Question about Ovens
Need a manual for Westinghouse Self Clean Oven Model #WFS43W-1
If anyone can point me in the right place to find one I would greatly appreciate your help. lauriepsych@hotmail.com
Powerman
  • 68 Answers
SOURCE: after self clean, jtp15 panel does not work
This may be related to the F7 problem. The error does not always show up on the display. It typically develops after a self-clean cycle. Go to my solution at the following link:
http://www.fixya.com/howto/h155060-dreaded_f7_error
I have shared this solution with over 1500 folks and most report success. Let me know if this works for you at:
hutchipop@yahoo.com
Posted on Dec 29, 2007
jerryg50
  • 1667 Answers
SOURCE: hot point electric stove
The link below is from Yahoo Questions. The self cleaning can take a number of hours. It is best to do it on a cool day and when you can open windows to let in fresh air. Never wipe down the inside of the oven with an abrasive or strong cleaner. This will damage the surfaces, and the self clean feature will no longer work properly.
http://answers.yahoo.com/question/index?qid=20061117171220AAUmNX0
Jerry G.
Posted on Jun 02, 2008
kram26
  • 544 Answers
SOURCE: I need to self- clean my Thermador convection oven
hi,
here is the manual for your oven try to follow them and make them as your guide enjoy..
click on this site..
http://specs.retaildeck.com/CACHE/FILE2202.PDF
thank you,
please don't forget to rate our answers.
Posted on Feb 19, 2009
jumptrout51
  • 3361 Answers
SOURCE: frigidaire self clean oven..3 yrs.old.. code F9
Either your lock motor switches are defective and out of sequence or your electronic control(clock) is bad.
Posted on Jul 17, 2009
SOURCE: Kenmore Ultra bake self cleaning oven is showing code E0 - F2
My oven will not stay on, when started to preheat it will come on for a few seconds and they it will make a beeping noise and the codes E0 F2 will appear. The codes stay on even if the oven is off.
Posted on Aug 27, 2009
Hi lost the manual..need to start self cleaning
An electric oven is a great oven choice because of the advanced self-cleaning feature often available on certain models. A self-cleaning oven uses high temperatures to clean crusty baking spills and splatters and free its owner from having to use harsh chemicals to clean his oven. The following 4 steps lay out how a self-cleaning oven works.
Step 1 - Setting the Self Cleaning Mode
Depending on the style and brand of oven you own, you start the self-cleaning cycle by setting the oven's operating dial to "Clean," a function that can be as simple as setting a timer knob or pushing one or two buttons.
Step 2 - Cleaning Cycle
Once you have set the self-cleaning cycle, the oven coils-both lower and upper--will begin to heat. These self-cleaning ovens are protected from high oven temperatures damage by heavy insulation installed in their walls and door during the manufacturing process.
Step 3 - Automatic Door Lock
When the oven reaches a pre-determined temperature, the lock on the oven door engages, preventing anyone from opening the door until the oven temperature has cooled.
Step 4 - Removing Residual Ashes
Once the cleaning process is completed, including cooling, you can then remove the residual ash by wiping the bottom oven surface with a damp cloth or sponge.
Hope this helpout
May 17, 2011 | Ovens
Help! I am renting an apt (and the owner is overseas) and the oven/range which came with it is an older Caloric Prestige series (gas range and oven) with self-clean feature. It has been cleaned so often...
Hello!
can you find information (sticker / label)in the body of the oven. It will be easy giving you information if you can provide the brand and model number of the oven.
Please post back!
Apr 10, 2011 | Ovens
I recently bought a home with a Kenmore Self Cleaning Ultra Bake Oven but no manual to be found. Serial # 9755994 Model 880 655 124PO. I would appreciate any information regarding this stove and how to...
Head over to the manufacture's website.
Typically - they have a SUPPORT section that you enter your full model number in, and you can download the manual for free.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 09, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
I self cleaned the oven for 4 hours and it worked great. I decided to take the front glass off to clean inside it. it was quite dirty inside and the self clean did not effect it. Once I put everything...
The procedure to Disassembling the door is as follows:-- 1. Set the oven door wide open. 2. Lift the hinge jumpers with your thumb and index fingers, then turn them fully outwards to the end of stroke. 3. Turn the door towards the closure position and lay it on the jumpers: in this way the hinge's spring is blocked. By fully closing the door the hinges are unhooked from the connection slits which are integral with the oven muffle. 4) Re-assemble the door by carrying-out the aforesaid operations in the opposite order. Disassembling of the door glasses:-- for your safety, before removing the glasses you should remove the oven door. To facilitate the cleaning, after having removed the door from the oven, you can proceed with the disassembly of the glass. Release the two upper blocks so that the glass can be removed. After the cleaning you should reassemble the glass, replace the blocks and lock into position. Check that all components have been assembled correctly and than you can re-assemble the door onto the oven. check fig:-- For more help click this link directly. The model and brand is different in the picture but the procedure to assemble the door is similar to your model http://www.partselect.com/ModelFrames.aspx?ModelID=1015781&ModelNum=plef398aca&ManufactureID=4&Selected=QN7WQCV6&Position=1&mfg=Frigidaire&Type=Appliance&Mark=3 Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Jul 13, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
White-Westinghouse wall oven, no manual
after self cleaning I cannot open the door
Dec 18, 2009 | Ovens
I need an owner manuel for Caloric Range Model # EST 345 I can'g figure out how to run the self cleaning oven cycle.
you might try the following, although it is the instructions for an old model, it may be relevant;
"The actual self-cleaning process is initiated by a simple 5 step procedure: 1. Set the range clock to time of day. Note: on models not equipped with an automatic oven timer, the self-cleaning cycle is preprogrammed for a 21/2 hour cycle. Use Steps 3, 4 and 5 only. 2.Establish the length of cleaning time by:
A. Setting the start time. Press and turn the start dial of the automatic oven timer clockwise to the desired starting time. B. Set the stop time. Press and turn the stop dial of the automatic oven timer clockwise to the desired stop time. Max time is 3 hours miniumum 1/12 hours. 3. Set the oven selector dial on the control panel to "Clean" 4. Set the temperature control dial to "off". If you temperature control dial has a "Clean" position, then set the dial to "Clean" instead of "Off". 5. Remove oven racks, broiler pan and broiler grid from lower oven. Close and lock the oven door by moving the latch lever as far right as it will go - into the locked position. If the lever is accidently dislodged restore it to the locked position. Otherwise, the self-cleaning process will not take place. Shortly after the cleaning cycle has begun, the oven temperatur reaches a degree in excess of the normal broiling temperature. The red "Clean" light will come on and the clean cycle will start. In a few minutes the door lock lever, which you have placed in the locked position, will automatically be secured to prevent the oven door from beging opened during the cleaning cycle. This latch remains locked until the clean cycle is complete and the oven temperature reduces to normal baking and broiling temperaturs. NOTE: Prior to self cleaning cycle operation, the oven and surface lights must be turned offed. The upper oven can be used."
I found this here; http://www.appliance411.com/archive/21155_caloric_oven_lost_cleaning_manual.shtml
Nov 18, 2009 | Ovens
Range Cleaning Cycle not Working
All F3-E Codes - Oven Temperature Sensor (RTD) or Warming Drawer Defect - Replace oven temperature sensor (RTD).
Feb 22, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Need to Clean
go to fixva.com manuals...your model number is located on top of pot draw on body of range
Dec 24, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidare Self Clean Oven
I JUST CALLED FRIGIDAIRE AND GOT INSTRUCTIONS FOR SELF CLEANING:
1. TAKE OUT THE RACKS UNLESS YOU DON'T MIND THEM TARNISHING
2. TURN THE "SELECTOR" AND/OR "OVEN" DIALS TO THE LOCK (OR CLEAN) POSITION
3. PRESS THE "COOK TIME" BUTTON
4. SET THE CLOCK TO 2 OR 3 HOURS (I.E., "2:00" OR "3:00"), DEPENDING ON HOW DIRTY THE OVEN IS
5. PRESS "START" BUTTON
6. YOU WILL HEAR THE MOTORIZED LOCK MOVE INTO PLACE; WAIT ABOUT 30 SECONDS, THE DOOR SHOULD BE LOCKED AND CLEANING WILL BEGIN.
7. CLEANING WILL STOP AFTER THE TIME SELECTED (I.E., 2 / 3 HRS) AND THE DOOR SHOULD AUTOMATICALLY UNLOCK
Sep 30, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
The F5 error code?
I unplugged the oven and it cleared the code and was able to self clean the oven.
Jun 19, 2007 | Whirlpool GBS307PR Electric Single Oven
Ovens Logo
43 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
