Question about Kenwood Heating & Cooling
Wiring diagram for oil filled heater - Kenwood Heating & Cooling
2 Suggested Answers
Natemane
SOURCE: ROCKER SWITCH DIAGRAM
On the top of the switch (inside the heater) there is a common connection.....even though it looks as if it is connected (electrically), it isn't electrically affected by the switch; it's just used as a post. It's just the place where the striped wire connects to the "common" point for the heater coils (they are in a parallel). Also, while you're in there you might want to put some electrical grease on the exposed conductors.....mine had quite a bit of corrosion (which was the reason for the failure). I had to replace 3 of the female connectors.
Posted on Jan 01, 2010
POWER IS ON--LIGHT ON, BUT DOES NOT HEAT UP
Check to see if the heating element has continuity or if it is even receiving power.
Mar 05, 2016 | DeLonghi TRD0715T Oil Filled Radiator...
My Lakewood heater turns on but will not produce heat. Any ideas as to what is wrong????
Same symptom on my oil-filled Lakewood model 5500. Used an ohmmeter to check it out and found that 1) the thermostat is defective and potentially a fire hazard due to intermittent operation. 2) Then I learned of reports about some Lakewood oil-filled heaters squirting hot oil and injuring people, and 3) the manufacturer subsequently going out of business. Three strikes and you're out.
I cut off my heater's power cord and threw the whole thing away, and recommend others to do the same.
Feb 07, 2011 | Lakewood Oil-Filled Electric Radiator...
I am looking for the wiering diagram
mrh68,
Try this site http://www.reddyparts.com . They have any parts, service literature and most wiring diagrams.
Thanks for using FixYa and for the great rating. Please consider a testimonial. Thank you.
hardrocko
Jan 24, 2011 | Dayton E51 Oil Filled Utility Heater
Lakewood heater 7101 schematic
The power cord goes the switch terminal 1 and 3.
Terminal 2 must be the opposite of terminal 1, such that when switched on, 1 & 2 connects. Terminal 4 must be the opposite of terminal 3, such that 3 & 4 connects.
Under this setup, you may connect red to terminal 2
and black to terminal 4.
Be sure of the 1 & 2 pair, as well as the 3 & 4 pair.
then, connect the red and black wires.
Hope this will help you.
Jan 06, 2010 | Lakewood Oil-Filled Electric Radiator...
Need wiring for on-off switch
Hi Joe. Typically the switch interrupts the hot wire, which is black. Therefore, two black wires are connected to the two screws on the switch. Look in the area where you see the one black wire and you should find a second black wire. Connect each of the to the switch and you will be switching [controlling] the hot [black] wire.
Dec 10, 2009 | Lakewood 7101 Oil Filled Radiator Heater
Oil heater not working
Request a wiring diagram from DeLonghi
Jul 15, 2017 | DeLonghi 9707 Oil Filled Radiator Heater
I need a wiring diagram for a lakewood 5500
Visit this page for service center info and or parts: they should be able to help you http://www.lakewoodeng.com/html/parts.html
Feb 13, 2009 | Lakewood Oil-Filled Electric Radiator...
Aug 27, 2008 | Lakewood Heating & Cooling
Delonghi TRN1015T wiring diagram
Just wondered how you learned to turn off the timer.
Jan 10, 2008 | DeLonghi TRN1015T Solaris Oil-Filled...
Heating & Cooling Logo
110 people viewed this question
Top Kenwood Heating & Cooling Experts
ray gallant
Electro Med Services...
Are you a Kenwood Heating and Cooling Expert? Answer questions, earn points and help others
