Question about Makita EM4251 16" 4 - stroke String Trimmer
Excessive oil coming from crankcase breather hoses on the makita trimmer 4 stroke engine
3 Suggested Answers
chico809876
  • 90 Answers
SOURCE: makita 4 stroke
not sure if there is a carburetor kit out there for that machine, but it sound like your having fuel issues, would suggest a rebuild kit or replacement..
Posted on Dec 14, 2011
chico809876
  • 90 Answers
SOURCE: Makita gas trimmer RBC221. engine runs fine but
would suggest that the cable that runs the head is broken or there is too much material wrapped around the head... remove the engine off the trimmer and check the cable that runs to the head....
I have a cb900 have got exessive smoke coming out of crank case breather and a lot of oil
Hi, Stephen if you are experiencing excessive oil coming out of the crankcase breather or air filter please drain all engine oil and replace half of the same oil that comes out. Many riders are over filling their oil system because they do not know how to properly read their oil site glass or dipstick. The following procedure works on nearly all 4 stroke engines but to be on the safe side you should refer to your owners manual. Use your center stand if you have one.
1. Bring the engine up to operating temperature or let idle for 5 minutes.
2. Turn off your engine and let it sit for 2 minutes, this will allow the oil from the top end to drain to the bottom.
3. Hold your bike straight up or on the center stand and wait 2 minutes for the oil in the bottom of the engine to be level in the sight glass or on the dipstick.
4. Your oil level should be between the top full mark and the bottom add mark.
5. Never over fill your oil system it will cause problems:
a. oil leaking out of exhaust pipes.
b. oil leaking out of breather pipe/hose.
c. oil carryover into the air cleaner.
6. Your oil site glass must "NEVER" be completely full or empty drain or add oil as necessary.
7. Your oil dipstick must "NEVER" be over the full mark and should never be below the add mark drain or add oil as needed.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
smoke coming out of crankcase breather tube
gl1800riders com
Honda CB900F Service Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda CB900F Owner Manual
Aug 16, 2017 | Honda CB 900 Hornet Motorcycles
Excess white smoke coming from exhaust of TB 75SS string trimmer
This model is a four cycle engine meaning that it does not a mix of gas and 2 cycle oil. You just fill it like your lawn mower, gas and fill the crank case with oil
May 25, 2009 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
I have an 18hp gxv610 honda engine that oil is coming out the crankcase breather tube while running. Any thoughts on why?
two possibles come to mind
excessive oil level in the sump
worn rings causing excessive blow by that is taking oil vapor out the breather as it escapes to the air
Mar 03, 2016 | Honda Motorcycles
I have a 1989 Yamaha radian 600. Do they have oil leak problems where oil would come out while riding on back tire.
It may have a crankcase breather hose/port around the back end of the engine which allow the lower engine to breath. If the engine has been over filled with oil/the breather hose lose/broke, or has excessive blowby (bad rings), the engine will push oil out. Most 4 stroke motorcycles are not designed to stay with the front end in the air for long periods of time or the engine will run short of lubrication and eventually fail. If you want to keep the front wheel up the engine will have to be modified so that it can lubricate while the front wheel is up otherwise it will cause damage!
Nov 17, 2014 | 1989 Yamaha YX 600 Radian
1986 Honda XR 600 R engine oil is blowing out the breather hose
Hi, Anonymous if you are experiencing excessive oil coming out of the crankcase breather or air filter please drain all engine oil and replace half of the same oil that comes out. Many riders are overfilling their oil system because they do not know how to properly read their oil site glass or dipstick. The following procedure works on nearly all 4 stroke engines but to be on the safe side you should refer to your owners manual. Use your center stand if you have one.
4. Your oil level should be between the top full mark and the bottom add oil mark.
5. Never overfill your oil system it will cause problems:
xr600 oil out of crankcase breather
Xr650r Blowing Oil Out The Crankcase Vent
1985 2000 Honda XR600R Dirt Bike Service Manual Moto Data Project
http://mybikemanuals.com/honda/honda-xr-owners-manuals
Sep 10, 2013 | 1986 Honda XR 600 R
Oil and fuel blowing out through top of motor in yamaha golf cart 4 stroke engine
Engine got to much oil in it? Worn engine allowing fuel down into engine diluting the oil and raising the oil level? Blocked engine breather, pressurising the crankcase. Oil change and clean the breather. Worth a try
Jan 10, 2013 | Yamaha G1 G-1 2-cycle Gas Golf Cart Tune...
2005 Honda Unicorn oil leaking from crankcase breather tube
Hi, Anonymous and the usual suspects are:
1. Oil tank/system overfilled.
2. Faulty breather valve.
3. Engine breather hose bent, pinched, kinked etc.
4. Air filter has too much "pre-oil".
5. Crankshaft seal failure allowing transmission fluid to migrate.
6. Blow by drain tube cracked/split or filled to capacity.
For more information about your question and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
2005 CRF450X oil coming out crank case breather tube
Crankcase breather tube Modification Honda Shadow Sabre
HONDA UNICORN CBF 150 BIKE WORKSHOP SERVICE REPAIR MANUAL Download Manuals... $15
https://www.partsfish.com/page/oem-parts-for-honda
Honda CB UNICORN DAZZLER 2010 Owner Manual
May 28, 2012 | 2005 Honda Unicorn
OIL leaking from my breather hose on top of the crankcase on my ttr 125
Hi, Anonymous oil level readings are taken when the engine has reached normal operating temperature and the usual suspects are:
1. Overfilled oil tank dipstick reading should at or below full.
2. If the sight glass is full you are running to much oil.
3. Excessive blowby caused by worn out piston rings.
4. Piston rings never properly seated.
5. Faulty breather valve or system.
6. Pinched or clogged breather line/hose.
7. Clogged or failed oil filter.
8. Contaminated oil dirt-rust-water etc.
9. Excessive oil foaming.
10. Wrong oil type not designed for your bike.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a wonderful day.
http://www.raptorforum.com/forums/66-raptor-660-maintenance/17542-help-oil-coming-out-crank-case-breather-help.html
Spitten Out Oil
YAMAHA TT R125 Owner Service Manual
OEM parts for Yamaha
YAMAHA TT R110E Owner Manual
Apr 07, 2012 | 2007 Yamaha TTR 125 LE
Oil is getting on air breather 2004 ram hemi
oil getting on a breather can indicate excessive crankcase pressure. Check all the `crankcase breathers and the valve cover breathers.
if the crankcase has been overfilled with engine oil. The crankshaft has to "beat" it's way through the oil and thus acts as a pump and sends oil all over the internal surfaces of the crankcase.
If the engine cylinders have developed 'blow-by" they will also contribute to an increase in crankcase pressure which will be evident by oil in the breathers. The fumes / pressure in the crankcase are designed to be removed by the engine breather system, and drawn through the engine etc.
I hope this info helps.
Jan 25, 2011 | 2004 Dodge Ram 1500
My 95 xr600r dirt bike leaks oil
This hose should be connected to the air filter box.
It's for ventilation of the crankcase, much like the PCV (Positive Crankcase Ventilation) in cars. As the bike runs, the crankcase gets hot enough to vaporize some of the oil. And since there's always at least a little bit of combustion blowby in the cylinders, you get a bit of fuel/air thrown into the mix and an oil/fuel/air "atmosphere" in the crankcase, which isn't an ideal situation. So, when the hose is connected to the air filter box, it slightly vacuums off this atmosphere, letting the engine burn it and expel it through the exhaust.
If it's not connected to the airbox, the vapors can condense back to oil and just drip out.
If a lot of oil is coming out ("a lot" is hard to quantify), you could be getting excessive blowby because of a broken ring or cracked piston.
Hook that breather line back up to the airbox and unless the bike smokes excessively, I wouldn't worry about it.
If it IS hooked up, it or the airbox is cracked and needs fixing/replacing. If the breather line has somehow become plugged (mud-daubers are amazing at finding holes to makes homes out of), the pressure buildup could have split your vent line.
May 11, 2010 | 1995 Honda XR 600 R
Makita EM4251 16" 4 - stroke String Trimmer  Logo
Top Makita Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Makita Measuring Tool and Sensor Expert? Answer questions, earn points and help others
