Question about Roper RT21AKXKQ Top Freezer Refrigerator
Roper rt21lmxkq01 defrost timer
Refrigerator and freezer warm
dididsaythat
  • 291 Answers
SOURCE: roper refrigerator 2002year
Things to check
Check freezer...
for Frost build up and if Fan is blowing,
Check condenser...
To make sure clean, and the fan is blowing by compressor,
Check Recirclating Vents in refrigerator... to make sure theres no blockage,
CONTROLS ...should be in the middle setting,
Posted on Oct 12, 2007
SOURCE: ROPER RS22AQXMQ SIDE BY SIDE REFRIGERATOR PROBLEM
I had the same problem with a top freezer. I found that the thermostat was bad by tapping on the it at the setting knob. The defrost timer was replaced first which did not help (repairman put in a timer for a Frigadair which will not work in a Roper). If one is used for a frigadair as soon as it cycles it will not work again until it is unplugged and allowed to reset. I replaced both the thermostat and the right defrost timer. It has worked great for over 2 months.
Hope this helps.
Posted on Dec 01, 2008
localwonder
  • 6784 Answers
SOURCE: roper refrigerator freezer not freezing and bottom not cold
This is a compressor issue. Its probably done.
Posted on Feb 14, 2009
SOURCE: Need to install defrost Timer
Check the following link for internal diagrams for this model
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=251062
On the left side bottom in "search by keyword" enter "defrost timer" and the display will show you the location and the part name in the diagram.
Please do rate my solution also please do post your comments on this solution.Good luck.
Posted on Apr 08, 2009
heatman101
  • 43501 Answers
SOURCE: Roper Refrigerator. No ice maker.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Posted on Jun 20, 2011
My roper refrigerator freezer ices up and the fridge is not cold. Model RT14BKXKQ05
You have a defrost problem, could be the timer not advancing, bad thermostat for the defrost system or an open heater. All of these items will cause this issue you have. the only way to find out is to test all the items. If I have to guess, I would replace the thermostat first, but its a guess as I am unable to test them. Good Luck
Mar 31, 2016 | Roper Refrigerators
Roper refrigerator warms and freezes
More than likely, you have a failed component in the defrost system. Call a good, reputable, service company. You do not need to replace this refrigerator.
Oct 01, 2014 | Whirlpool Refrigerators
My Roper refrigerator stopped getting cold, although the refrigerator lights and the fan in the freezer works. What is the problem?
If the freezers warm, possible defrost timer bad, if freezers cold, set to middle setttings on both dials, the 1-10 OFF dial operates the compressor, the COLDER/WARMER dial operates the flapper door that regulates freezer air into the reefer box, if set to max cold that makes cold freezer, not reefer.
Nov 01, 2010 | Roper RT21AKXKQ Top Freezer Refrigerator
Roper top freezer works but not the bottom
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 16, 2010 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
Refrigerator cold ice on ceiling no air to refrigerator and its warm the fan not turning
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
Sep 19, 2010 | Roper RT21AKXKQ Top Freezer Refrigerator
Ice build up in freezer...Auto Defrost not working Model unknown...smaller model...about 5 feet tall...2 feet wide...freezer on top..no ice maker. Bought in 2002....noise during defrost quit about 2 months...
If it is a magic chef the model number will be on the back of the fridge and will have to order the exact defrost timer for this model. Only place to get will be from repairclinic.com
Jan 31, 2010 | Roper Refrigerators
Roper stopped working
Your defrost timer is bad. The defrost timer motor probably quit in defrost mode, thus no power to the compresser
Mar 30, 2009 | Roper RS25AEXLQ Side by Side Refrigerator
I have a fairly older model Roper....lately it has been freezing up, then rapidly defrosting in the freezer. Also the Refridgerator section stays like warm....I have been told that the defrost timer is the...
It may be the timer and it also may be the defrost terminator they are both common repairs. the terminator is in the freezer section behind the back panel. It is a small 1"round part with 2 or 3 wires going to it and it clips on the evaporator tubing at the top. both are not much money to replace and it would be worth replacing both parts for future problems.
Nov 30, 2008 | Whirlpool ER6AHKXPQ Top Freezer...
Hope this helps.
Sep 10, 2008 | Roper RS22AQXKQ Side by Side Refrigerator
Frig shut off
my 7yr old roper refrigerator top freezer stopped cooling and freezing but the light was still on with no fans. I dropped the thermostat cover and jumped the thermostat wires,no help . then i removed the wiring harness from the defrost timer and jumped the #1and #4 .She kicked off. I then replaced the defrost timer and it is running fine now
Jul 16, 2008 | Roper RT21AKXKQ Top Freezer Refrigerator
Roper RT21AKXKQ Top Freezer Refrigerator Logo
Top Roper Refrigerators Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
