Question about Hardware & Accessories
Instructions to set up ge digital timer #15313
Wall timer
SOURCE: Grasslin Digital wall mounted timer programme setting instructions please
pdf file link, instructions will say it is for a topica500 also known as a logica 500.
Hope this helps.RoyG
Posted on Mar 09, 2009
SOURCE: Need to re-set time on Salter digital timer
If it's the same as ours (clock button top left, clear bottom left):
  1. press and hold clock until the clock starts to flash
  2. set time using h/m/s keys
  3. press clock again
Hope it works
Posted on Nov 01, 2009
SOURCE: The Sylvania SA170 digital wall timer did not come
visit www.hardwareinnovations.com, all manuals are online
Posted on Jun 01, 2010
SOURCE: GE Indoor In-Wall Smart Digital
The timer is wired incorrectly.
ON the GE timer and Utilitec timer: The red and black wires are reversed.
On the Intermatic ST01C
Posted on Oct 13, 2010
SOURCE: Can GE Digital Timer model 15086 be used for two way switch?
GE 15086 can replace single pole switch only.
If you have "3-way" switch, that is when 2 switches control same light, for example in a hallway.
Open link below to identify GE15086 timer, see wiring instructions, on-line manual <> and see list of timers that can be used for 3-way switching with links to those timers and manuals:
http://waterheatertimer.org/GE-timers-and-manuals.html#15086
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Jan 27, 2011
How do I program defiant 470-906 timer
http://waterheatertimer.org/GE-timers-and-manuals.html#15313
Follow steps in manual?
Be careful, this timer is not rated for heavy-duty.
No neutral wire needed.
Gene
Oct 11, 2014 | Hardware & Accessories
HI,I installed a GE digital timer model 15313 about two years ago.Now cannot turn on or off manually or program it. But it does turn on and off the times I programed the last. Thanks
Try reset and reprogram
If functionality is not restored, then replace timer.
Note also the load rating for each timer.
If you are operating above or outside the load parameters for timer, then timer might not function correctly or function as long as expected.
This timer, and most timers have 1 year warranty.
Suggest replacing with 5-year warranty Ei600
Can operate any load value, LED fluorescent incandescent motor
Has dawn-dusk or programmable mode
http://waterheatertimer.org/Programmable.html#st01
Gene
Sep 02, 2014 | Hardware & Accessories
Need instructions for a defiant brand digital indoor wall timer model 49815
http://www.jascoproducts.com/products/pc/GE-Timers-c35.htm
Apr 16, 2013 | Hardware & Accessories
The timer has 3 wires, blue, black and green and the wires from the outlet after I removed the original switch are 2 black and one red. How should I connect the new timer? The timer is a GE 15313.
There are 2 different timers: 15313 and 15312
15313 has Black Blue and Green wires
15312 has Black Red White and Green wires
1) Your Switch has 3 wires: sounds like a 3-way switch at each end of hallway.
The 15313 timer cannot be used to replace 3-way switch
http://waterheatertimer.org/GE-timers-and-manuals.html#15312
2) Buy GE 15312 timer for 3-way switching.
http://waterheatertimer.org/How-to-wire-GE-15312-timer.html#3-way
3) GE 15313 is for single-pole only, and rated for incandescent lights only and will not work for CFL, LED bulbs, or other inductive loads.
4) GE 15313 timer will work for single-pole or 3-way, and work with any type of bulb, or load up to 100 feet away.
Dec 20, 2012 | Hardware & Accessories
GE digital timer 15313 has 3 wires, black, blue and green. Wall switch wires have bare, black, red and white from one line, and black and white from the other line. I've tried every combination
It sounds like you are replacing 3-way switch.
Low voltage light? Are these lights connected to 120Volt circuit?
I think you want the GE 15312 timer, instead of GE 15313.
GE 15313 is for single-pole incandescent light bulbs only.
This is live answer 11-2012
Add a comment for more interaction on answer.
Nov 22, 2012 | Hardware & Accessories
Wall light switch timer inline with Extension cord GE 15313
Black to black (hot), Green to green (ground) and the only one left is of course white to blue. The (neutral) white wire can be many different flavors (blue, red, orange, brown, etc.).
If the outlet your plugging into (or controlled by the service panel breaker) is 15 Amps use a minimum of 14 gage wire (or 12 gage is even better), if its a 20 Amp outlet use 12 gage wires (or 10 gage). Don't use a 16 or 18 gage wire because it may get hot and start a fire because its undersize for the Amps.
Nov 13, 2012 | Hardware & Accessories
Replace et724-A with new digital timer 15313
You are install GE 15313 timer
Open following link to identify timer
15313 timer does not require Neutral wire.
The timer you are replacing has neutral wire (White wire)
So replace timer wires 1:1 except do not connect timer to white neutrals.
Keep in mind the 15313 is for incandescent lights only and is not for CFL or LED lights.
If you want timer for CFL, then install one of the other timers shown on page.
Apr 29, 2012 | Intermatic Inc. EJ500C Digital Wall Switch...
I just installed a GE Smart Digital Timer. After I programmed the timer and went to manually turn on the light the light started to click on and off and the timer ticked?
Timer wiring instructions shown on following page:
http://waterheatertimer.org/GE-timers-and-manuals.html#15071
You connected the white wire and red wire together, and that is why lights are clicking on-off.
I test timers and have done this intentionally during testing.
Follow instructions shown on link above, and GE timer will work correctly.
Same wiring applies to Tork, Swilight, Utilitec, Woods, Leviton, Intermatic non-battery operated timers.
Instructions are different for Aube, Brinks, UPM and Intermatic battery operated
Dec 28, 2010 | Intermatic Inc. ST01C Digital In-Wall...
My GE smart digital timer keeps flashing I need help to rewire this
You posted under GE timer.
Open following link to identify timer and see manual and written wiring instructions:
Most in-wall timers are wired the same way except timers listed on page that work for 3-way switching.
Dec 20, 2010 | Intermatic Inc. ST01C Digital In-Wall...
GE smart digital timer was installed according to instructions. Timer was set to turn lights on at 5:30, and the lights blink on and off but will not stay on. I tried reprogramming, but same result. ...
It sounds like wiring is wrong.
If you have GE Tork Intermatic UPM Woods Brinks Hagar Pass-n-Seymour Stanley Westek in-wall timer, with red, black, white and green wires, then you probably put red and white wires together.
Add a comment any time.
See instructions along with image at following link:
http://waterheatertimer.org/Program-wire-Utilitec-0192773.html
Heres how to wire timer
1) Timer-green-wire connects to bare ground wire.
2) Switch has 2 wires. Take switch wires and connect them to timer-black-wire and timer-red-wire. Choose either one for now.
3) In back of electric box are white wires twisted together and covered with wire nut. Connect timer-white to these wires.
4) If electric box does not have white wires described above, then connect timer-white to bare ground, along with timer-green wire.
5) Turn on electricity, and push ON-OFF button > with GE timer, door is push-button switch. If lights come on, timer is wired correctly. If lights do not come on, then reverse timer-red and timer-black wires.
Dec 11, 2010 | UPM Programmable Wall Switch Timer
Hardware & Accessories Logo
550 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
