find the correct code for your devices. you can
follow these steps to search the remote control's entire library.
1. Manually turn on the device you want to set
up.
2. Press the corresponding device key (TV,
VCR, or CBL).
3. Hold down P until the red light blinks twice,
then press 9, 9, and 1. The red light blinks
twice again.
4. Aim the remote control at the device you
want to operate.
5. Repeatedly press PWR then the device key
for the device until it responds to the command.
6. When the device responds to the command,
press P within 5 seconds to save the code.
Note: If you do not press P within 5 seconds,
the remote control does not save the code.
• Because the remote control's library has
so many codes, this procedure can take
several minutes.
• If your device turns off during the search,
but does not operate after you lock in the
code, begin the search again, pausing
longer between key presses.
Determining the 3-Digit Code
After you set up your remote control using manual code search, you can find which 3-digit code the
remote control is set to by following these steps.
1. Press the device key you want to get the
manufacturer's code from, then hold down P
until the red light blinks twice.
2. Press 9 9 0 . The red light blinks twice again.
3. Press 1 then count the number of times the
red light blinks. This is the first digit of the 3-
digit code.
Note: If the red light does not blink, the digit
is a 0.
4. Repeat Step 3 twice to find the second and
third numbers of your 3-digit manufacturer's
code, pressing 2 and 3 respectively for each
additional digit.
ok
Dec 14, 2010 | Panasonic Televison & Video
Lhv
Is the red light blinking or steady?
Have you tried to reset the tv?
System Reset
If the TV will not respond to either the remote control or the front panel controls and/or will not power Off, press the SYSTEM RESET button with a pointed item like the end point of a paperclip. The TV will turn Off and the TIMER light will flash quickly for about one minute. When the TIMER light stops flashing, you may again turn on the TV. The changes you made the last time the TV was on before you used the SYSTEM RESET button may be lost, however, the changes that were previously saved are not lost.
Try this and let me know.
Good Luck.
Apr 22, 2008 | Mitsubishi WD-62525 62" Rear Projection...
What is the comcast cable code for this tv for the digital box
Hello
Comcast remote codes for Emerson TV are:-
10154, 10451, 10236, 10463, 10180, 10178, 10171, 11963, 11928, 11913, 11911, 11909, 11905, 11665, 10282, 10280 10270, 10183, 10181, 10179 10177, 10038, 10019
You have to check with each code, until you find which code sets for your TV
programming TVcontrol
The Comcast Digital Adapter remote control is pre-programmed at the factory to operate the Digital Adapter. The Comcast Digital Adapter remote also contains a universal TV library to allow you to control the Power and Volume of your TV.
1. Turn on the TV
NOTE: Please read steps 2 to 4 completely before proceeding. Highlight or write down the codes and device you wish to program before moving on to step 2.
2. Press and hold SETuntil the Red Light blinks twice, then release SET.
3. Locate the code for your device in Manufacturer's Codes on the back of this user guide. Brands are listed in alphabetical order with the most popular codes listed first.
4. Enter the first five-digit code for your TV. If you perform this procedure correctly, the Red Light will blink twice
NOTE: If you enter an invalid code, the red light will display one long blink and exit the programming mode. Repeat steps 2 to 5 with a valid code.
5. Aim the remote control at your TV and press Power once. The device should turn off. If it does not respond, repeat steps 2 to 4, trying each code listed for your brand until you find one that works. If it still does not work, try Searching For Your Code.
If your brand of TV does not respond to the remote control after trying all of the codes listed, or if your brand is not listed at all, try searching for your code.
1. Turn on your TV.
3. Enter in 9 - 9 - 1. The Red Light will blink twice.
4. While pointing the remote control at the TV and press and release the CH + key until the TV turns off. (Note: You may need to press [CH+] numerous times).
NOTE: In the search mode, the remote control will send IR codes from its library to the TV.
5. Press SETonce to lock in the code. The Red Light will blink twice.
OK.
Dec 03, 2010 | Emerson EWC1303 13 in. TV/VCR Combo
62HM15 Toshiba DLP TV won't respond to remote or control panel
Blinking is a trouble code. Try unpluging for a longer time then hold power button in when pluging back in to try and reset.
Mar 15, 2010 | Toshiba 62HM15 62" Television
Need codes for rcr 460 remote
1. Manually turn on the component
you want the remote to control
(TV, VCR, DVD, satellite receiver
or cable box).
Note: If you press an invalid key
during the Manual Code Search,
the remote does not respond and
the LED indicator light does not
blink. If you do not press a valid
Manual Code Search key (TV,
VCR, DVD, SAT·CBL, ON·OFF,
GO BACK), the search times out
after two minutes. When the
search times out, the LED
indicator light blinks four times
and turns off. The last
programmed code under that
component key is retained.
2. Press and hold the component key
(TV, VCR, DVD, SAT·CBL) you
wish to program. The LED indicator
light turns on and remains on.
3. While holding the component
key down, press and hold the
ON·OFF key. The LED indicator
light turns off.
4. After holding down both keys
for three seconds, the LED
indicator light turns back on.
5. Release both keys. The LED
indicator light remains on.
Throughout the
programming of each key, be sure
to keep the remote pointed at the
IR sensor of the component you
are currently programming the
remote to control.
6. Press and release the ON·OFF key
repeatedly until your component
turns off. Each time you press the
ON·OFF key, the LED indicator
light blinks, and the next code in
the list is sent. This process
continues until all of the codes in
the Code Lists have been searched.
If your component turns off, you
have found the correct code. (If it
cycles through and the LED
and turns off, all codes have been
searched. The Manual Code Search
method is exited.)
Press Stop when TV turns off.
Mar 06, 2010 | RCA Universal Remote Control
My Bose 321 series II is not responding to the control remote commands!
You need to test the remote, in a low lit room try using your remote real close in front of a digital camera or video camera, hold the remote button down and look at the LCD screen of the camera, you will see blinking LED's if its working, (Dogs can see this light all the time I think) if you see the infrared beam in the digital camera image its working or transmitting.
Oct 27, 2009 | Audio Players & Recorders
Sentry RMC-10 remote can't 'discover' my tv's code
.there are several codes. try each one seperate.
1. press and hold setup button until the red light stays on.
2. press and release the desired mode button (example t. v.) the light will blink and then stay on.
3. enter one of the 4digit codes.
note: if the code is valid the light will turn off if it flashes it is an invalid code.
4. with the device on press the channel up and down. if the remote only controls some of the functions try another code.
CODES:1171,0116,0167,0176,0922
1.manually turn on the t.v.
2.press and hold the setup button.
3. press and release the tv button the light will blink once and then stay on.
4.press the channel button repeatedly up to 300 times until the device changes channels. the light will blink and then stay lit.
5. press and release the mute button to store the code the light will go off.
Aug 28, 2009 | Sentry SE-RMC10 Remote Control
I'm missing the instruction manual for my RCA RCR460 remote control. I need the manual set-up instructions, and a list of all the potential codes to sync up to a Toshiba or Mitsubishi DVD player. Any help...
1. Manually turn on the component you want the remote to control (TV, VCR, DVD, satellite receiver or cable box). Note: If you press an invalid key during the Manual Code Search, the remote does not respond and the LED indicator light does not blink. If you do not press a valid Manual Code Search key (TV, VCR, DVD, SAT·CBL, ON·OFF, GO BACK), the search times out after two minutes. When the search times out, the LED indicator light blinks four times and turns off. The last programmed code under that component key is retained. 2. Press and hold the component key (TV, VCR, DVD, SAT·CBL) you wish to program. The LED indicator light turns on and remains on. 3. While holding the component key down, press and hold the ON·OFF key. The LED indicator light turns off. 4. After holding down both keys for three seconds, the LED indicator light turns back on. 5. Release both keys. The LED indicator light remains on. Throughout the programming of each key, be sure to keep the remote pointed at the IR sensor of the component you are currently programming the remote to control. 6. Press and release the ON·OFF key repeatedly until your component turns off. Each time you press the ON·OFF key, the LED indicator light blinks, and the next code in the list is sent. This process continues until all of the codes in the Code Lists have been searched. If your component turns off, you have found the correct code. (If it cycles through and the LED indicator light blinks four times and turns off, all codes have been searched. The Manual Code Search method is exited.) Press Stop when TV turns off.
Jul 06, 2008 | RCA RCR460 Remote Control
Se-d1 will not boot
escient music server...light blinking red...
cant turn on system...
tried resetting...nothing
tried turning system off..for a hour or two...nothing..
juse blinks will not respond to anything...
any ideas.
Jun 28, 2008 | Digital Products Escient SE-D1 FireBall...
Sony Playstation 3 (PS3) Console Logo
1,085 people viewed this question
Top Sony Video Game Consoles & Games Experts
Iron
Iron
Troy Gorman
Troy Gorman
shaun taylor
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
