SOURCE: HP Designjet 5500 carriage belt is off the pulley
go to a store and ask them for to put it in it place again
SOURCE: I am getting a system error 0C003200000003
System Error: 0C0032 (Continuable)
Problem
Description:
Drop Detector not Calibrated for all Printheads.
Corrective Action: Try the following:
n Perform the Service Station Calibration þ
n Replace the Drop Detector Assembly þ
n If the Error Code continues, replace the Electronics Module þ
WARNING Only replace one component at a time and check if the error has
gone before replacing another component. Using this procedure
you will be able to determine exactly which component failed
this is a continuable error.
SOURCE: how to reples belt HP Designjet 5500
Good luck finding HP ASP's anymore since HP jacked us all around in spring 09 and killed most of us off for not bowing to their extortionist methods to get sales up. Anyway I've been doing these since they came out, all I took was an online certification test before Hp started charging for them. Open book test, it's not a big deal but an amount of skill on Designjets and knowing how to properly use the service manual is necessary - Sheri is right that if you botch the job you'll botch the plotter.
To ajitkadam37if you want to see the procedures to replace the belt just download the manual. DONT get sucked into buying a pirated PDF from some schmoe on eBay. Go to Feedroller.com and down the left navigation bar near the bottom there's a place to go to the manuals. When you are there click HP then go to the Designjet area and find the 5000/5500 service manual. Once you have it you can see the procedure - even if you don't repair it yourself, you at least know in advance if a repair company is trying to jack you around and make it more expensive. Also check the HP Parts store for the list price on the belt - many dealers should be drug dealers with making parts 400% and higher than list. I'm all for making a living but damn some of these places are one step from scam artists (Sheri likely will agree that some of our colleagues are bandits). New belts usually last much longer than the old rubber and cord belts - the replacements are nylon and other synthetic materials. My 2002 DSJ 800PS got a belt in 2004 (I put it in when it was owned by the previous who was my client) as it was shredded and crumbling - the belt was the factory belt. The new HP belt made of synthetics is now 6 yrs since it was installed and still looks like new even running daily.
At least read up on the procedure and you can decide for yourself if you want to tackle the job, or let someone else do it for you.
SOURCE: Hp designjet 5500 system error
Hi...Pls check the cable from iss to supply st is correctoly connected.
APS may be faulty,check replacing the APS if error continues then the problem in main pca replace them .
your problem may be resolved 100% .
SOURCE: i have HP designjet
An '0x ...' Error Message Displays on the Front Panel When Printing HP Photosmart C5380 All-in-One Printer - HP Customer Care (United States - English). If
you need more help come back. Post
/ thumbs / testimonial are welcome!
