Question about Troy Bilt 22HP Hydrostatic 46" Riding Mower
How to change a drive belt on a 46" troy-bilt super bronco mower
  • 760 Answers
SOURCE: I have a troy-bilt gtx 2446,i put a new drive belt
If you don't have your manual, this might be for yours (you didn't list complete model number)
http://www.managemylife.com/mmh/owner_manuals/10259/TROYBILT-Lawn,-Tractor-L0401081?brand_name_search=14AZ809H063+TROYBILT
See the part about changing drive belt and adjusting. If you got it around idler pulleys wrong, it might not lelt the clutch go far enough to apply the break.
Posted on Jul 28, 2010
  • 12 Answers
SOURCE: NEED A DIAGRAM OF HOW TO ROUTE A BELT ON A TROY
type in your model number to your search engine. find your model and the diagrams will be there.
hope this helps.
Posted on Aug 13, 2010
vincob
  • 718 Answers
SOURCE: how to replace drive belt on troy bilt lawn
Go to this website, upper right hand corner and do a parts look up. Search for your model and that good stuff they ask of you and then choose mower housing should be there, browse the site it's really cool and has a lot of info.
http://www.jackssmallengines.com
I did a sample search for generic riding mower deck and found great diagram of belt routing. Give it a try you will find same results Good Luck! Don't forget the thumbs!
Posted on Sep 18, 2010
  • 3911 Answers
SOURCE: I have a troy bilt pony and the drive belt to
well i would take a long look at the spring which holds the tension pulley in place. if it is weak, or not connected correctly, there will be inadequate tension and the belt can come off. I would also take a look at whatever fasteners keep the deck in place as if it is not kept to the rear, there again will be too much play in the deck belt.
Posted on Apr 06, 2011
  • 147 Answers
SOURCE: can i get a diagram
without more information i can only give you a link.http://www.troybilt.com/webapp/wcs/stores/servlet/ARIPartFinderView?storeId=10001&catalogId=14102&langId=-1#Error
if this dose not help please contact me back with more info like model, make, year and I will do better.
Posted on Jun 05, 2011
Troy-bilt bronco riding mower hydrostat drive will not move mower
be sure the drive rod is engaged on the back of the mower. pulled out should be free move and in should be the drive position. if it is in check the belts are in good shape and not off of a pulley.
Feb 05, 2017 | Troy-Bilt Garden
2006 Troy Bilt Super Bronco riding mower. How can I grease the rear end?
Hi, Your Troy-Bilt has a sealed for life transaxle and requires no service. However, there have been some issues with the CVT clutch assembly bushings. Since there are no lubrication points, if the unit will not reach top speed or changes speeds abruptly, the first thing to inspect is the drive belt wear and tensioners. If the belt is in good condition then the bushings, and/or the clutch assembly will need to be replaced. I hope this helps and feel free to reply back if you need further assistance. Here is a link to the transaxle and clutch assembly;
Troy Bilt 13AX60TG766 Troy Bilt Super Bronco Lawn Tractor 2006 Drive...
Mar 14, 2016 | Troy Garden
Need diagram to replace tension spring for drive belt
Go to the manufacturersame website, enter in the the model number and look under diagrams for the pic of your tractor. My troy Bilt has 2 belts, one for the cutting deck and the other is the drive belt. I would replace both as the cutting deck needs to be removed and it's fairly simple and will save you time. It sounds let the drive belt is the reason for the tractor not moving. Hope this helps.
My tractor is a 2007 troy Bilt super bronco with a new fresh installed motor.
Nov 03, 2015 | Garden
Where can I get all three belt diagrams for a troy built bronco riding lawn tractor model# 13AV67KG
Troy Bilt Deck belt Replacement - YouTube
? 11:46
www.youtube.com/watch?v=w3SrErGTyoY
Apr 1, 2014 - Uploaded by Murray Mayhem
I got a good one troy bilt bronco having problems finding the right deck belt for it. I use the model number under the seat but they are too long ..
Jul 09, 2015 | Troy Garden
How do i replace drive belt on a gardenway lawn tractor 16.5 hp 42 inch cut hydrostatic drive troy bilt gardenway
how do you install a drive belt on a 46 inch garden way troy bilt riding mower
Jul 26, 2010 | Garden
Had to change the small drive belt that drives the transmission on a Troy-Bilt 42'' 17.5 HP Pony mower. Now it only has one speed forward, slow!! Didn't touch anything-got the OEM belt replacement. Any...
You need to adjust the gas pedal. Info should be in the owners manual. I have it in my Troy Bilt Bronco manual. It say to adjust it in my book after replacing the trans drive belt. Maybe that will help.
Aug 17, 2009 | Garden
Changing Drive belt On Troy Built Tiller
You have to remove the engine (4 bolts, no big problem), then remove the bolt in the center of the pulleys, then remove the pulleys. Slip the belt(s) (2 if you have the Super Bronco model) onto the pulleys, re-attach the pulleys with the bolt, re-mount the engine, and you're home free.
May 20, 2009 | Mtd Troy-Bilt Bronco OHV Tiller
Troy Bilt 22HP Hydrostatic 46" Riding Mower Logo
382 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
