Question about Broan-NuTone Dryers
Broan-Nutone Qt-300N exhaust fan not blowing outside
Exhaust not bowing outside only around
SOURCE: QT 100L replacement
Forget it. I also had the same problem with the QT100L. Cannot buy this unit and the replacement unit is the LS100L by Nutone/Broan. Good news: it is more powerful 110CFM and the housing is the same size. Bad news, the motor assy is completely different and it cannot be mounted in the existing housing. To install the new unit, you will need to cut the ceiling around the fan housing and install the new housing and wire it as well. Be aware that the wiring comes into the housing 180 degrees from the old QT100L unit. That means I hope you have enough romex to reach the hole. My advice is to get another unit from any other company because the quality sucks. It will be as much work to install any other brand as the LS100L.
Julius in CT
Posted on Nov 25, 2007
SOURCE: Replace motor in Broan 678 bathroom fan
I ran into the same problem, Lowe's carries Broan exhaust vents. They had both a replacement motor for all generations of 678 fans for $18, and they also had the latest generation of the complete unit for $40. I bought the complete unit, which included the fan I needed. Just unbolted it from the new bracket and bolted it to the old one. The new light housing, trim piece, and lens also interchanged. The existing one was old and yellowed, so this made for a huge improvement. All done from in the living space as well.
Posted on Aug 01, 2010
SOURCE: Problems with exhaust fan NuTone Model LS 100SE
The C-frame motor for LS100SE (P/N 62345) is no longer manufactured, and no replacement is specified. I checked with Nutone customer service if the motor for LS100 (P/N 89169) will work. They said the blower housing is the same between the units, so it should work mechanically, but the plug configuration is different requiring some electrical changes.
Posted on Aug 17, 2010
  • 3600 Answers
SOURCE: My Bathroom Fan (Nutone) is sucking very little
if there is no suction my question back you would be do you have a leak around the box in the cealing did you use calking material when you installed it? let me know so I can help. Also do you have a window open to see if the room breaths? Just some ideals Reply back for more help.
Posted on Aug 31, 2010
  • 95 Answers
SOURCE: We have a Broan/Nutone 763RLN Ceiling Fan/Light in need of cleani
The grille is held in place by the reflector. The reflector is hidden by the the lens. The first step is to remove the lens, then you will remove the light bulb. You will see one wing nut above the light socket. If you unscrew that the reflector and the grille should come down. The replacement motor assembly for the 763 RLN is the S0503B000, if you are looking for a little more power you could also purchase the S0504B000
http://bit.ly/ax4Upk
Posted on Nov 19, 2010
I would like to replace a Nutone 8663Rm series bath exhaust fan with a Broan 683L The 683L requires an opening of 8" X 8 1/4". Since access it is located in the attic, where it is unbearably...
You can buy a replacement motor assembly for that model.
http://vacuums-intercoms.centralvacuumstores.com/search?w=8663rmsa&af=type%3Aproduct&asug=&x=0&y=0
http://parts.broan-nutone.com/nutone/Shop?actn=quicksearch&searchtype=all&indextype=7&keyword=8663rmsa&Search.x=0&Search.y=0
Jun 16, 2011 | Broan-NuTone N-8663RMSA Combination Light...
Our exhaust fan is really noisy. Nutone QT 100N-B model. Where can we purchase a new one?
This model has been discontinued but replacement motor assemblies are available. There is no off the shelf model that will fit in the existing housing. If you do not want to replace the housing then the motor assembly is the way to go.
You ca purchase the replacement from either site below:
http://www.centralvacuumstores.com/Bath-Vent-Fan/NuTone/Motor-Assembly/0696B000-Motor-Assembly.php
http://parts.broan-nutone.com/nutone/Shop?actn=quicksearch&searchtype=all&indextype=7&keyword=qt100l&Search.x=0&Search.y=0
Jun 07, 2011 | Broan-NuTone QT100L Fan
My nutone qt-110n-b is louder than usual and I seem to have a loss of exhaust.
Sounds like you need motor replacement assemblies. take a look on amazon for it. Amazon com nutone qt 110n motor. Hope this was helpful. cheers
Mar 06, 2011 | Broan-NuTone N-LS100SE Exhaust Fan Exhaust...
My Bathroom Fan (Nutone) is sucking very little but blowing quite abit from around the fan asembly meets the cutout in the ceiling. The vent outside is blowing out quite a bit of air, (more than whats...
Aug 31, 2010 | Broan-NuTone N-763RLN Combination Light...
Nu tone model QT-100N-B. looking for a replacement. Were can I buy 2 of them in sacramento, ca?
There is no replacement fan for that model that will fit in the existing housing. You can buy the replacement motor assembly.
You can buy these online and have them shipped to you:
or
http://www.centralvacuumstores.com/search/search.php?keywords=qt110&x=47&y=15&asug=
or
http://www.partstore.com/Part/Broan-Nutone%20Group/Broan/0696B000.aspx?s=froogle
Jan 07, 2010 | Broan-NuTone QT100L Fan
When it is windy outside the flap on my exhaust fan flaps open and shut. Is there a problem in the way the fan was installed?
Not likely, Just a condition of the location of the vent and the wind direction.Putting a secondary larger hood over the outside exposure will sometimes help alleviate this.
Eric
Oct 13, 2009 | Broan-NuTone Nutone QTRN080 Quiet Test 80...
Where can i get a replacement motor for a qt100l BATH FAN?
Go to the link below and you can order replacement parts for the QT 100L
http://parts.broan-nutone.com/nutone/Shop?DSP=30115&PCR=1:21000&IID=QT100L
Nov 08, 2008 | Broan-NuTone QT100L Fan
QT 100L replacement
Don't worry, you can purchase just the fan from amazon (not entire motor). here: NuTone 0696B000 Motor Assembly for QT100 and QT110 Series Fans. I hope this was helpful. cheers
Oct 12, 2007 | Broan-NuTone QT100L Fan
Dryers Logo
223 people viewed this question
Top Broan-NuTone Dryers Experts
Mike Squire
Craig Dupler
Level 1 Expert
Are you a Broan-NuTone Dryer Expert? Answer questions, earn points and help others
