Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Install 41A4315-7D logic board Sears craftsman 1/2hp
  • 3197 Answers
SOURCE: I have a sears craftsman door opener. I replaced
There isn't a reset code. It sounds like you may be having a door sensor problem. Is the small light on each sensor lit and not blinking ever so slightly? Does your door start down and then reverse to the open position? Is the door stuck in the open position? Check to make sure the trolley isn't jammed against the bolt just in front of the motor unit. If it is then remove the bolt and run the door until closes. Then adjust the up limit on the side of the motor unit. Turn it in the opposite direction of the arrow printed on the cover about 3 turns. Be sure to then replace the bolt.
Posted on Jun 04, 2009
  • 3197 Answers
SOURCE: Craftsman 41A4315-7D. Door opens only 2 inches
Check the door springs. One may be broken. You may have a bad drive gear which is a nylon gear just in front of the motor. Remove the cover and take a look. It will be obvious if it is stripped.
Posted on Nov 15, 2009
Testimonial: "Right on DonO It is a broken spring! Do you have a rough est of repair cost?"
swolfinor
  • 504 Answers
SOURCE: Garage door won't move
goto http://www.garagedooropenerguide.com/installationmanuals.html
download the pdf for the unit that is closest to what you have, go thru the diagnostics.
Hope this helps
Posted on May 29, 2010
  • 3197 Answers
SOURCE: Ocasionally my garage door will open by it's self,
Look at the LED light next to theSMART/LEARN button on rear of the motor unit. You may need to removea light lens cover in order to see it. If the light is flashingrapidly this means you have a stuck button on one of your remotecontrols. Take the batteries out of each remote control. When youremove the batteries from the bad remote, the light will stopflashing. This remote needs to be replaced.
If one of your neighbors remotecontrols is inadvertently programmed into your receiver, you doorwill open when their remote is activated. If this happens you willneed to clear out your receiver and reprogram your remote controls.Press and hold the smart/learn button for 6 seconds or until you seethe small LED light near the button turn itself off. If the abovesteps have been followed and the symptoms continue, there may be anelectronic short in either the wall control button or the receiverlogic board. In this case, remove the wall control wires fromterminals 1 and 2 on the motor unit. Should the symptoms persistafter the wires are removed, replace the receiver logic board. If thesymptoms stop with the wall control wires removed from the motorunit, replace the wall control button, and the wires leading to thewall control button.
Posted on Jun 17, 2010
  • 3197 Answers
SOURCE: my craftsman 41a4315-7d garage door
Remove the cover and check the drive gear. It is white nylon and is just in front of the motor. You will find it is stripped. The part number is 41A2817.
Posted on Jan 28, 2011
Replaced logic board on sears garage door opener, cannot turn light on from wall control
Did u make sure to plug the light in when u replaced the logic board? And u may have three wires been t only two are needed for the wall button ... whats the model number of your opener?
May 24, 2014 | Sears Craftsman LiftMaster Chamberlain...
I need a replacement for a Lift-Master 1/2 HP garage door opener. I can't find a model number, but do have a serial number: 41A4252-7B. It was installed in 1995, but I have no original papers on it. Is it...
The number you give is a part number for the logic board. The model number is on the opposite end of the opener. If it is a Craftsman the model number will start with 139.
Jan 06, 2011 | Sears Craftsman LiftMaster Chamberlain...
How can I test the Receiver Logic Board for Craftsman 1/2 HP Garage Door Opener Mod.139.53962SRT1
The only way a homeowner can test a logic board is with a good remote that is programmed to that logic board.
Jun 20, 2010 | Sears Craftsman LiftMaster Chamberlain...
We just installed a CG40Chamberlain 1/2 hp garage
Your logic board is bad. If this is a used opener I would pull the logic board and look for loose or missing traces on the printed circuit board.
Apr 19, 2010 | Sears Craftsman LiftMaster Chamberlain...
Model 41a4315-7c wont program remotes but will work with single wall button. has worked for years
That number you are giving is the part number for the logic board and if you cannot program your remotes is the part you will need. It is expensive.
Aug 26, 2009 | Sears Craftsman LiftMaster Chamberlain...
Only opens when remotes are close
The problem is in the receiver on the logic board. You will have to replace the logic board. You can get a replacement part at searspartsdirect.com. Thanks BB
Feb 22, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
107 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
