Question about Oster Golden A5 2-Speed Universal Motor Clipper 78005-140
Removed balades for cleaning how to reinstall them oster nodel 76974-710
Oster Vt3
4 Suggested Answers
SOURCE: NEED PARTS FOR OLDER OSTER CLIPPERS
I gave it a shot and it worked!!!....
No need to bother with the universal guards. They looked bulky for the task, and after careful (visible scrutiny) decided to gamble on the "fast feed clipper" guides. Check them out here:
http://www.cache-beauty.com/oster0541.html
There are surely other people who sell them - you might shop around, but I bought from these guys. Warning, the shipping price is kinda steep. But like I said in my last post, I've tried other clippers and these are just the best. It was worth it to me.
Anyway, I am now confirming that these guards fit this old clipper brand of ours. Perfectly!
Posted on Feb 03, 2009
greenspan
  • 1734 Answers
SOURCE: Where do I put the oil in my oster a5
Find a manual for the Oster Clipper Motor here:
http://manualfox.com/link/oster.htm
Posted on Apr 09, 2009
philschneide
  • 448 Answers
SOURCE: Bought Oster Golden A5 clippers new but did not
There is a small gun-metal colored bar at the very rear, just below the back of the blade. It pushes inward, in the direction of the blade. Push it firmly in and pull up on the teeth of the blade. It should pop upward. You can then remove the blade from the tongue that it sits upon. When you want to put it back, slide the blade back on the tongue, then, WITH THE MOTOR TURNED ON, push the blade down to its seated position. It will click into place.
Terms regarding these devices are all too often assumed as understood. For most purposes, these are what you have to know for the A5 Oster. The cover plate is the part with two screws that has the name and other info on it. If you remove the two screws and the plate, you will see a nylon part that moves the blade back and forth--that is the lever. The other end of the lever, with a hole in it, is connected to a metal part called the link. Both parts are easily removed by simply pulling them upward from the device. The bakelite gear is the part that the link sits on (the larger hole in the link). It too can be simply pulled up off the metal shaft that it rides upon (careful not to lose the washer under it). That gear is turned by the armature gear of the motor (which is where things get much too involved to cover here, but from that point on the device very rarely has problems). Incidentally, the lever, the link, and the gear can all quite simply be replaced. They are available quite inexpensively at Amazon under Oster A5 Clipper parts (note that the one speed and the two speed take different bakelite gears, but the lever and the link are the same). If you were to replace parts such as these or simply lubricate them, remember that a good white lithium grease is recommended in light application for the gear and the shafts (lever and gear shafts and armature gear). Also, the gear shaft has a hole down its middle (and two small holes that lead to the outside of the shaft. The shaft should be filled with grease so that grease can get through those small holes to lubicate the inside of the bakelite bearing. The two pads (one on each side of the lever) should be oiled. The simple way to tell if you need to replace parts is to grip the blade end of the lever while all parts are in place and try to move it back and forth, as though it were running the blade. If there is any more than the slightest movement, replace the lever (replace that anyway if the part that contacts the blade is rounded off) link and gear.
Good luck.
Posted on Oct 03, 2009
Can't get my oster 3181 to come apart for cleaning
Hi Mary, if it is not an Oster Shaver or Clipper then it may pay to ask again in the correct category, it seems it may be a juicer.
Apr 05, 2015 | Oster Health & Beauty
I'm after replacement parts for my oster versa 1400w blender preferably in australia .
when you order parts it goes by model number, from what I can see there are several different model #'s for the Oster Versa,
BLSTBV-RV0-000 and BLSTVB-000-000.
try here, type your model # in the search area at the top.
Oster Blender Parts
or here,
Oster blenders lids blenders jars caps at Goodman
or here, under parts & accessories
Oster Parts Accessories Oster
I haven't found any where in Australia to get them, you may just have to get them on line.
Mar 05, 2015 | Oster Blenders
How to assemble an Oster 3125 can opener?
Hello, Here is the users manual that you are looking for: Oster 3125 User Manual
May 25, 2014 | Oster 3125 Tall Can Opener, White
I have a older model Oster bread maker I cant find the model. I brought it from Salvation Army and I need a manuel
Oster manuals are not the easiest to find; here are three; hope one is is for a model similar to yours. If you can find your model number on the botton or back might be able to assist further.
Thank you for using FixYa!
CKSTBRTW20 - Oster® 2lb. Expressbake® Bread Maker
http://www.oster.com/manuals/MANUALS/CKSTBRTW20_43_33506787.PDF
5838 - Oster® 58-Minute Expressbake® Breadmaker
http://www.oster.com/manuals/MANUALS/005838-000-000_ENGLISH.PDF
Deluxe 2-Pound Bread & Dough Maker
http://kitchen.manualsonline.com/manuals/mfg/oster/deluxe_2pound_bread_dough_maker_p_n_101017.html?idRes=2148332
Sep 14, 2011 | Oster 5838 ExpressBake Bread Maker
How to use clean cycle
Most probably find a Oster Coffee Maker manual here. Just send them a search request.
Apr 26, 2009 | Oster HDX23 12-Cup Coffee Maker
Newbie Clipper needing advice
This is from the Oster book:
Changing Blades
To Remove: IMPORTANT- stop motor; push latch with thumb while lifting blade away from clipper and slide off tongue.
To Replace: turn motor on; insert blade on tongue fully and then snap blade into place.
Note: if the hinge is flush against clipper, lift it up with a screwdriver.
From me - Never take your blades apart to clean them. You can slide them one side to the other to get the hair out. (One little hair, can stop them from cutting.) You need to buy a can of clipper blade cool from oster or andis both are good, and it really helps to lubricate the blade and keep them cool while clipping. If you live near a dog groomer, petsmart or something of the like. Ask them to show you how to remove the blade and I know they will be happy to show you. I tried to submit an image from the book, but I don't know if it will get here or not.
Mar 31, 2009 | Oster Golden A5 2-Speed Universal Motor...
Set up Oster Microwave
No, that is the "waveguide cover".
It provides very important protection for the magnetron.
And always keep it clean according to your manual's instructions.
Jan 18, 2009 | Oster 0.7 Cu. Ft. Compact Microwave
Oster kitchen center driver removal
http://www.oster.com/CustService.aspx
The customer service will help you to find the right answer to your question.The do also have technical repair center or they will tell you how to return the item for replacement.i used before and they work good
Jun 12, 2008 | Oster Food Mixers
Oster Golden A5 2-Speed Universal Motor Clipper 78005-140 Logo
81 people viewed this question
Top Oster Health & Beauty Experts
Anglia Clipper...
shaveroutlet.com
shaveroutlet.com
Michael Vincent Cruz
Are you an Oster Health and Beauty Expert? Answer questions, earn points and help others
