Question about Panasonic Televison & Video
How do I hook up my Panasonic dvd recorder EZ248V to my box AND TV
WIRING i USE TO HOOK UP RECORDER TO CABLE BOX AND TV
  • 142 Answers
SOURCE: dvd/vcr without cable hook-up
If ** cable TV hookups exists, then the only inputs you can use are the line-in along with audio left/right. You've probably got a slew of output connections. Your unit does **t contain a tuner (which would allow you to use a cable input). You need to have a cable box or other device (vcr/tv) that has outputs compatible with the input of your dvd/vcr. A lot of dvd/vcrs are that way. It actually saves you some $$ since most cable boxes (especially HDTV compatible) already have the required outputs on them.
Posted on Mar 10, 2008
  • 3 Answers
SOURCE: Panasonic DMR-E85 DVD recorder TV Guide problem
Unit must get the TV guide from an analog station. If cable company goes digital you loose the data. If the station that hosted TV guide goes digital you loose the data. This unit does not have a digital ATSC tuner only analog NTSC tuner. If you are still getting analog data there are a few capacitors on the power supply under the hard drive that bulge up and cause problems. They should be replaced with higher voltage rating types.
Posted on Feb 08, 2009
pgh_pa_guy
  • 2992 Answers
SOURCE: Problem hooking up DVD player to TV thru my cable box
Chances are you've got your DVD player hooked to OUPUT jacks on the cable box, not inputs. I haven't yet seen a box that takes any kind of an input other than the cable line, but they will have RCA jacks for audio and video outputs on the back. So your cable channels are fine, but the DVD signal is hitting a dead end.
The only solution if your TV doesn't have RCA inputs for video and audio is to get an RF converter (around $10-$20). This takes the A/V signals from your DVD and turns them into a channel 3 or 4 signal that connects to your TV's antenna input.
The converter also has a connector on the back for the cable coming from the cable box, since you'll have to disconnect that from the TV. When the DVD player is off, the cable box signal gets passed to the TV as normal. Turn on the DVD player and the RF converter switches on; put your set on channel 3 or 4 and you'll see your video.
One final thing: The converter will need an AC outlet for its power adapter or power cord, so make sure you have a spare. If you don't already have your TV and DVD player connected to one, this would be a good time to pick up a surge-protector outlet strip. Then not only will you have enough outlets, you'll be protecting your equipment as well.
If this solution has given you what you need, please take a moment to rate it appropriately. And thanks for asking here!
Posted on Mar 01, 2009
Testimonial: "Thank you. I forgot to thank you when I first read this response. Works fine now though :)"
  • 7 Answers
SOURCE: How to eliminate error screen:"your tv does not allow display of this program through the dvi input source. please chose another tv input source."
"cable box to tv is hdmi cable"
Everything I've read on the web says cable box to tv connection must also use component (rgb) cables. The error is coming from the cable box (STB). All the Scientific Atlanta (SA) cable boxes seem have this Digital Rights Management (DRM) bug and the only way to be totally rid of the error is to replace the digital connection from box to the TV with an analog connection.
Posted on Jun 06, 2009
ltfrc
  • 227 Answers
SOURCE: Would like to record from my tv to my magnavox dvd/vcr combo box
If I understand your request right, You do not have cable or satellite box.
You can not record from your TV. You use the TV as a monitor from the dvd/vcr combo box. What the box receives is what shows on the TV. So you will have to have a digital convertor hooked to the (antenna in) dvd/vcr combo box, (antenna out to the tv antenna in) Depending on the antenna you are using that is on the other end of your cable-in coax connection this will hook to your antenna in on the digital convertor box. If your cable is hooked up and operating correctly and directly to the tv that is digital ready you probabbly have a good picture. When the vhf/uhf signal was transmitted you could go from the dvd/vcr to the tv with no problem. But now that the signal is digital and the tv is set for digital the dvd/vcr will not pass a digital signal to the tv. Best suggestion, you have to get a digital dvd/vcr receiver. If you have more question please contact me.
Mike
Posted on Jul 25, 2009
Www panasonic com help
You will need to connect your cable box to your DVD recorder and then connect your DVD recorder to your TV to be able to record content.
Oct 06, 2013 | Panasonic VIERA Televison & Video
We have a magnavox dvd/vcr player. We can't figure out how to record a program from our t.v. on the vcr. it is hooked up to a panasonic viera.
First, make sure the wiring is ok, any outside cable connection (box) wire from the out..should be plugged into the in on the dvd.vcr... and the wire out from the dvd.vcr to the tv...... now make sure the tv and dvd/vcr is both on Ch 3...........(if cable / sat this will select the ch)..... ok test it pick a channel.........press rec on the vcr,,, 30 seconds is long enough... stop rewind press play ..... yeeay.........
Oct 05, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Hookup wrong? I can't get the menu to come up for the VR375
New HD tv. Have digital cable box connected to tv., cable box connected to DVD recorder, but can't get setup menu to come up on tv screen. I had a similar problem. I have a HD tv connected to a digital cable box. I hooked up the DVD recorder with the wires it came with, but it would not play or give me the menu. However it was correctly hooked up. So the next day I connected a HDMI wire from the DVD recorder to the tv and everything works now.
May 24, 2009 | Samsung DVD-VR375 DVD Recorder/VCR
I'm simply looking for the most efficient way to hook up my HD-TV with HDMI inputs to both my cable box (with HDMI inputs) and my DVD player/recorder so that I can record from the TV I watch.  ...
The way you have it hooked up right now will not work unless you have a coaxial out on your cable box going to the dvd recorder. Even then, picture quality will be severely degraded. The best way to do it is to leave your cable box hooked up to your TV via HDMI and connect your dvd recorder to your cable box via component video if your dvd recorder has a component video input. If it doesn't, then just use the composite video input. That way your picture quality will be better and you will still be able to record with the TV off.
Jan 02, 2009 | Insignia 37" LCD Flat-Panel HDTV
Dvd/vcr with ** hookup for cable tv
Just hook your antenna or whatever wire you have currently connected to the TV to the input on the new recorder, and you'll be to record anything you can watch now.
Mar 10, 2008 | Memorex MVD4540 DVD Player/VCR
CONNNECTING THE DMR-EZ475V TO A TV, THEATRE SYSTEM AND CABLE BOX
noavatar_s.png jdrrwoods
Rank:wizard_s.gif Wiz
Rating: 84%, 12 votes
http://www.altex.com/product_info.php?products_id=9207 here is a link to a audio / video switch box you need one of these make sure it has several audio video in and at least one audio/video out
hook all you rca1.gif cables up to the audio/video in from the cable box, tv, and dvd/vcr combo then out to the surround sound youll also need to get some rca cable splitters for the out so you can run it back to the audio/video in to the tv as well as the surround sound here is alink to what they look like
http://www.altex.com/product_info.php?cPath=344&products_id=6201
youll need thre of these of course when hooking it up dont pay attention to the color on these just the ones from the tv and surround sound and thats it your done it will all work if you want it to were you dont have to get up and push a button everytime most of them if you push all the buttons in at one time theyll stay like that
Feb 08, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
SETTING UP TJE PANASONIC DMR TO OTHER COMPONENTS
if studio audio facility in tv there [are] hence remaining to install just input channel of output but if there is no having to suround efec,thank.........
www.modifmax.com.
Televison & Video Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
