Question about Humidifiers
Why does My bionaire steam mop makes a clicking noise when I turn it on
Heat up but when I turn the motor on to produce the steam it makes a clicking noise
3 Suggested Answers
SOURCE: My bionaire CM1 makes bubbling sound every other minute
Yes, mine does that too. It got very annoying and I couldn't sleep. I noticed some calcification inside and gave it a rinse. I don't have the manual on cleaning it but after I did that it's much quieter. I think you should try cleaning it.
Posted on Jan 15, 2009
SOURCE: Spitting noises and gushing water
Sounds like it needs a good cleaning. Use 1/2 c. regular vinegar to 3-4 cups regular water and let soak for a few hours. Remove and tap the steamer to remove caked up sediment. Should be ready to use again. If it's a little slow, add a small pinch of salt.
Posted on Feb 11, 2010
I need a manual
Try google.
Humidifiers Instruction Manuals at Bionaire.com.
www.bionaire.com/...manuals/humidifiers/humidifiers-manual.html
Browse our Humidifiers Instruction Manuals to find answers to common questions about Bionaire® products. Click here to view on our FAQs now.
[PDF]Crane Owl Cool Mist Humidifier Owners Manual - Sylvane
Dec 18, 2015 | Humidifiers
When I turned on my ultrasonic humidiifier it worked for 10 sec, then I observed the water coming through the bottom. When I removed the tank and the bottom full with water. How can I fix this?
Bionaire BWM401 leaking - YouTube
? 0:39
https://www.youtube.com/watch?v=Gy7VKJJeb3o
Jan 20, 2013 - Uploaded by urhorh
My Bionaire BWM401 leaking through the bottom. ... Review ofBionaire Cool Mist Humidifier BCM7932P-CN from Costco HD - Duration: 1:41.
Nov 28, 2015 | Bionaire Humidifiers
We have a water softener and I think the water has too much salt and therefore, our Vicks vaporizer has too much steam. Any suggestion?
If your softener is working properly, you should never get any salt in your water. The salt is used only to reactivate the ionic media in your softener cartridge, and during the backflush cycle, all that salt is removed, down to PPM (Parts Per Million) levels.
In any case, even if you used salt water in your vaporizer, it would not increase the amount of steam that it produces. Salt water has a higher boiling point than fresh water. You would also notice salt buildup inside the tank as the water level goes down.
The Vicks Vaporizer works by using only heat to produce steam- the hotter it gets, the more steam it makes. The only practical way to get too much steam outside of a malfunction that causes your heating element to get abnormally hot would be if you live at a very high altitude where water boils at a lower temperature.
High humidity in your home will make it appear as if your vaporizer is making too much steam since the surrounding air will be less capable of absorbing it.
A slightly "off topic" note- if you chose the Vicks Vaporizer/humidifier and have children, you have made a wise decision. Because it produces water vapor by heating instead of ultrasonics, contaminants and minerals (such as salt, iron, calcium, etc.) remain in the tank and will not enter the vapor stream.
Mar 25, 2011 | Vicks Warm Steam Vaporizer 1.5 Gallon...
Where can I purchase a replacement filter for a bionaire BCM 1250
If you perform a GOOGLE search...type in "Bionaire BCM6010 Humidifier filters".
Also, here is a link I found on GOOGLE.
http://www.humidifierfilters.com/bionaire/filters.html
Good Luck
Oct 05, 2010 | Bionaire BCM6010 Humidifier
No steam output
Dec 06, 2009 - found solution: if unit is truely clean, unplug unit then mix about a teaspoon of iodized salt (table salt) to the water. Reconnect unit wait about 1 - 2 minutes, unit will start to make a grinding sound but shortly after steam will produce.
Nov 13, 2009 | Vicks Warm Steam Vaporizer 1.5 Gallon...
Gurgling sound
the gurgling noise is the water going into the base. since you haven't used it in so long your going to hear some weird noises at first then they should go away. but before using it make sure that all dust particals and everything is cleaned. if you have any more problems please let us know.
Jan 27, 2009 | Bionaire W9U Humidifier
Dec 16, 2008 | Bionaire CM1 Humidifier
Humidifiers Logo
51 people viewed this question
Top Humidifiers Experts
Mack Baxter
Dennis
Are you a Humidifier Expert? Answer questions, earn points and help others
