Question about Mr. Heater Heating & Cooling
Celsi fire wall mounted heater firebed doesn't light up
2 Suggested Answers
kebah
  • 683 Answers
SOURCE: Hi, my old Vulcan wall
Check if there is contact between the terminals of the thermostat using an ohm meter when set to a higher temp, if the reading is infinite or open, you have to replace the thermostat. Also check if the thermopile is receiving enough heat from pilot flame for it will generate a little amount of electricity to energize the main valve and fire up the burner.
Posted on May 11, 2011
1995 ford escort wagon heater problem1. 9 liter
probly the heater core when car is warmed up turn heat on and fell of heater hoses going in to the fire wall both should be hot if only 1 is it needs a core.
Apr 16, 2013 | Water Heaters
Mr. Heater MRH-MH18B. looking heat a unfinished basment about 1000sq ft
If you're asking if the Mr heater you referenced will heat 1000 sq ft, it won't. You'll need at least 32,000 Btu's to heat that much space. Either a gas mounted convection or infrared wall heater or a vent-free gas fireplace, that has a maximum heat out put of 32,000 Btu's should do the trick. Keep in mind, the air temperature in a basement, doesn't change more than 10 degrees F, thru out the year, so more than 32,000 Btu's is not better.
Hope this helped you and thanks for choosing FixYa.
Sep 12, 2011 | Mr. Heater MRHMH18B Gas Utility
Coleman catalytic converter heater bought about 1964 or 65. Are there instructions available for this product? My friend just found this heater and would like to put it into use. He doesn't have the...
I doubt very seriously that there are any manuals available any more. I think they discontinued that heater over 10 years ago. It was intended as a wall mount heater, that had a wall mounting bracket, that kept the heater about 3/4:" off the wall.
Sorry I couldn't be of more help.
May 06, 2011 | Coleman Heating & Cooling
30,000 btu wall mount reddy heater nat. gas. pilot lights and heater will run for about a min. then i hear a click in the main control and everything shuts down. Is this the double safety i read about...
Yes your pilot light may not be surrounding the thermocouple. Check and see it the pilot is burning blue and surrounds the thermocouple . These units are very sensitive if even a little breeze across the unit. You can clean the pilot with compressed air or maybe even a small wire brush. If this doesn't work you may have to change the thermocouple.
Apr 21, 2011 | Heating & Cooling
Williams debonair wall heater + pilot light problems
THE flame from the pilot should shoot past the thermo-couple and heat this up and make a small amount of mili- amps to prove the pilot light is lit. ..So if the flame doesn,t go past the thermo-couple it won, make mili-amps or its tme to change out the thermo-couple, They only cost lest than $8:00 and you can change it!
Dec 22, 2009 | Williams 3003622 Ceramic Wall Mounted...
Dyna-glo parts
thermocouples you can buy from any heating spares oulet or national energy a hone well is most common for useing as a replacement
Feb 03, 2009 | Dyna-Glo D-E36 Infra-Red Wall Mounted...
Wall mount dyna glo model RMC-40NGT
I have the same one i am looking for the wall brackets, I lost mine. I also bought mine at a garage sale the people had it attached to the wall completely hooked up .they had no fire backer on it .They only took it off the wall when i purchased it
Nov 02, 2008 | Dyna-Glo D-E36 Infra-Red Wall Mounted...
Installation of Fahrenheat wall heater
http://www.marleymeh.com/develop/prod_pdf/instructs/5200-2638-000.pdf
Jan 20, 2008 | Fahrenheat (FFH1614) Wall Mounted Panel...
Electric wall mounted heater
Make sure that the heater is mounted where convection currents occur freely. When heat builds up around the top of the heater its temperature will rise uncontrollably. You'll be luck not to get a fire.
Jan 18, 2008 | Fahrenheat (FFH1614) Wall Mounted Panel...
Heating & Cooling Logo
Top Mr. Heater Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Mack Baxter
Are you a Mr. Heater Heating and Cooling Expert? Answer questions, earn points and help others
