Question about Gateway 450SX4 Notebook
C0000218 Stop Error
I found this error on some blogs and they directed me to download RegCure, which I did. But my friend's computer won't allow me to get to a DOS prompt to install or run the scan. It just keep rebooting over and over.....
  • brendap1010 Oct 24, 2008
    The problem is, I can't get to a prompt of any kind to run a scan.
  • brendap1010 Oct 26, 2008
    But I can't get INTO Windows.... or to a DOS prompt
  • 535 Answers
Your pc has been infated by virus that y this error coming scan it from good anti virus like mcafee or avg free
Posted on Oct 24, 2008
  • sandip panchal
    sandip panchal Oct 25, 2008
    you not need to scan from to dos just open my computer right clik on it click on scan frist scan c drive then all
I hv error 6266 in tally and m not able to fix his error pls suggest me the way tom resolve this error
Causes of the error:
Windows Tally Error 6266 are caused by misconfigured system files.
So, from my experience, If you received a Tally Error 6266 message then there is a 97.5% chance that your computer has registry problems.
The Windows Tally Error 6266 are easy to repair. By downloading and running the registry repair tool RegCure Pro, you can quickly and effectively fix this problem and prevent others from occuring. Simply click the links below for your free download.
To Fix the problem you need to follow the 3 steps :
STEP 1:
Download & Install RegCure Pro for Free.
NOTE: If the download link doesn't work you may need to Download it Directly from a Mirror Here.
STEP 2:
Click "Quick Scan" Button to Scan Your Computer.
STEP 3:
Click the "Repair All" Button to Repair Your PC!
Nov 05, 2015 | Computers & Internet
Error 206 are caused by miss configured system files.
So, from my experience, If you received a Windows Http Error 206 message then there is a 97.5%chance that your computer has registry problems.
STEP 1: Download & Install RegCure Pro for Free.
STEP 2:
STEP 3:
Apr 13, 2014 | Office Equipment & Supplies
Stop c0000218
Which operating system ????
If you've just installed Windows XP on your desktop and you've received the following error "STOP: c0000218 {Registry File Failure" you're not alone.
This is a known issue with XP that can arise from incompatible hardware being installed with XP or, in the worst-case scenario, from a faulty hard disk.
Luckily, it is fairly simple to figure out if your disk needs to be replaced or if a software fix is enough to solve the problem.
Check if your hardware is compatible with Windows XP.
You can find compatibility information at the official Microsoft marketplace website (see Below).
http://www.windowsmarketplace.com/
Use the recovery system if your hardware is compatible but is still not working. You can access the recovery console by simply putting in your Windows XP CD before booting your computer.
You will be asked whether you want to "Repair or Recover.
" Simply press the "R" key.
Type in your administrator password.
(You must have admin access to use this option.)
Choose to use the "chkdsk" command line, which will allow you to check your disk.
Once in the chkdsk use the "chkdsk /r" command to check your hard disks for errors.
Press "Enter" to start the disk check.
Type in "chkdsk /f". If any errors are found this will allow your computer to attempt a fix of the broken drive.
Restart your computer after the disk fix has been performed, and attempt to run your Windows XP setup again.
You should have no input while the chkdsk utility is in progress any input might further damage your computer and hard drive
Replace your hard disk if the setup fails with the same message. At this point your hard disk is more than likely broken and needs to be replaced.
Jun 25, 2013 | Dell Computers & Internet
How to remove from the error 5201
What Type of Printer is it? Each Company has their Own Trouble Codes...
Cannon for Example"
Problems with Error 5201
Cause: 5201 errors usually are caused by misplacement or broken system registry
structure.
Note: This is also a critical sign of an unstable system that is usually caused by improper
maintenance of the computer
Solution: RegCure is a Microsoft Certified tool that is tested to repair issues with code 5201 errors.
Download & Fix with Regcure Repair Tool Free!Windows 98/SE/ME/XP/Vista Compatible
Regcure Additional Features:
Repair ALL detected Registry Errors instantly!
Optimize PC's performance up to 300% Faster!
Prevents Freezing & Crashes - Completely!
Increase Window's Boot & Programs Speed!
Advanced Windows configuration settings!
Error Code 5201 Problems
JavaScript / Scripting Errors
Internet Explorer / Active X Errors
EXE / DLL / OCX Errors
Virtually all Windows related Errors!
How To Use:
Step 1: Download & install RegCure Repair Tool for FREE!
Step 2: Scan your computer
Step 3: Click the 'Fix Errors' button & your DONE!
Apr 12, 2013 | Office Equipment & Supplies
The system cannot find the file specified. (0x80070002)
Problem with 0x80070002 Error? Don't Worry - i'm here to help you fix it!
0x80070002 Errors are caused in one way or another by misconfigured system files.
So, If you got error 0x80070002 then there is a 94% chance that your computer has registry problems.
To Fix the problem you need to follow the steps below:
Step 1 - download and install RegCure Registry Scan for FREE.
NOTE: If the download link doesn't work you may need to Download it Directly from Regcure Site Here.
Step 2 - Click the Scan Button.
Step 3 - then click the Fix Button and you're done!
May 12, 2009 | Computers & Internet
Computer is not booting up error code c0000218
You get this message from a corrupt or damaged registry or corrupt or missing drivers, or both. Unless you have made a full backup of the operating system and data, without the XP disc I don't know of any way you can fix this. See if a friend has the same operating system disk. If all else fails a reputable repair person can solve this.
Good Luck
Mar 21, 2009 | Dell Inspiron 8600 Notebook
Error 17? what is that?
Error 17 Codes are caused in one way or another by misconfigured system files.
So, If you got error 17 then there is a 94% chance that your computer has registry problems.
Download and install RegCure Registry Scan for FREE.
Mar 02, 2009 | ASUS Eee PC 900 Notebook
Intrnal error
If you got c0000005 error then there is a 94% chance that your computer has registry problems. To Fix the problem you need to follow the steps below:
  • Step 1 - Choose a c0000005 error repair tool,download and install c0000005 error repair tool Scan for FREE.
  • Step 2 - Click the Scan Button.
  • Step 3 - then click the Fix Button and your done! It is very easy to repair c0000005 error.
Q: Which C0000005 Error Repair Tool is the most effective? A: The results of our research and rigerous testing procedure found that Perfect Optimizer was the most effective c0000005 error repair tool. Its easy to use, eliminated all known errors on our computer, includes great safely features and left our PC running incredibly fast. We were extremely impressed! Second came RegCure which was very user friendly, but did not perform as well in tests. Third came RegistryEasy.
Click Here To Download Our Winner C0000005 Error Repair Tool "Perfect Optimizer":
Dec 18, 2008 | TallyGenicom (048959) for T2265, T2280,...
Computers & Internet Logo
95 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
